Old 12-09-2003, 04:54 AM   #9931
sparksy's Avatar
Trader Rating: 14 (94%+)
Originally posted by Taylor-Racing
I gotta ask . . . . how did you bend it.
Its quite easy to bent them... actually.. it was the middle shaft I bent.... dont know how... think it had something to do with the dadgy 6000 series ally I made it out of... got my hands on some 7075 and never had a problem... actually still think I have some still kicking about in my pit box...
sparksy is offline   Reply With Quote
Old 12-09-2003, 05:02 AM   #9932
Thumbs up Re: Question to Manticore
Manticore,
Thanks for the info, I am using 1.0 gears, would a change to 0.8
Evo spec spur gears help? As I can get these, but not the clutch gears.
Kin'ell
Kin'ell is offline   Reply With Quote
Old 12-09-2003, 07:57 PM   #9933
Manticore's Avatar
R/C Tech Charter Subscriber
kyosho has released carbon composite arms for EVO.
part number
front arms (upper and lower) VZ101H
rear amrs VZ004H
Manticore is offline   Reply With Quote
Old 12-09-2003, 09:52 PM   #9934
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
part number
rear amrs VZ004H
A nice pair of front universals would be nice.
How about a metal roll bar, if there isnt one out there
HEYALIGNMENTGUY is offline   Reply With Quote
Old 12-09-2003, 10:01 PM   #9935
Manticore's Avatar
kyosho has also released the uni I will try to post it later but it is at kyosho web site anyway
Old 12-09-2003, 10:25 PM   #9936
Send a message via ICQ to noobatron
i have no idea! initially i thought it was the spur gears not on preperly and after proper inspection (rolling it on a flat surface) i found that it wa bent... ever so slightly though.
I havn't been in any stacks though, so i'm just as curious as you! aside from that, everything else is ok. Oh btw, what do you think about a SIRIO .12 outlaw? was reading up on it... pretty neat stuff hehehe
noobatron is offline   Reply With Quote
Old 12-10-2003, 03:46 AM   #9937
AMGRacer's Avatar
Default Re: Re: Re: CONRODS?
Originally posted by noobatron
Turn your engine over by hand... When my engine was at it's prime running stage it was very hard to turn over but now, it feels alot easier...
I don't have the engine compression gauage but just by feeling it while turning the engine over will give you an indication of the compression.
BTW, found the culprit... a bit 2spd shaft >_< just slightly, but enough to cause binding. thnx for the help guys, i only discovered it while looking for a stone in the brake pulley like you guys suggested
Actually that is how NOT to check for compression man That is why I asked. You need to check compression hot and with some lube in the engine. Check how long it holds compression at TDC.
AMGRacer is offline   Reply With Quote
Old 12-10-2003, 04:44 AM   #9938
Default Re: Re: Re: Re: CONRODS?
OH heheh... is it the same when i do it while engine is hot? cuz that's when i check
i'm looking for a compression gauge atm...
Old 12-10-2003, 05:39 AM   #9939
Taylor-Racing's Avatar
Default Re: Re: Question to Manticore
Originally posted by Kin'ell
Manticore,
Kin'ell
The 0.8M gears are supposed to be more efficient.
You will need to use Kyosho 0.8M pinions with 0.8M spurs.
Taylor-Racing is offline   Reply With Quote
Old 12-10-2003, 09:18 AM   #9940
I have a really stupid question..... I am getting this car soon.... and I have noticed that parts are kinda hard to get. I know tower has them, but most of them are out of stock. Is there any overseas shops that carries all the parts for the EVO kit?
Will the Rear Suspension Arms from the V-one RR fir the EVO kit?
FirstLoser is offline   Reply With Quote
Old 12-10-2003, 09:19 AM   #9941
Manticore's Avatar
Yes !
Old 12-10-2003, 08:07 PM   #9942
AMG I got your package
Old 12-10-2003, 08:15 PM   #9943
Another
Old 12-10-2003, 08:17 PM   #9944
I spent way too much time cleaning her I need to show off A
Old 12-10-2003, 08:29 PM   #9945
Manticore's Avatar
Thumbs up
very nice car and clean.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
