Old 01-05-2004, 02:05 PM   #10171
Data's Avatar
Originally posted by Kenshin
Can you use the RR one-ways with the Evo? I will be getting my conversion kit in the mail soon and I just want to make sure. Thanks.
unfortunately no, battousai. the front of the evo is narrower than the rr.
Data is offline   Reply With Quote
Old 01-05-2004, 02:31 PM   #10172
Kenshin's Avatar
Thanks Data, I was hoping I can use the one in my RR.
Kenshin is offline   Reply With Quote
Old 01-05-2004, 03:33 PM   #10173
AMGRacer's Avatar
Originally posted by Taylor-Racing
I'm all for getting the weight down low but have been concerned with the header contacting the side belt, so haven't done anything - we want to use the full overdrive 25T pulley and really don't like to crank down on the tensioner too much.
How high are the Mugen engine mounts?
What's the diameter of the FW-05 flywheel? - the FW-05 uses the same 3D clutch, otherwise, yeah?
It seems to me we actually need a longer side belt - maybe a job for Course-R.
Thoughts?
I would not worry about the belt rubbing. Mine rubbed for over 1 year without failure. With the 25T pulley the rubbing is even less.
The stock V1RR mounts are 17mm (I think) the kawahara V1RR mounts are 14mm (and they cause rubbing on the 27T pulley) and the Mugen mounts are 13.5mm (approx).
The FW05R clutch is identical except for a 33mm flywheel (which is required for the lower mounts). I would not recomend getting the Mugen mounts unless you feel like cutting the chassis as the bell rubs. Note that the 5 star lightened bell does NOT rub as it appears to be marginally smaller.
You will really notice a difference in these mods. The throttle response on the 5 star bell is quite stunning if you use the lightened 3 racing flywheel as well. I actually thought that the motor was faulty initially as it just sounded "off". You will notice a rear grip increase as well as you are lowering the engine 18% and shaving nearly 30% off the rotating mass of the clutch assembly.
AMGRacer is offline   Reply With Quote
Old 01-05-2004, 03:36 PM   #10174
AMGRacer's Avatar
Well I just repeated everything that people have already said Anyway...............
Old 01-05-2004, 03:42 PM   #10175
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
This all sounds really great. I will give it a try by scavanging the flywheel from my Fw-05R and the optional engine mounts I got for it.
Racing4Evo is offline   Reply With Quote
Old 01-06-2004, 02:39 AM   #10176
apmk's Avatar
Originally posted by Manticore
5 stars bell 2
Hi Manticore, do you know if this 5 star clutch bell will fit into the
Mugen centax clutch?
apmk is offline   Reply With Quote
Old 01-06-2004, 02:48 AM   #10177
Manticore's Avatar
R/C Tech Charter Subscriber
the bell is actually for mugen but it does work on kyosho clutch !
Manticore is offline   Reply With Quote
Old 01-06-2004, 02:56 AM   #10178
apmk's Avatar
Thanks I gonna get one soon, Bye
Old 01-06-2004, 02:57 AM   #10179
Manticore's Avatar
which clutch you are going to use the bell on?
Old 01-06-2004, 03:06 AM   #10180
No, the one way at RR cannot be used at Evo. However, the conversion kit includes a new one way.
utopian is offline   Reply With Quote
Old 01-06-2004, 03:32 AM   #10181
Taylor-Racing's Avatar
. . yes.
I nearly answered one from two pages back myself.
Thanks for the info. AMG, dtm and Manti - sounds good.
I guess I'll start with the FW-05R mounts and go from there.
Taylor-Racing is offline   Reply With Quote
Old 01-06-2004, 03:33 AM   #10182
Manticore's Avatar
. . yes.
you sure you dont mind the belt polishing your header ?
Old 01-06-2004, 04:06 AM   #10183
Well I do, but everyone seems to think it's OK.
What about this then:
Move the mid block back 1mm - I reckon there's enough slop in the front belt to do it and it might kill two birds with one stone.
Old 01-06-2004, 04:08 AM   #10184
Manticore's Avatar
I doublt how you can do that unless you re-engineer the chassis.........
that is gonna give and take. accept the rubbing fact !
Old 01-06-2004, 04:40 AM   #10185
No no - re-engineer the mid block.
. . . or talk to Corse-R about a 376 side belt.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
