Old 12-07-2003, 07:03 AM   #9916
Send a message via ICQ to noobatron
Default Re: Re: CONRODS?
Originally posted by Taylor-Racing
The binding could be nearly anything - as Manti says, maybe the bearing in the bulkhead. You need to test each part of the drive train separately - removing belts would be a good start.
. . . but I'm going to guess that the grub screws in the two-speed are screwed too far in.
If your engine has run out of compression - join the club!
Yes the NS-5 stuff will fit, but it's likely uneconomical.
thnx for that guys!~ i've checked each part individiually and have narrowed it down to the rear. checked the grub screws (they're fine. thnx taylor ) it's not really binding now... something close though... it rolls freely until a certain point in the revolution, it binds abit... and then it's fine... it always binds there though =( i've checked and changed the bearing inside the rear axials. wheels arn't warped... maybe diff? checked to see for leaks but no leaks..
oh btw taylor, uneconomical as in better off buying a new one? From RC-Mushroom, you can get the NS5 P/S/C and crank for $92USD... which equates to about $160AUS shipped... what do you think? or am i better off buying a new engine? I'm hunting another OFNA 7 port .12 still crying over my loss
keep you guys posted =)
noobatron is offline   Reply With Quote
Old 12-07-2003, 09:37 AM   #9917
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: Re: Re: CONRODS?
Brake disc on the pins?????
dtm is offline   Reply With Quote
Old 12-07-2003, 06:08 PM   #9918
sparksy's Avatar
Trader Rating: 14 (94%+)
10 bucks its a small pebble in the rear diff pully, or the pully on the 2spd shaft. Or a build up of grime on same.
sparksy is offline   Reply With Quote
Old 12-07-2003, 06:23 PM   #9919
drfritz's Avatar
Or................................................ ...... the diff has gone bad, ak broken bevel gear..... your problems sounds like the same one I had this summer and it turned out to be the gears in the diff had given up the ghost. pull the diff out and tun it by hand and see if you have any spots that feel to tight.
drfritz is offline   Reply With Quote
Old 12-07-2003, 07:22 PM   #9920
Question.....
Where is a good place to get spare parts for the EVO car? I have noticed that Tower has some of them, but most of them are backordered until Late Jan.
FirstLoser is offline   Reply With Quote
Old 12-07-2003, 09:18 PM   #9921
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Originally posted by FirstLoser
Question.....
That is the only major supplier here in the states, most of the RR parts do fit since most of the change was done in the front
HEYALIGNMENTGUY is offline   Reply With Quote
Old 12-07-2003, 10:00 PM   #9922
FirstLoser: Please contact us.
JustRC
justrc is offline   Reply With Quote
Old 12-07-2003, 10:16 PM   #9923
JustRC
Ooooop's my bad
Old 12-08-2003, 03:37 AM   #9924
Taylor-Racing's Avatar
<SNIP>
I'm with sparksy - a rock in a pulley.
The NS5 P/S/C is US$100 at RC-Mushroom.
The NS5 crank doesn't seem to be listed but I would expect roughly US$60.
Add a couple of bearings and it may be worth it, I guess.
Taylor-Racing is offline   Reply With Quote
Old 12-08-2003, 09:29 AM   #9925
Question to Manticore
Manticore
I have read on some old post that you have fitted a MTX Centax clutch to your v1, I am doing the same mod now using Mugen 1st & 2nd {19T,16T on order} for more low end. Did you use Kyosho or Mugen gears?
As I have been told Mugen will not work! I did look for your pics but could not find them.
Any other info would be appreciated.
Kin'ell
Kin'ell is offline   Reply With Quote
Old 12-08-2003, 09:36 AM   #9926
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Question to Manticore
Originally posted by Kin'ell
Manticore
Kin'ell
I use kyosho pinions on the mugen clutch. I am talking about 1.0 module which is what you are referring to. the mugen pinions are of smaller diameter and you will have gear mess problem on the kyosho car.
Manticore is offline   Reply With Quote
Old 12-09-2003, 12:02 AM   #9927
AMGRacer's Avatar
Default Re: CONRODS?
BTW, my novarossi NS3 engine is running outta compression (i got canned by an OFNA picco 7 port .12 Turbo... that thing just hammers!!!!!!!!!) Was wondering if i would be able to replace my internals with NS5 internals (conrod, P/S Crank)?
Any advice is appreciated.
thnx guys
Just a quick question. How do you know it is running out of compression?
AMGRacer is offline   Reply With Quote
Old 12-09-2003, 04:42 AM   #9928
Turn your engine over by hand... When my engine was at it's prime running stage it was very hard to turn over but now, it feels alot easier...
I don't have the engine compression gauage but just by feeling it while turning the engine over will give you an indication of the compression.
BTW, found the culprit... a bit 2spd shaft >_< just slightly, but enough to cause binding. thnx for the help guys, i only discovered it while looking for a stone in the brake pulley like you guys suggested
Old 12-09-2003, 04:43 AM   #9929
[QUOTE]Originally posted by noobatron
[B]
BTW, found the culprit... a bit 2spd [B][QUOTE]
ops i meant BENT
Old 12-09-2003, 04:50 AM   #9930
I gotta ask . . . . how did you bend it.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
