Old 09-30-2003, 09:53 PM   #9361
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Originally posted by kevink2
Thanks man. I appreciate it.
I was actually up in San Jose for work last month but didn't have time to bring my gear. I should be up there again, probably early next year. Come down to So Cal some time again, Revelation will be having a Toys for Tots race in December...
Jonathan showed up a lot down here before the Nats... he and Thello-true R/C madmen!
Yes they are
Toys for tots race sounds like fun, Just might have to mention it to him
HEYALIGNMENTGUY is offline   Reply With Quote
Old 09-30-2003, 09:54 PM   #9362
Well my take an the S3 serious is nothing short of disgraceful. I have a JP S3 and for 600 bucks it really is apauling. I have one and i can't tune so my take on the engine could be wrong but it lots all of it's potency after about 4 race meets and from then on it all went down hill. Started getting 5 mins or less run time even when some one with tuning knowledge had a go. Lost all of it's punch out of corners but maintaining respectable top end. I must admit i wasa huge fan of the S1's though so i'm not sure what Nova did different but hopefully they will go back to their old methods when you would get good and reliable with decent run time. But now 2 other people have got JP S3's and these two people can tune. One of them being Rob and he was filthy after the last meet about how little longevity the engine had, including no bottom end. The other owner i'm not to sure on saying that he did have engine trouble in the last final. I'm most certainly think u should keep your eyes on the new JP NS12's though i think nova copped alot of heat fromtheir last engine and i think they have HOPEFULLY sorted themselves out but my money is still on the RODY to maintain it's power advantage.
Don't flame me for MY thoughts cause they are only that.
Dexter is offline   Reply With Quote
Old 10-01-2003, 12:12 AM   #9363
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Re: Re: Re: Slowest Evo Build up!??!!
Originally posted by Taylor-Racing
I would love a test report on the NS3, please.
Doesn't Manti have one also?
I've got NS5 instead of NS3.
the NS5 is the best/fastest stock engine and IMO it is much better then JP-RS5
overall NS5 is a powerful engine
Manticore is offline   Reply With Quote
Old 10-01-2003, 12:48 AM   #9364
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I know someone that recently bought an Evolution and I see that he has to true his tires to the bare minimum to get the car to handle while maintaining a 4mm split between the F and R. Is this neccesarry? Also, what can I do to get rid of the built in overdrive in the car (pully?)? I'm planning to pick one of these up and sell my Mugen.
Racing4Evo is offline   Reply With Quote
Old 10-01-2003, 01:01 AM   #9365
AMGRacer's Avatar
You are correct. With the 25T side pulley (standard) you need to true the front tires down 4mm more than the rear to keep a 1:1 ratio. This is easily remedied with a 27T side pulley and a 27T side belt. Should cost $15.
AMGRacer is offline   Reply With Quote
Old 10-01-2003, 01:02 AM   #9366
vones's Avatar
change the side pulley 25T to 27T for 1:1 ratio
vones is offline   Reply With Quote
Old 10-01-2003, 01:43 AM   #9367
Send a message via AIM to skywalker Send a message via Yahoo to skywalker
Sorry to correct u on the pulleys: for the 25T u got more front ratio, 26T u get 1:1 ratio, for the 27T there's more rear ratio hope u learn something out of it
skywalker is offline   Reply With Quote
Old 10-01-2003, 01:49 AM   #9368
AMGRacer's Avatar
You are not correct.
25T is 4.5mm overdrive, 26T is 2.25mm overdrive and 27T is 1:1 ratio. I can prove it if you require..............
Front = 27 / 19 * 32 / 18
Rear = 48 / 19
Old 10-01-2003, 01:58 AM   #9369
InitialD's Avatar
vones is still correct. 27T will give you the same front and the rear drive ratio which is 1:1.
With 25T,
Front drive ratio = (32/18) x (25/19) = 2.34
Rear drive ratio = 48/19 = 2.53
With 26T,
Front drive ratio = (32/18) x (26/19) = 2.43
Slightly less front drive than 25T but still gives front overdrive.
With 27T,
Front drive ratio = (32/18) x (27/19) = 2.53
Equal front and rear drive ratio which gives a 1:1 overdrive.
Old 10-01-2003, 02:19 AM   #9370
AMGRacer's Avatar
With 25T,
With 26T,
With 27T,
So what did you learn?
Old 10-01-2003, 02:24 AM   #9371
Manticore's Avatar
Old 10-01-2003, 03:08 AM   #9372
finchy's Avatar
Dexter go the RODY all the way. I have an S3 , MT12 ( still one the best engines I own) and have had a few others from the Nova family and all I have to say is that at the qld titles I saw one of the good guys from our club use 2 NS3's at the meet. Wheather he likes a lean diet of fuel mix, I'm not certain but never the less these engines should last a bit longer than that. My S3 now needs a new P&L but that is after 24 litres of fuel and I did not change the rod after run in.
finchy is offline   Reply With Quote
Old 10-01-2003, 03:14 AM   #9373
finchy's Avatar
AMGRacer I learnt something. Thank You Should come and check out the Nats on the weekend if you get time. I was talking to a guy from SA today and he was showing me what he's done to his EVO and man you got to see this thing, and some of the idea's he has. It will be interesting to see how it preforms on the track. I might see you there .
Old 10-01-2003, 03:35 AM   #9374
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Arrow MTX3 RECEIVER COVER
guys could you give me the part number of the mtx3 receiver cover that you used in your evo receivers. my lhs does not carry such part and i might have to order it on an online hobby shop.tnx........
buboy28 is offline   Reply With Quote
Old 10-01-2003, 03:37 AM   #9375
What kind of work are we talking about? And yes keep us posted on how it goes
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
