Old 12-23-2001, 11:43 AM   #976
Regional Moderator
disaster999's Avatar
Originally posted by dtm
Manticore- You have another fan!!
got-speed- gear the car as high as humanly possible and watch out on the time you spend on full throttle... you don't want to keep your finger jammed down for more than 3-4 seconds otherwise you may over rev your engine on that size of a track!
but i thought if you lower the ratio of the car, it takes the engine more effort to rev up due to its low ratio..which give the car more top speed up lower acceleration...you could full throttle for more then 5-6 secs or even longer cuz it takes the engine more time to reach its max speed!
i read this somewhere...dunno if its right!
disaster999 is offline   Reply With Quote
Old 12-23-2001, 11:49 AM   #977
dtm
dtm's Avatar
Send a message via ICQ to dtm
Oops... brain in gear.... you are correct 999 gear it as LOW as humanly possible!!
As for the 3-4 sec limit that should be 3-4 secs with engine 'screaming'! It's 2:50 AM getting late!!!!!
dtm is offline   Reply With Quote
Old 12-23-2001, 05:38 PM   #978
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by got_speed?
Hey Manticore....(or anyone) I have read some of your posts all over this board and I can tell that you have the "wisdom" . A new purpose built track just opened close to my house. Can you tell me, (i know this could be hard) bassed on the pictures attached what kind of setup i should have? Mainly in gearing and front and rear differential selections.
This track is HUGE!!! They run 1/5 on this track.
Thanks in advance.
http://www.tecnago.com/pixs/new1.JPG
http://www.tecnago.com/pixs/SVMS3.jpg
http://www.tecnago.com/pixs/tracksketch.jpg
What tire are you going to run on this track?
If you run on rubber tire, you might like to just stick with the stock setting but you need to reduce camber to rear/1'-1.5' and front/0'-0.5'
use lower gear ratio as compare with the stock box pinion. start with 17/21 and go down on the gear ratio if you think you dont have the speed on the straight. as for clutch, you might just stick with the stock clutch for a while but you need to change to a bit harder spring. Kyosho made a harder spring which is color in blue. rather then that, stay with the box setting overall.
One thing about building the shocks, there is another tree with two spring bottom retainer which is in dark blue color and it is flatter which allow the long spring seat lower in the rear. I see a lot of people miss that part but use the retainer which comes with the shock parts tree.
Hope this help
Manticore is offline   Reply With Quote
Old 12-23-2001, 05:44 PM   #979
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Thanks in advance.
Got_speed, I was wondering where is this track? is it in Socal or somewhere else??
Ah10 is offline   Reply With Quote
Old 12-23-2001, 05:50 PM   #980
got_speed?'s Avatar
Thanks Manticore....I'll try that setup....do you have the Kyosho part# for the Kyosho LSD....is it the same LSD from the Kanai Inferno?
Ah10, yes the track is in SoCalifornia. In Sun Valley to be specific.
got_speed? is offline   Reply With Quote
Old 12-23-2001, 05:53 PM   #981
Manticore's Avatar
just stick with the stock rear diff. some people (including me) has toasted the LSD big bevel gear. It just cracked in the middle. I suggest you to wait for the kawahara negative diff.
Old 12-23-2001, 07:10 PM   #982
Regional Moderator
The track is called SVM Speedway and locate near Burbank airport.
White cat is offline   Reply With Quote
Old 12-23-2001, 08:05 PM   #983
Ah10's Avatar
do you have a address or website? I would like to go!
Old 12-23-2001, 08:29 PM   #984
Regional Moderator
Their website is www.svmspeedway.com
Old 12-23-2001, 10:47 PM   #985
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Manticore.........can you give W Fok directions to the Hobby shops there in HK kind of hard knowing where you are going sitting in a chair in Claifornia
I have special interest in his vacation over there next month
HEYALIGNMENTGUY is offline   Reply With Quote
Old 12-23-2001, 10:48 PM   #986
Merry Christmas ALL
Old 12-24-2001, 12:29 PM   #987
got_speed?'s Avatar
Yes WhiteCat, about 5 min from Burbank Airport....
Old 12-24-2001, 05:09 PM   #988
Manticore's Avatar
Merry christmas folks !
HAM: sure !!!!
Old 12-24-2001, 07:26 PM   #989
Regional Moderator
Merry Christmas to all V1R owners!!!
I wish we will kick more butts with our V1R.
Old 12-24-2001, 09:22 PM   #990
FACTION95Si's Avatar
Send a message via ICQ to FACTION95Si Send a message via AIM to FACTION95Si
Default Hop Ups!
Merry X mas everyone!
Santa is going to bring me some hop ups for my V-One R
FACTION95Si is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
