Old 10-17-2003, 12:51 AM   #9526
esham's Avatar
Originally posted by alana07
thanks pal. btw, when u're using the 3racing alu radio tray supports, you'll need to trim/shave off some plastic from the rx battery holder if you're using the old v1r batt holder, took me about 10 mins worth of shaving!
I did trim off the V1RR Evo battery case. Take off both legs and than grind smooth both side one of the battery holder hole. Result - not really comfortable with it as the battery is abit hanging. Maybe i should follow as dtm - put it below with spacer in between.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]esham
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 10-17-2003, 05:28 AM   #9527
coastaltony's Avatar
on page 137, mr fury asked if anyone has a rear exhaust header for his VoneR. Anyone state side got one?
Maybe a Trinity Reflex header will fit
coastaltony is offline   Reply With Quote
Old 10-17-2003, 05:43 AM   #9528
Taylor-Racing's Avatar
He won't need any specific header for the V-One R.
I'd suggest taking the car/engine/pipe along to his LHS - they should have a number of rear exhaust headers that would be suitable.
Taylor-Racing is offline   Reply With Quote
Old 10-17-2003, 06:01 AM   #9529
T-R
Thanks for the input. I'll get this
guys address and send him one of my
old headers.
Old 10-17-2003, 10:54 PM   #9530
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Default Re: Clutch bell?
Originally posted by V-One S Racer
Anybody got a (spare) 3D Clutch Bell they can sell me? I gave it to my dad to get the gears off so I could change them to larger ones and I ended up with a bent clutch bell ! I've tried straightening it and it hasn't worked .
They'd cost about $40 in Aus but I'd rather wipe my a$$ with a cactus than pay $40 for one .
Got racing in less than 2 weeks
I'd pay the $40 what if one of those cactus needles gets infected
HEYALIGNMENTGUY is offline   Reply With Quote
Old 10-17-2003, 11:36 PM   #9531
Default Re: Re: Clutch bell?
I've ordered one... should be here around Tuesday .
...better go put the cactus back
V-One S Racer is offline   Reply With Quote
Old 10-18-2003, 03:26 AM   #9532
dtm
dtm's Avatar
Send a message via ICQ to dtm
I've been out of the country for a week.....but the easiest method is to use the old RR battery case. Use at least a 5mm shim and pick up on the existing upper deck holes. If you use a 5mm shim, the case will clear the 3 Racing stand off. The battery will be sitting really low.....it maybe advisable to stick a piece of AE chassis tape on the bottom of the battery!
dtm is offline   Reply With Quote
Old 10-18-2003, 04:05 AM   #9533
dtm
dtm's Avatar
Originally posted by AMGRacer
Anybody had experience with mounting one of these bad boys to a V1R?
Haha....I still have this shell kicking around! When running it is Extremely COOL! Massive downforce on the rear makes the car understeer. Extremely stable...but with the high CG it is easy to roll over the car during corners. I ran it a few times on the on MTX-2!
Old 10-19-2003, 02:53 PM   #9534
mckrooz's Avatar
Send a message via AIM to mckrooz
Default Gearing?
Hey guys. I seem to be running out of gearing at my track. We have a huge straight and my MR12 is just straining towards the end of the track. What is the ideal spur/pinion combo to run? I'd like to keep the 1st gear the same if possible.
mckrooz is offline   Reply With Quote
Old 10-19-2003, 09:24 PM   #9535
Default Re: Gearing?
How long of a straight are we talkin. I would say a 1 tooth jump would be enough if its around 200ft, you also might wan't to get a RPM pipe as well to help the engine.
Old 10-20-2003, 02:07 AM   #9536
It's ok putting a taller second gear on but IDEALLY u wouldn't want to run more than a 4 tooth split between the 1st and 2nd pinion. Or you it might start to get bogged down when changing. Also bearing in mind 1st gear pinion + 1st gear spur = 2nd gear pinion + 2nd gear spur.
Dexter is offline   Reply With Quote
Old 10-20-2003, 06:55 AM   #9537
tazman34685's Avatar
Default Replacement Motor....
I'm looking for input on a replacement motor to work in my V1RR. I had a STS R3 but the bottom end was to weak. I'm looking into the OS TR, as a maybe....
Thanks in Advance.
tazman34685 is offline   Reply With Quote
Old 10-20-2003, 01:50 PM   #9538
Default Re: Replacement Motor....
Thanks in Advance.
Hey....i'm sure you know about trilordy web site http://www.trilordy.com... well you can get some imputs on there cars by looking at pictures and the cars with certain bodies on and watch the vids.....they had a V1R on there with a o.s. .12 TR that was clocked at 80MPH. You should get a popular engine such as novarossi,novamega,o.s., and so on known to provide that power for the V1R....this is my opinion
mr.fury is offline   Reply With Quote
Old 10-20-2003, 05:53 PM   #9539
Default V1RR Evo
Is it really a big jump in performance from the regular V1RR? I have my car dialed finally and wondering if the Evo conversion kit will make even better. Thanks for you input.
elnitro is offline   Reply With Quote
Old 10-20-2003, 09:00 PM   #9540
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hi guys ! well, i have decided to bring my v one rr out of retirement for the local parking lot race . i need some suggestion on parking lot setup, i will run the one-way and foam tires , any suggestions will be appreciated ! also, does anyone know if i run the 25 side pully instead of the stock 27 what kind of change should i expect handling wise ? thanks
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
