Kyosho VoneR Thread
Originally posted by Taylor-Racing
Damn, we've got stuck with one of the old 3mm ones.
What about the chassie from 3racing? looks heavier? Is it 3 or 4 mm?
Anyone?
Anyone?
Anyone?
Anyone?
Re: Re: Pinion question.
Cilla,
If it's any help, we run 20/61 for 1st. and 25/55 for 2nd. on a medium sized twisty track - maybe similar to yours. We were also looking for a bit more low down acceleration.
Cilla,
Re: Re: Re: Pinion question.
Originally posted by Cilla
Thanks Taylor,I will take that into my consideration. At the moment I will try 20/61 for the 1st and 25/56 for the 2nd speed as suggested by Manticore. Then I will give a try on 26/56 and yours 25/55 for the 2nd speed.
My new set-up
WoW!
I?fm so happy the my new Evo. chassis. Although I have only run my machine for a short time during engine break-in, I?fm very glad with the set-up that I have. I look forward to pushing its limits, techin?f it out and racing with my new friends at the local circuit.
I hope to learn from all of you that have the incite and advice that I need and respect. Thank you. In my neck of the woods language barrier is a bit of a hold back, but I work on it.
See ya in the Forums! R.F.
Re: My new set-up
Originally posted by unbelievably
WoW!
WoW!
i just got hold of a vonerr in a trade. the guy who used to own it ran foams and pretty much had it dialled in (or so he says). i plan on running rubber (as of now) and was wondering if there's any change in the gearing that i have to do in order for it to work.
i believe the car was set-up to use foams and vds. i already have the hardware to convert it to accept tc but am not sure if there's anything else i have to do as far as pulleys are concerned. i read somewhere that the kit comes with pulleys that produce overdrive. if i use rubber tires, can i still use these or do i have to change the pulleys to make it run 1:1.
by the way, am running front diffs. any help/info will be greatly appreciated. thanks guys .
Originally posted by Manticore
3racing quality is second to GPM (from the worst) i will avoid using it unless i dont have a choice.
but honestly, they're of better than the GPM, definitely both in design and long-lasting
Originally posted by EiKuD
Don't say that lah, i felt sad u know, i have quiet a number of 3 Racing product u know....
I just ordered the Evo conversion kit from JPL racing in Singapore. This is not the Kyosho kit. Does anybody have this and whats it like? It has the 3racing chassis!
Cheers
Cheers
Cheers
Cheers
What does the JPL kit contain? . . . got a link?
Actually I thought JPL only did Martian "Off-Road" vehicles.
Originally posted by prawntoe
at least manti didn't say eagle racing or top racing better than 3racing like some of the racers I spoke with the other day . . . .
