Old 12-15-2003, 07:42 PM   #9976
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by esham
your beer hasnt shown up right !
Manticore is offline   Reply With Quote
Old 12-15-2003, 09:15 PM   #9977
AMGRacer's Avatar
New Kyosho rear swaybar.
So called "hard type".
AMGRacer is offline   Reply With Quote
Old 12-15-2003, 10:11 PM   #9978
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Why you use this kind of sway bar instead of the orginal RR sway bar. Is it more effective?
I like the option of having more than 3 adjustments, when I used the original sway bar set up
HEYALIGNMENTGUY is offline   Reply With Quote
Old 12-15-2003, 10:12 PM   #9979
Manticore's Avatar
you dont need that any more !
Old 12-16-2003, 12:15 AM   #9980
finchy's Avatar
Just curiously would like to know if anybody has tried the new Kawahara shock towers for the EVO. ( there is a front and rear tower). I was just wondering if you had to use the old R rear end stuff or does these item allow you to use the RR rear end ( not the floating bits, but sway bars) . Any info would be appreicated.
finchy is offline   Reply With Quote
Old 12-16-2003, 12:28 AM   #9981
Manticore's Avatar
i have both kawahara shock towers (F&R)
you need to use the R rear cover and you need to use the R rear sway bar set unless you get the kawahara rear blade type sway bar set.
the best part of the shock towers is that it allows you to make half hole adjustment on shock position.
Old 12-16-2003, 12:39 AM   #9982
finchy's Avatar
Thanks for the info manticore, how's the EVO going anyway. Do you prefer the EVO or the MTX3 now days.
Old 12-16-2003, 12:41 AM   #9983
Manticore's Avatar
they are different. both are very good cars and i do like them without any preference over the other !!
Old 12-16-2003, 05:03 AM   #9984
AMGRacer's Avatar
Finchy good to hear from you! Hope all is going well with you. I have the Kawahara rear tower which I hope to test soon. I am currently testing the Kyosho alloy rear shock tower, the R style one.
Also I am testing the kawahara rear swaybars, but I think you might need one of these for Brendale. Or at least the new "hard style" swaybar from Kyosho.
Also you really should get the G4 belts, these things are kick ass.
Lastly I bought the 26T side pulley recently and it came with some interesting setup advice:
27T pulley = mild initial steering with better high speed cornering
26T pulley = medium effect
25T pulley = good initial steering with better low speed corner response.
So I guess you should go with the 27T at Brendale.
Old 12-16-2003, 09:48 AM   #9985
InitialD's Avatar
AMGRacer, are your tests base on using same front and rear tire diameters or are you using the necessary split when using 26T and 25T pulleys for 1:1 overdrive?
Old 12-16-2003, 10:09 AM   #9986
Taylor-Racing's Avatar
Bugger - I thought the G4 side belt was for the 25T pulley.
I really like the 25T front pulley since trying it on the "R". The more even tyre wear helps maintain some consistancy of handling.
I'm needing to consider Lilydale and imagine that Brendale is much more flowing. While Lilydale is large (long straight) it still has a fair bit of twisty stuff.
We ran the front tyres down to 52mm at Lilydale last Sunday and the car was handling great.
The engine was tragic, however.
Where did the 26T come from?
Taylor-Racing is offline   Reply With Quote
Old 12-16-2003, 03:01 PM   #9987
AMGRacer's Avatar
These are not my test results, it is the advice from the instruction sheet that came with the 26T pulley from Kyosho.
The advice assumes that you have the tire split correct. Ie. 0, 2mm or 4.5mm as appropriate.
Old 12-16-2003, 03:05 PM   #9988
AMGRacer's Avatar
The 26T is a Kyosho "Team" part, only available in alloy.
I was actually quite surprised with the advice that came with the pulley which is why I thought I would share it.
You could possibly get the G4 belts in a smaller side belt size (Manticore can you confirm this?)
Old 12-16-2003, 06:04 PM   #9989
Manticore's Avatar
the problem with copy master is that he is corrupted with stupidity. other then that, he is just a simple calculator.
Old 12-16-2003, 06:24 PM   #9990
mckrooz's Avatar
Send a message via AIM to mckrooz
Default V-One R 2-speed tranny
Looking for a V-One R 2 speed tranny. So if anyone has done the Evo conversion and has this 2 speed laying around, help a brotha out! Has to be complete. Throw me an offer.
mckrooz is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
