Old 10-14-2003, 09:03 AM   #9496
Taylor-Racing's Avatar
Originally posted by HEYALIGNMENTGUY
My set up
FRONT
Camber 2 deg neg
Caster 8 deg pos
toe out 2mm total
Shocks 80 wht and gold springs
no droop screws and no up travel screws
sway bar flat
tires Speedmind 40 shore
REAR
Camber 2.5 deg neg
Toe 2 deg in each wheel
Shocks 60 wht and black springs
no sway bar
Tires Speedmind 40 shore
I do like a softer set up and with lots of suspension travel
Track is Small to Med. its a Oval Bowl like Daytona, The Sweeper is usually from a banked turn into a flat infeild, back straight is about 120-130 ft average lap times are in the 13-16 sec.
the real fast guys do it in 11-12s
As far as the universals are conserned I may give it a try. as far as the doggies popping out, only when I make a turn at full lock and bump the barrier does this happen. It has happed twice during the mains and about less than a min to go and I am trying to catch 1st place guy or trying to keep 1st place.
Basicaly I am pushing the car harder than I usually do
Hmmm . . . OK.
It's always difficult when you can't see the car, but a couple of things stand out to me.
Firstly, you have zero droop control . . . eeee . . gads! Install the droop screws and set them to about 4mm of droop front and rear. The rear droop is the one that really needs restricting, here. You didn't mention ride height so I'll assume it's reasonable . . . whatever that is.
Next, you might set the front bar at 45.
Do this stuff in order - you'll still have plenty of suspension travel.
For the doggies, try my servo saver travel restrictor - it really does work. Of course, a big hit just means that the something else will give - typically a steering arm will pop off, but that's a lot quicker to fix than an ejected doggie.
I know everyone says it, but we must stay of the boards.
For us, a decent race result is often more to do with limiting the time losses than it is with making the blistering odd lap.
Hope this helps.
Taylor-Racing is offline   Reply With Quote
Old 10-14-2003, 10:44 PM   #9497
Here's a few pics of my newly 'sexyfied' Evo !
V-One S Racer is offline   Reply With Quote
Old 10-14-2003, 10:46 PM   #9498
Second one...
Old 10-14-2003, 10:47 PM   #9499
Last one...
Old 10-14-2003, 10:48 PM   #9500
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Originally posted by Taylor-Racing
Hmmm . . . OK.
Hope this helps.
No worries mate Will do on the droop screws also I installed my old universals from the R and shorten the track width about 1 mm per side seems to do the trick.
My ride height is set at 4.5mm Front tire at 6omm Rears at 64mm
Thanks for the advise
HEYALIGNMENTGUY is offline   Reply With Quote
Old 10-15-2003, 01:55 PM   #9501
Default polished manifold
HEY GUYS..I KNOW THIS ISN'T A BUY/SELL/TRADE FORUM BUT...I GOT A POLISHED MANIFOLD FOR SELL. IT COST $40 BRAND NEW RIGHT NOW AT HTTP://WWW.TOWERHOBBIES.COM i AM WILLING TO SELL IT OR TRADE IT FOR A REAR EXHAUST MANIFOLD FOR THE V-ONE R. THIS MANIFOLD IS FOR SIDE EXHAUST ENGINES. THE MANIFOLD I HAVE WAS MADE FOR THE V-ONE R. PLEASE EMAIL ME AT [email protected] IF YOU ARE INTERESTED IN BUYING THE MANIFOLD OR TRADING IT WITH YOURS...OR IF YOU HAVE ONE I COULD BUY OFF OF YOU. PIC INCLUDED
Thank You
mr.fury is offline   Reply With Quote
Old 10-15-2003, 06:39 PM   #9502
esham's Avatar
Guys, I just bought 3racing Left brace and centre mount. but i face aproblem to install the battery with them. The original V1RR Evo came with special battery case which the stand mounting is joint together with the battery case but not on this 3racing option. Any idea how to fix this ? How to fix the battery with this option??
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 10-15-2003, 06:42 PM   #9503
Manticore's Avatar
R/C Tech Charter Subscriber
use the RR battery mount. you might need to trim some material from the mount to avoid blinding.
Manticore is offline   Reply With Quote
Old 10-15-2003, 06:43 PM   #9504
AMGRacer's Avatar
They talked about this on HK forum. From my understanding you need to cut the legs off your original plastic mount and screw it to the new mount.
manticore and dtm will know for sure.
AMGRacer is offline   Reply With Quote
Old 10-15-2003, 06:49 PM   #9505
AMGRacer's Avatar
Anybody had experience with mounting one of these bad boys to a V1R?
Old 10-15-2003, 06:51 PM   #9506
AMGRacer's Avatar
I am running one of these:
but they are kinda tough to fit as they are right on 200mm.
Old 10-15-2003, 06:54 PM   #9507
Manticore's Avatar
ask dtm, he ran one !
Old 10-15-2003, 06:54 PM   #9508
Manticore's Avatar
i doubt about the rear down force of this body.
Old 10-15-2003, 06:54 PM   #9509
esham's Avatar
That quick! Thanks guys... just a little bit more. Observe the original casing if I about to trim or cut away the leg is it means I will only left upper mounting of the original casing ( turn to be U shape without the back support which attach along the 2 legs ) then tape the battery with it and mount hanging ? He..he.. Photo please....
Old 10-15-2003, 07:32 PM   #9510
esham's Avatar
Oppsss... when through HK forum. Yup..dtm did posted pictures and suggestion. Can't believe it - 3racing !!?
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
