Old 10-29-2003, 04:26 AM   #9601
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Battery pack for Evo
Originally posted by Hank
What battery pack is every one using in their evo's?
I tried to put in my hump pack from my RR and it hits the tank and bends back the battery holder/radio support and you cant screw down the radio tray!!! Please help me cos i want to drive my car this weekend.
Hank
5xAAA 700 mah nimh cells
Manticore is offline   Reply With Quote
Old 10-29-2003, 04:34 AM   #9602
Hey Mr Manticore
How do they fit in the car? i thought you have to use 1/2 AA to make a hump pack. Do you have a pic of the battery pack so i can make one up.
thanks
Hank
Hank is offline   Reply With Quote
Old 10-29-2003, 08:40 AM   #9603
Wolf's Avatar
Send a message via ICQ to Wolf
It's also a hump pack. To mount it, you need to rotate it 90 degree (top view).
Wolf is offline   Reply With Quote
Old 10-29-2003, 11:36 PM   #9604
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
Hi all, i have a qestion here any help will be appreciated i would like to run the 30mm rear tires, do i need to order the ones with off set in order to get 200mm width ? i have tried with my mugen's 30mm and it does not seen to fit right. thanks
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 10-29-2003, 11:43 PM   #9605
me43's Avatar
i belive you have to put spacers behind then axle pins
me43 is offline   Reply With Quote
Old 10-30-2003, 08:38 AM   #9606
Can anyone tell me the part numbers for the floating rear body mount parts on the EVO.
I need the top arms, links, pins, rear slider bracket, body support and screws.
An electronic copy of the manual will do and I will take the numbers out of it.
Bob The Builder is offline   Reply With Quote
Old 10-30-2003, 05:34 PM   #9607
Default Re: Re: Need setup help
Originally posted by AMGRacer
Well first up slippery and high speed sweeper usually dont mix that well. There is only so much speed you can carry on a low grip circuit. However if others are faster than you through this part of the track then you know you can make it better
On a low grip track first and foremost get the tires right. I cant help you here, but get the good tires from local racers. Also make sure they are even, not chunked and for low grip tracks not too small.
Next thing is the body. You MUST use the right body. For high speed stability the Stratus and Stratus 2.1 is good and the new Alfas are also very very good.
After that there are a few other settings which can help. Caster is number 1, too much caster will make you spin on corner entry. Set the swaybars a little stiffer can also help. Also check your shock damping is not too light.
Thanks AMG,
I'm running the Stratus 2.1 and switching to the Alfa just to give it a try. I was running 37/35 F/R on the tires, but switched the rears to 30s in hopes of sticking the rear end down a bit, slightly sucessful, but then I lost all feel for when the car would swap ends.
I have the silver sway bar on the rear and the front blade is flat as in 0 degrees, soft I guess. caster is twwo small shims in the rear and the thickest one forward.
I think I have 40wt oil in the shocjks all the way around.
Sugestions, besides slowing down for the entry to the corner.
KingWillie is offline   Reply With Quote
Old 10-30-2003, 05:50 PM   #9608
AMGRacer's Avatar
Default Re: Re: Re: Need setup help
Originally posted by KingWillie
Thanks AMG,
Well it is hard to say without seeing your car run really. Like I say driving the right lines, body and tires is 95% of your setup.
There are just far too many variables. Where is your car oversteering? Corner entry, off throttle, on throttle, mid corner? Need more info, as much as you can give.
AMGRacer is offline   Reply With Quote
Old 10-30-2003, 07:33 PM   #9609
Tag
Tag's Avatar
thanks for the help, but I am not planning to add spacers rather i would like to run the offset tires, do you or anyone know what offsets should i use ?
thanks
Old 10-30-2003, 07:36 PM   #9610
AMGRacer's Avatar
thanks
I do not know of any tires with the correct offset. You will need around 3mm offset. You can get some clamp on 2mm offset hubs which make it work.
Old 10-30-2003, 07:37 PM   #9611
AMGRacer's Avatar
Look on www.kyosho.co.jp The manual is there and the exploded diagram.
Old 10-30-2003, 07:59 PM   #9612
Tag
Tag's Avatar
thanks i will look into that
Old 10-30-2003, 08:29 PM   #9613
Default Re: Re: Re: Re: Need setup help
Off throtle entry into fast corners, I know chances are could be me more than the car.
Old 10-30-2003, 08:41 PM   #9614
InitialD's Avatar
Default Re: Re: Re: Re: Re: Need setup help
My guess is too much rear droop. With your light weight oil, it makes things worse when the weight transfers too quickly to the front. Perhaps better would be to list out your complete setup.
Old 10-30-2003, 09:10 PM   #9615
Manticore's Avatar
can you tell us your "EVO" setting ! I think you are driving a EVO! not snake? right?
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
