Old 01-15-2004, 08:07 AM   #10306
EiKuD's Avatar
Originally posted by ziggy12345
I just ordered the Evo conversion kit from JPL racing in Singapore. This is not the Kyosho kit. Does anybody have this and whats it like? It has the 3racing chassis!
Cheers
I have the Evo conversion kit rom JPL racing, it's a compilation of 3 racing parts and kyosho parts. Everything needed for the conversion is there except for 2 speed and pinions. They work fine for me, i am satisfied with them.
The Guy Ahead Of Me Is There To Be Overtaken
EiKuD is offline   Reply With Quote
Old 01-15-2004, 09:48 AM   #10307
ziggy12345's Avatar
Thanks Man!
I wasnt going to use the 0.8 gears anyway as I have the set of the old ones and they are OK.
Apart from the conversion kit whats the most usefull hop ups? I have been looking at the new type of blade rear roll bars. Anybody using these?
Cheers
ziggy12345 is offline   Reply With Quote
Old 01-15-2004, 10:00 AM   #10308
Trader Rating: 74 (100%+)
Default for sale
Please check my for sale post, I know this doesnt belong here.
Unfortunantely, I have sell my Evo rr, raced it once. Tooooo many car in my fleet. I dont have a digital camera, but if you open up the issue of car action sep 03 you will see my car. They used my car for the shoutout versus the fw05r. See my for sale post.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 01-16-2004, 01:00 AM   #10309
carkillaii's Avatar
I have the rr but i want to run the 0.8 gears
should i use the gears from the fw05 or the evo
and can someone tell me the pros and cons of both
what will be better for me to run
carkillaii is offline   Reply With Quote
Old 01-16-2004, 01:38 AM   #10310
thefuzzclub's Avatar
Default foam tires for v1r
the wider rear foam tires will not fit right? so i just have to use the same size with the front foam tires?
thefuzzclub is offline   Reply With Quote
Old 01-16-2004, 01:41 AM   #10311
carkillaii's Avatar
use a 2mm offset rr rim
Old 01-16-2004, 01:53 AM   #10312
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: foam tires for v1r
make the rear track width a bit narrow and use spacer at the hex and that you may use stand zero offset wheel.
Manticore is offline   Reply With Quote
Old 01-16-2004, 01:59 AM   #10313
Default Re: Re: foam tires for v1r
well noted with thanks, i always believe there's always a way.
Old 01-16-2004, 04:34 AM   #10314
ziggy12345's Avatar
Even with the wider track set i still have to use 2mm offset on my RR.
Old 01-16-2004, 08:01 AM   #10315
Manticore's Avatar
standard RR doesnt need to use 2mm offset wheels. it has shorter dog bone and a spacer in between the hex adaptor and the outter hub bearing.
Old 01-16-2004, 02:40 PM   #10316
ziggy12345's Avatar
I got the jap cup ver so had to purchase the Wide Tyre rear adapters. Is this standard on the original RR?
Cheers
Old 01-16-2004, 05:59 PM   #10317
Manticore's Avatar
Cheers
i dunno about the jap cup version but that is what the RR foam tire version comes with.
Old 01-17-2004, 03:12 PM   #10318
ziggy12345's Avatar
I havent got a solid rear axle but wanted to try one on my car. What if I just plug the rear diff with putty. Will that work just as good?
Do i need to run a softer front to compensate?
Cheers
Old 01-17-2004, 06:01 PM   #10319
Manticore's Avatar
Cheers
some use snake cleaning putty there.
you just need to adjust your driving style. you may have more throttle time.
Old 01-17-2004, 06:56 PM   #10320
EiKuD's Avatar
can you or rather do you think it's possible to run rear rigid axle on a technical tight track.....i am running a rear rigid on a speed track and it is very very GOOD, but i have never try it on technical tight track.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
