Old 01-19-2004, 12:20 AM   #10336
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by AMGRacer
Yes the K Factory belt does free up your drivetrain.
especially the mid belt which makes the biggest improvement to your drive tran.
Manticore is offline   Reply With Quote
Old 01-19-2004, 12:37 AM   #10337
bulldog's Avatar
Default question
does anyone know a hobby shop that carries kyosho parts(v1r/evo) in orange CA?thanks in advance.
bulldog is offline   Reply With Quote
Old 01-19-2004, 12:43 AM   #10338
carkillaii's Avatar
BullDog try tower hobbies
carkillaii is offline   Reply With Quote
Old 01-19-2004, 12:54 AM   #10339
rrgt_kid's Avatar
Holy smokes!!
hi amg is this your design top deck if so how did you make the kfactory low cg tank fit correctly???its awsome!!!
or you find the pic from a web site or something!!!!
jeremy.
rrgt_kid is offline   Reply With Quote
Old 01-19-2004, 12:57 AM   #10340
Manticore's Avatar
the fuel tank has been re-positioned to a bit to the left side.
Old 01-19-2004, 01:11 AM   #10341
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by Manticore
a Lola body shell works best with this combo but you need to do thing you dare not to do with a rear diff. i.e. you need more throttle time and drive it like you steal it !!
See a corner....give it more throttle...be brave...and be prepared to trash a couple of shells before you get the hang of it!!
dtm is offline   Reply With Quote
Old 01-19-2004, 08:36 AM   #10342
mckrooz's Avatar
Send a message via AIM to mckrooz
Default Re: question
Ultimate Hobbies in Orange carries some V-One parts. Mostly just your basics though like knuckles and arms etc.
www.ultimatehobbies.com
mckrooz is offline   Reply With Quote
Old 01-19-2004, 10:59 AM   #10343
popsracer's Avatar
Default Traction rolling
Guys;
I'm having problems with traction rolling.
The track is large sweeping and sprayed with VHT occasionally so bite is VERY high.
Using the Gold springs, 80wt oil, Heavy Rear sway, Front bar at 45, 4.5mm ride height and 45/42 Tires. The Car handles very good and is fast until the tires warm up, then it T/R's.
What changes whould someone recommend to combat the traction roll?
Thank you,
popsracer is offline   Reply With Quote
Old 01-19-2004, 11:41 AM   #10344
ziggy12345's Avatar
Drive slower
ziggy12345 is offline   Reply With Quote
Old 01-19-2004, 11:54 AM   #10345
drfritz's Avatar
Default Re: Traction rolling
Originally posted by popsracer
Guys;
Thank you,
Smaller tires
drfritz is offline   Reply With Quote
Old 01-19-2004, 03:30 PM   #10346
AMGRacer's Avatar
jeremy.
I cannot claim credit for this!! Somebody in France made it. He measured it up using a plastic plate first, then cut it into a 1.8mm graphite plate.
AMGRacer is offline   Reply With Quote
Old 01-19-2004, 03:36 PM   #10347
AMGRacer's Avatar
Guys;
Thank you,
The three best things you can do to avoid traction rolls in my experiences:
1. Not easy but make sure everything on the car is low as possible. Obviously you are limited by car design here.
2. As stated above small tires. On a high grip course you need to be under 59mm in my experience. Also it is VERY important that you round the edges of the tire off the truer. If they are square they will "catch" as you corner.
3. Minimise droop as much as possible. The beauty of reduced droop is that as you roll into the corner it will lower the CG of the car.
Another interesting thing is that a too hard setup can actually make the car traction roll. If the suspension is so stiff that the car will not roll at all and your tires are too grippy you can go over. Your setup does not look this stiff however.
Old 01-19-2004, 05:16 PM   #10348
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Decrease your rear toe and stiffen your front bar to the vertical position. The best thing to do here is adjust your droop first. What are your camber settings?
Racing4Evo is offline   Reply With Quote
Old 01-19-2004, 05:20 PM   #10349
Racing4Evo's Avatar
Sounds like Revelation Raceway. The best body to use with this car is the orginal Stratus. You definitely don't want to run the Alfa Romeo if that is what you are using. If you need more steering the go to the 2.1 or even more steering, the RDLogic Stratus.
Guys;
Thank you,
Old 01-19-2004, 06:28 PM   #10350
popsracer's Avatar
Default Traction Rolling
Guys;
Yes this is at Revelation raceway.
Front: 2 deg Camber, 2mm droop.
Rear: 3 deg Camber, 4mm droop.
Body: Original Stratus with the wing in the middle hole.
ziggy12345: You've GOT to be kidding!
Thanks,
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
