Old 01-08-2004, 04:42 PM   #10231
AMGRacer's Avatar
Default Re: Thanks for the link
Originally posted by B4
Thanks for the link B
Looks like I would need to replace my current 3 Racing side brace to use this sway bar, is that correct. Would be good if there was more than just a top view.
Check this out.
AMGRacer is offline   Reply With Quote
Old 01-08-2004, 04:43 PM   #10232
theRED5's Avatar
R/C Tech Charter Subscriber
Thanks, for the part nos. I'm trying to make a 200mm outlaw car out of a Reflex I have laying around.
Hey Tenderfoot57 the Reflex has a steering servo mount that is adjustable to lower the servo.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 01-08-2004, 04:56 PM   #10233
drfritz's Avatar
when you lower the servo you will be putting more bump steer into the car.
I do have a question on the k factory tank, I was reading that it would'nt work on the evo, is this because it is to wide and will hit the break- gas servo, or is the some other reason, still waiting for my kit to get in from tower, they keep putting the recieving date bake on me
drfritz is offline   Reply With Quote
Old 01-08-2004, 05:39 PM   #10234
AMGRacer's Avatar
Yes this is exactly right. The stock tank sits up hard against the steering servo, well almost within a few mm.
You know the tank is not as bad as it appears. If you look at a lot of these "low cg" cars they have a large cutout below the tanks for battery packs. This in fact raises the fuel considerably. Look at both tanks when half full (the average level in any given race) and you will find that the Kyosho tank is pretty much ok. It is only a very small bit higher in CG.
Get the battery pack and motor down low and the tank is not a very big issue.
Old 01-08-2004, 06:00 PM   #10235
Manticore's Avatar
Default Re: Re: Thanks for the link
Originally posted by AMGRacer
Check this out.
a more closer picture amg.
Manticore is offline   Reply With Quote
Old 01-08-2004, 06:01 PM   #10236
Manticore's Avatar
Default Re: Re: Re: Thanks for the link
Old 01-08-2004, 06:01 PM   #10237
Manticore's Avatar
another angle
Old 01-08-2004, 06:04 PM   #10238
Manticore's Avatar
kawahara rear shock tower for sedan body
Old 01-08-2004, 06:05 PM   #10239
tenderfoot57's Avatar
Send a message via AIM to tenderfoot57 Send a message via Yahoo to tenderfoot57
Default lower steering servo
Will I still get alot of bump steer if I keep the steering linkages at the same angle as stock. The guy at my lhs said if I change the angle of connection that I would get more bump steer but not if I keep the angle the same.
Maybe it's not that good of an idea. More hassle than gain?
Thank you for your input.
tenderfoot57 is offline   Reply With Quote
Old 01-08-2004, 06:05 PM   #10240
Manticore's Avatar
kawahara front shock tower
Old 01-08-2004, 06:07 PM   #10241
Manticore's Avatar
Default Re: lower steering servo
when you lower your servo. you need to use another servo saver with a higher steering rod position, this will offset the difference due to lower the servo. i used a snake servo saver to do the trick.
Old 01-08-2004, 06:17 PM   #10242
B4
B4's Avatar
another angle
Thanks to all those that posted pics of the sway bar,
It does raise another question.
1) Does the sway bar come with all the hardware i.e. the right side brace.
Also it would appear that the five stars left side brace will not fit. Are you happy with no brace on that side.
B4 is offline   Reply With Quote
Old 01-08-2004, 06:18 PM   #10243
Manticore's Avatar
it comes with all the hardware that you need to put the sway bar on your car. i am very happy with the rear sway bar set even i cannot put on my "charge" left side stiffiner.
Old 01-08-2004, 06:19 PM   #10244
AMGRacer's Avatar
Yes you will alter the bump steer as manticore has mentioned. It is almost impossible to keep the stock angle after loweringas there is insufficient room.
I lowered mine a heap and just reversed the ballstuds to the top of the saver and it always seemed to work nicely.
Old 01-08-2004, 07:04 PM   #10245
Diva's Avatar
Send a message via Yahoo to Diva
Just cleaned all the bearings and rebuilt the shocks and everything. My Evo is hungry again. Manti, don't forget the food.
BTW, I'm still for the Charge rear sway bar over Kawa. It's scary for missing the left brace.
The G4 belts are way too ugly.
Ah, I need a strong pipe too. But I won't raise the dump question on the choice to go.
Diva is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
