Old 01-11-2004, 05:03 PM   #10276
But the Shimo chassis is 4mm and it is lighter than the kit chassi which is 3mm but it is dubious if the shimo chassi is more rigid.
Dexter is offline   Reply With Quote
Old 01-11-2004, 10:08 PM   #10277
Manticore's Avatar
R/C Tech Charter Subscriber
4mm shimo ?? is it newly released by kyosho?
Manticore is offline   Reply With Quote
Old 01-11-2004, 11:24 PM   #10278
so shall i get the PRO Chassis from Kawahara?
is it more expensive than the K-Factory one?
CyrilJ88 is offline   Reply With Quote
Old 01-11-2004, 11:25 PM   #10279
Manticore's Avatar
the EVO chassis from kawahara is nice and should not be more expensive then k factory.
Old 01-11-2004, 11:37 PM   #10280
mmm.
looks like I'm gonna sell off all my 3Racing hop ups,
those Kawahara's look way cooler
Old 01-11-2004, 11:39 PM   #10281
Manticore's Avatar
mmm.
yes it is !! you never need a 4mm shimo !
Old 01-11-2004, 11:54 PM   #10282
Default Pinion question.
Hi to all,
I want to change the standard 1st speed pinion which is 21T to 20T to get more pick up. So my question is do I have to bring down the 2nd speed pinion also,I mean from 26T to 25T and what about the spurs? I run a V1RR Evo in a medium size track with alot of tight corners and a long straight of about 50 metres. Thanks.
Cilla is offline   Reply With Quote
Old 01-11-2004, 11:58 PM   #10283
Manticore's Avatar
Default Re: Pinion question.
Originally posted by Cilla
Hi to all,
it is all up to your engine power, different track layout would required different gearing. i suggest you to go with 20/25 and go up one gear on the 2nd speed pinion if your engine reaches max rpm too soon on the straight.
Old 01-12-2004, 12:05 AM   #10284
What engine do u have if u have a powerful one like a Rody, JP or Nova max u could get away with a 5t split but no more than that or else the engine will bog down when shifting. I think it would be more preferable if there was a 4t split for increased shifting efficency.
Old 01-12-2004, 12:08 AM   #10285
Default Re: Re: Pinion question.
Do you mean if the engine reaches max rpm too soon on the straight then I should go with 20/26.
Old 01-12-2004, 12:10 AM   #10286
It's Nova Max.
Old 01-12-2004, 12:22 AM   #10287
Manticore's Avatar
Default Re: Re: Re: Pinion question.
yes but you also need to consider your clutch and 2speed setting. you should consider that it is a whole system.
Old 01-12-2004, 12:28 AM   #10288
Default Re: Re: Re: Re: Pinion question.
Anyway thanks Manticore,I think I'll start with the pinion first.
Old 01-12-2004, 01:57 AM   #10289
Taylor-Racing's Avatar
Hi to all,
Cilla,
If it's any help, we run 20/61 for 1st. and 25/55 for 2nd. on a medium sized twisty track - maybe similar to yours. We were also looking for a bit more low down acceleration.
Set the second gear so that the engine peaks at the end of the longest straight and then choose first gear to take care of the low speed stuff, bearing in mind you don't want a bigger split than is necessary. We run a six tooth split at another track. It's all a matter of compromise and it sounds like your going in the right direction.
Taylor-Racing is offline   Reply With Quote
Old 01-12-2004, 02:00 AM   #10290
Damn, we've got stuck with one of the old 3mm ones.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
