Old 10-12-2003, 10:09 PM   #9481
Regional Moderator
disaster999's Avatar
Originally posted by boner
Manticore:
Your NSR baby is hibernating right now but I'm running your other baby, the MT12 you worked on for disaster999 family v1r. Very please with it.
haha...im gonna charge you for using the engine!
disaster999 is offline   Reply With Quote
Old 10-12-2003, 10:28 PM   #9482
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Default Re: Re: Re: Gearing on a VoneR
Originally posted by tazman34685
Tell Me where can I get the kyosho gear set here in the states or anywhere for that matter.... The stock spur gears 48/44 can stay?
Tower should have them in stock
HEYALIGNMENTGUY is offline   Reply With Quote
Old 10-12-2003, 10:30 PM   #9483
Originally posted by cvccsi
Hi Guy,
This may be the wrong thread to ask this question but I am going to give it a shot.
Will the V ONE RR EVO conversion kit work on the Trinity Reflex NT?
Thank you.
It might, but didnt trinity come out with a updated version of that car
Old 10-12-2003, 10:36 PM   #9484
Well I took the evo for some local club racing today and had a good time
Just need a little set up help, the car over stears going through the middle section of a sweeper. I only exsperiance this wile on throttle.
Also had to call it a day when the front dog bone got stuck when I nicked a dot at full turn they need to get unerversals made for this,It has cost me a couple of good finish's in the last month.
But other than that the evo is a fun car to drive and is giving those NTC3's fits
Old 10-13-2003, 05:07 AM   #9485
Trader Rating: 74 (100%+)
Default Popping dogbones
I too have have my share of ejected dogbones. Mine were coming out because the flimsy plastic ball cup on the steering knuckles would pop off going into the turn from the force of it. I have changed to a captured style end such as mugen's, but I used the Traxxas's instead.
I ran it the weekend, and have broken the cup in one of the hubs from the dogbone popping, now I too am in need of parts.
Does anyone know if the K factory parts would fit for the V One R? Are they the same lenght, and width?
My kit is the V one RR evo. Thanks for the needed help.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 10-13-2003, 05:35 AM   #9486
Kyle Hazell's Avatar
Trader Rating: 17 (100%+)
Default Front Dogbones
Probably one thing you guys should check is the front track width if your continually popping the doggies out. From my experiences running a front track width of 199 mm you should never have a problem, even when there is heaps of steering dialed in.
Sometimes i have even been a bit concerned that the dogbones are a tad tight......
Hope this helps out
Kyle
Kyle Hazell is offline   Reply With Quote
Old 10-13-2003, 05:56 AM   #9487
Taylor-Racing's Avatar
Default Re: Re: Gearing on a VoneR
Originally posted by dino.tw
Try to make the pressure pipe longer.
dino.tw,
How does this make a difference to the bottom end?
Taylor-Racing is offline   Reply With Quote
Old 10-13-2003, 06:05 AM   #9488
Default Re: Re: Re: Slowest Evo Build up!??!!
Originally posted by OZDC
The pipe might look like a wank Gav, but Cammo (TQ Aussie nats), likes it
DC
Actually, I may have been a bit too subtle.
If you look at the original pic, the car is on a HUDY set-up board and the "Y" of the "HUDY" word looks to form fins on the rear of the pipe . . . . anyway.
But Mr Calamari was using one?
Mr Calamari and Manti obviously know their pipes, but I thought "Shark" only produced outlaw versions.
I guess we could always sleeve the stinger, somehow.
Old 10-13-2003, 06:14 AM   #9489
sparksy's Avatar
Trader Rating: 14 (94%+)
Sparks,
Look forward to meeting you at the track.
DC
Sweet,
Thanks for that mate. I cant wait to run down there.
sparksy is offline   Reply With Quote
Old 10-13-2003, 06:15 AM   #9490
Hi Guy,
Thank you.
Maybe.
Remember that when using the conversion kit the only assembly you really keep is the rear bulkheads together with the suspension bits etc. that are attached to it. Pretty much everything in front of the engine is new/different.
Will the rear end bolt onto a V-One XXX chassis?
The Reflex gears are different, I believe.
Old 10-13-2003, 07:09 AM   #9491
What's your set-up and track details?
On the doggies, I usually take a couple of precautions:
Firstly, if you move the wheel to full lock and turn it, you'll find that the doggie will "catch" on the square edges of the pin slot in the axle. I round these edges off with a dremel.
Secondly, we install a small piece of alloy attached to the servo saver which limits the throw of the saver - it will contact the inside of the bulkheads before the doggie gets close to a "pop out" situation.
If I recall, AMG said the old universals will fit.
Of course, with a significant brain fade, all bets are off.
Old 10-13-2003, 07:11 AM   #9492
boner's Avatar
Yo, sure you can charge me all you want and I'll charge you for tuning your engine. Heheeeee, tell me when your mood swing is over. I don't want to be your target for your throwing knife.
boner is offline   Reply With Quote
Old 10-13-2003, 07:17 AM   #9493
boner's Avatar
.... Also had to call it a day when the front dog bone got stuck when I nicked a dot at full turn they need to get unerversals made for this,It has cost me a couple of good finish's in the last month.
I too have this problem but I fix it using Kyosho's V1R/RR universal. Just make sure to make your front a tad narrower, I believe my front width is 196~197mm.
Old 10-13-2003, 07:19 AM   #9494
Default Re: Front Dogbones
Hope this helps out
Kyle
Agreed - I think they are a bit tight too and was worried about the front bearings.
You reminded me . . . . last race week, between heats, I noticed these two "ring things" on the front dogbone. I first thought the front inner wheel bearing had let go due to the tight dogbones. On close inspection I found the two "ring things" were bearing shields from the wheel bearing. Obviously there shouldn't be two shields there - maybe one.
I can only guess that the robot that assembled this bearing had installed an extra shield instead of a snap ring. Ya just can't trust robots.
Old 10-13-2003, 10:39 PM   #9495
My set up
FRONT
Camber 2 deg neg
Caster 8 deg pos
toe out 2mm total
Shocks 80 wht and gold springs
no droop screws and no up travel screws
sway bar flat
tires Speedmind 40 shore
REAR
Camber 2.5 deg neg
Toe 2 deg in each wheel
Shocks 60 wht and black springs
no sway bar
Tires Speedmind 40 shore
I do like a softer set up and with lots of suspension travel
Track is Small to Med. its a Oval Bowl like Daytona, The Sweeper is usually from a banked turn into a flat infeild, back straight is about 120-130 ft average lap times are in the 13-16 sec.
the real fast guys do it in 11-12s
As far as the universals are conserned I may give it a try. as far as the doggies popping out, only when I make a turn at full lock and bump the barrier does this happen. It has happed twice during the mains and about less than a min to go and I am trying to catch 1st place guy or trying to keep 1st place.
Basicaly I am pushing the car harder than I usually do
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
