Old 10-30-2003, 09:18 PM   #9616
AMGRacer's Avatar
Default Re: Re: Re: Re: Re: Need setup help
Originally posted by KingWillie
Off throtle entry into fast corners, I know chances are could be me more than the car.
Almost certainly will be one of:
- Swaybar in front needs to be stiffer. If too soft the car dumps over when turning in sharp and you spin.
- Too much or too little caster. Likely too much. Too much makes front bite too hard when turning in.
- It may be rear diff related.
Like manti suggested please list out your whole setup.
AMGRacer is offline   Reply With Quote
Old 10-30-2003, 10:01 PM   #9617
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Originally posted by AMGRacer
I do not know of any tires with the correct offset. You will need around 3mm offset. You can get some clamp on 2mm offset hubs which make it work.
Nitro shoes offer a 2mm off set as well as the normal 0 off set
HEYALIGNMENTGUY is offline   Reply With Quote
Old 10-30-2003, 10:26 PM   #9618
EVOLUTION's Avatar
Default Re: Re: Re: Re: Re: Re: Need setup help
Originally posted by Manticore
can you tell us your "EVO" setting ! I think you are driving a EVO! not snake? right?
Maybe it's a hybrid !
EVOLUTION is offline   Reply With Quote
Old 10-31-2003, 12:52 AM   #9619
FAST tires for the Mugen MTX3 are 2mm offset.
Bob The Builder is offline   Reply With Quote
Old 10-31-2003, 12:57 AM   #9620
Data's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Need setup help
beauty of the internet age, even if you can't walk like a pro, you can still talk like one.
i guess all the cars are the same when you are a pro
Data is offline   Reply With Quote
Old 10-31-2003, 01:29 AM   #9621
EVOLUTION's Avatar
Data you the man,now get back to work !!!
Old 10-31-2003, 05:16 AM   #9622
AMGRacer
Look on www.kyosho.co.jp The manual is there and the exploded diagram.
Just as required - Thanks
Can you point me to a US distributor who will ship to the UK.
The RR and the EVO are not available here in the UK so no one keeps the bits.
Old 10-31-2003, 07:10 PM   #9623
I'll post it Sunday night after the race. I'm going to try a little heavier oil and a little more sway bar up front. I am running the Kawahara neg diff as I did in the RR.
KingWillie is offline   Reply With Quote
Old 11-01-2003, 12:41 AM   #9624
B
does anyone know what are the parts needed to build the front gear diff? (gears, joints, etc..) and part #'s would definitely be helpful as well
Thanks a lot
B is offline   Reply With Quote
Old 11-01-2003, 12:54 AM   #9625
Bounty Hunter's Avatar
Originally posted by Bob The Builder
AMGRacer
You can try either of these sites:
www.catalog.rcmodel.com.hk
www.towerhobbies.com
Both have availabilty on EVO parts
Bounty Hunter is offline   Reply With Quote
Old 11-01-2003, 12:55 AM   #9626
oops make that:
Old 11-01-2003, 01:31 AM   #9627
Taylor-Racing's Avatar
Thanks a lot
I presume this is for an EVO and that you have the case.
BS107 Beval Shaft
VZ012 Differential Gear Set
VZ021 Differential Packing
VZ118 Differential Shaft Set
Taylor-Racing is offline   Reply With Quote
Old 11-01-2003, 01:44 AM   #9628
B
Thanks very much
Old 11-01-2003, 06:24 AM   #9629
apmk's Avatar
Default Negative diff
hi dose anyone knows whats a egative diff, whats good about it?
apmk is offline   Reply With Quote
Old 11-01-2003, 08:16 AM   #9630
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: Negative diff
Acts as regular differential during slow speed, i.e. cornering.
The Clutch-shoe in adjacent housing will lockup when accelerates and reaches certains speed; hence, acts as a solid axle. All the power is gained to the rear wheels; thus, it enable the car to go faster.
eddiethefish is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
