Old 12-21-2001, 03:09 PM   #961
cornerspeed's Avatar
Thanks AMGRacer- Now I have some ideas to start with.
How are the limited slip diffs working out? Kawahra or Kyosho, which one is better? Are they for rubber or foam tire use, or both.
cornerspeed is offline   Reply With Quote
Old 12-21-2001, 04:38 PM   #962
SpeedTech's Avatar
Hi guys,
We just updated our website with a ton of new hop-ups from Kawahara for the V1R. We also have more hop-ups coming end of next week including the V1R Negative diff. Check them out on our website, they are going really fast!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
909-869-9443
SpeedTech is offline   Reply With Quote
Old 12-22-2001, 08:01 PM   #963
sparksy's Avatar
Trader Rating: 14 (94%+)
Had a wierd thing happen.....The circlip that holds the clutch shoes back on the standard clutch came out a little and was binding the clutch bell.... anyone else have this happen?
sparksy is offline   Reply With Quote
Old 12-22-2001, 08:07 PM   #964
got_speed?'s Avatar
I had my pilot shaft come loose a bit. It was enough to lock-up the clutch bell. This was during my test runs, I have since used blue loctite....
got_speed? is offline   Reply With Quote
Old 12-22-2001, 08:19 PM   #965
Manticore's Avatar
R/C Tech Charter Subscriber
use two wisegrips to do the job. one holding the flywheel and another one hold the driver that for the clutch nut. use excessive force to fix the clutch nut.
Manticore is offline   Reply With Quote
Old 12-22-2001, 08:39 PM   #966
got_speed?'s Avatar
Thanks for the advise Manticore..
What do you guys think of the Kawahara lower engine mounts in conjunction with the smaller diameter flywheel? According to them this would lower the engine 2.5mm. Would that make a big difference in handling??
Old 12-22-2001, 08:57 PM   #967
Manticore's Avatar
its not only lower the engine, this will reduce flywheel weight and thus reduce rotation mass and you will have better throttle respond.
I am using this combo on my V1R but with a mugen centax.
Old 12-22-2001, 09:46 PM   #968
got_speed?'s Avatar
I think I'll do the same thing....was that mugen clutch a direct replacement?? Did you have to modify anything?
Old 12-22-2001, 10:22 PM   #969
Manticore's Avatar
there are a few things you need to go:
1/. make clearance for the clutch bell on the main chassis. just dremal to file on the area underneath the clutch bell to ensure the clutch bell spin freely. (you need to do this with kyosho clutch as well)
2/. you need to use kyosho clutch pinion especially the 2nd pinion as the diameter for the mugen pinion (2nd gear) is smaller.
3/. file the main chassis engine mount hole a bit longer to the left to ensure maximum spur/pinion coverage. AMG has it without making mod on the main chassis. may be I am using option chassis.
Old 12-23-2001, 12:50 AM   #970
got_speed?'s Avatar
Thanks for the information....I have to wait for all the Kawahara hopups I ordered I hate to tear the car apart over and over...Now all I have to do is look for who sells the Mugen Axial Clutch the least $$.
Old 12-23-2001, 01:15 AM   #971
AMGRacer's Avatar
Yep, it fits OK just a few notes. Like Manticore said the Mugen pinion 20-21-22 tooth 2nd gears actually are different in diameter by quite a bit whereas the Kyosho pinions gears are exactly the same size (or at least very close). You have to pay attention to gear mesh more.
Also I did not initally file the chassis holes to get the coverage, but what I did find that by not doing this my clutchbell was actually rubbing on the outside of the 2nd gear. So you actually do have to file the chassis about 1-2mm to make better clearance for the clutchbell - 2nd gear. It does not do any major damage to 2d gear it just wears a slight groove into it.
The Kyosho centax off the RR may be a better buy if the price is good as it presumably will fit with no mods, only has 3 flyweights for better response, and they are lightened.
AMGRacer is offline   Reply With Quote
Old 12-23-2001, 01:35 AM   #972
got_speed?'s Avatar
Thanks AMG....I am tired of seeing references to the V1RR.(i'm presuming it is not yet avail in US.)...where can I get this car?? Or beter yet, do you guys know the part# of the Kyosho LSD and that Kyosho Centax for the V1R??
Old 12-23-2001, 10:04 AM   #973
got_speed?'s Avatar
Hey Manticore....(or anyone) I have read some of your posts all over this board and I can tell that you have the "wisdom" . A new purpose built track just opened close to my house. Can you tell me, (i know this could be hard) bassed on the pictures attached what kind of setup i should have? Mainly in gearing and front and rear differential selections.
This track is HUGE!!! They run 1/5 on this track.
Thanks in advance.
http://www.tecnago.com/pixs/new1.JPG
http://www.tecnago.com/pixs/SVMS3.jpg
http://www.tecnago.com/pixs/tracksketch.jpg
Old 12-23-2001, 11:31 AM   #974
dtm
dtm's Avatar
Send a message via ICQ to dtm
OMG... that track looks big enough to run Go karts!!!! Shame we can't have something like that in Hong Kong!
dtm is offline   Reply With Quote
Old 12-23-2001, 11:36 AM   #975
dtm
dtm's Avatar
Manticore- You have another fan!!
got-speed- gear the car as high as humanly possible and watch out on the time you spend on full throttle... you don't want to keep your finger jammed down for more than 3-4 seconds otherwise you may over rev your engine on that size of a track!
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
