Old 12-21-2003, 01:43 AM   #10021
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Re: Re: Notice
Originally posted by Taylor-Racing
More speculating from me, of course - but how about this:
The ultra direct feel you describe may indicate better chassis rigidity which then affects your set-up negatively.
What if you took steps to accomodate the stiffer chassis - would you be further in front overall?
Part of what's going through my mind here is our last practice day.
We ran a light 2mm rear bar and the rear was probably better planted than I've previously seen. We were also running on the silliest small front tyres (52mm) and the roadholding didn't seem to suffer at all.
i would say if you run on rubber tire, a less stiff chassis is preferred but on foam tire, a more rigid chassis is more on what you need/
Manticore is offline   Reply With Quote
Old 12-21-2003, 07:19 AM   #10022
ziggy12345's Avatar
I just fitted my one way and find that smaller tyres at the front gives the better handeling, difference of 2mm.
Problem is i end up with larger tyres at the front than the rear as the rears wear quicker.
I wanted to fit a different pully on the middle belt to give the same effect but which one do i change? I have 18-27 at the moment.
The K factory sells a 19 teeth but this will have the opposite effect of what I want I can also get a 26 tooth one but this also speeds up the fron wheels.
Am i missing something?
Cheers
ziggy12345 is offline   Reply With Quote
Old 12-21-2003, 07:39 AM   #10023
Manticore's Avatar
Cheers
you should have 19/27 instead of 18/27 check your other pulley and see if you have mis install them.
you may change from 19/27 to 19/25 and with kyosho SP belt with length 375mm. you may be able to do it with larger tire split (4mm).
for the 25T pulley, kyosho has a pulley set for VoneRR and you may get all the pulley you want there.
Old 12-21-2003, 07:42 AM   #10024
Manticore's Avatar
download the overdrive ratio tool here to check on your OD ratio and tire split
Old 12-21-2003, 08:28 AM   #10025
ziggy12345's Avatar
Nice little app to see the drive ratio! Whats the teeth on the diff pulleys for the v1rr?
Cheers
Old 12-21-2003, 08:42 AM   #10026
Manticore's Avatar
Cheers
The front should be 32 and rear 48
Old 12-21-2003, 08:51 AM   #10027
Manticore's Avatar
Cheers
it is not my app. it is Dino's appl.
Old 12-21-2003, 08:58 AM   #10028
ziggy12345's Avatar
Ok i counted them. 32 at the front and 48 at the rear. So with 18-27 pulleys installed you get 1-1 internal drive ratio front to rear.
This will allow me to use only a 1mm smaller front tyre
The way I see it is that if your running foam tyres and a front one way you get power on to the rear wheels along the straight, effectively 2 wheel drive then as you turn the inner front wheel is rotating slower than the outer front wheel and so the power is applied to this and helps pull you around the corner.
This sound OK but why would you want overdrive to the front wheels when running rubber tyres? My car handles like a pig with front overdrive on foams!!
Old 12-21-2003, 09:05 AM   #10029
Manticore's Avatar
you cannot trim rubber tire size so you better stick with 27T pulley.
Old 12-21-2003, 09:07 AM   #10030
ziggy12345's Avatar
I am using foams
Old 12-21-2003, 09:11 AM   #10031
ziggy12345's Avatar
Tell Dino that Plley is spelt Pulley!! LOL
Old 12-21-2003, 09:14 AM   #10032
Manticore's Avatar
you should send him a complaint, you are his potential customer ! hahaha
Old 12-21-2003, 10:11 AM   #10033
ziggy12345's Avatar
Do i have to change the middle belt if I go from 19 to 18 tooth pulley? Can i use the Kfactory one K1404 Low Friction Belt
Cheers
Old 12-21-2003, 10:17 AM   #10034
Nitro Tech
dino.tw's Avatar
Ooooopppppsssss....
thanks.....
dino.tw is offline   Reply With Quote
Old 12-22-2003, 01:46 AM   #10035
Taylor-Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Notice
Why would you say this?
I'd be thinking a "bendy" chassis would essentially act as part of the suspension and therefore be unpredictable.
Taylor-Racing is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
