Kyosho VoneR Thread
#9331
Re: Re: Re: Re: Slowest Evo Build up!??!!
Originally posted by dtm
100% correct Mr AMG! The brace sits real close to the engine back plate screws...like they are touching! If I use the Mugen centax I cannot get the engine far back enough! things are pretty tight around there!
#9332
Re: Re: Re: Re: Re: Slowest Evo Build up!??!!
Originally posted by Manticore
i am using mugen clutch with a left side brace !
#9333
Re: Re: Re: Re: Re: Re: Slowest Evo Build up!??!!
Yes...thats one "bone" I have to pick with you Mr Manticore......the Kyosho brace gives me less clearance than the old 3Racing brace I was using!!!! who was the one to recommend getting Kyosho!!??!! KY has reverted back to the 3Racing brace!! I think I will too.....this one is not my "blue" car!
#9334
Got a chance for some track time this morning, tested a few new things out....
I tested the active diff in the rear again. This time it was perfectly behaved, so I assume it must have broken in or something. I could make fine settings of the rear diff tightness very easily, very impressed with its performance today.
I installed 2 x 9550 futaba servos. These fit in nicely and give a huge amount of extra space in the radio area. They seem to power the brakes and the steering just as well as my old 9450s used to. Very happy with these beasts.
Went down to 30wt shock oil all around and I am impressed with how much more reaction I get out of the suspension. Mayby a bit too much in the front.
Used my tires from their stock 65mm size on a bumpy and loose track. I have decided that I like it better. The reaction of the steering dulls away a little, but the car has much more forgiveness between grip and spin.
#9335
Track width
Hi can you pros advise.
If i run with a narrow track width in front then the rear, what is the handling effect? Thanks!
#9336
Re: Track width
#9337
clutch setting
hi, there,
my 3d centrax clutch engage very late. so the rpm very high then acc strongly. however there is no low - mid speed.
if i set it engage early. will it damage the clutch?
i set it earlier, then some days later, it become later, and later.
how can i lock the timing of engage?
#9338
Re: clutch setting
Originally posted by Franky
hi, there,
hi, there,
1/. clutch spring
2/. clutch bell end play
3/. shim betwee clutch bell inner bearing and engine nut
the problem with your clutch could be either or all of the about improper set up of your clutch.
1/. the stiffer the spring tension, the later then clutch engage
2/. more end play reqired clutch spring compress more i.e. clutch will engage later
3/. excessive shim there will also cause late clutch engagement.
the general setting of the above
1/. stock clutch spring: within 2mm engine nut thread exposed
2/. approx 0.3mm end play
3/. either none shim or just enough shim to let the clutch bell spin freely.
#9339
Re: clutch setting
#9340
Originally posted by HEYALIGNMENTGUY
I would like to thank Manticore and all of those blokes down under for there posts on SET ups for the evo
I took it out for its maiden voyage today, and boy did those TC3's and mugen cars get A eye opener.
I TQ'd with out any major or minor changes to my initial set up, the main was going soo well until a back marker who was afraid to get lapped took me out Damn those nitro shoes and hard plastic wheels
Oh well maybe next time I will win
Anyway glad your first time out with evo was good.
#9341
Nah....that would be too quick for me! I need to run in the NS3 engine first.....something for next Saturday!
Doesn't Manti have one also?
#9342
Originally posted by Taylor-Racing
I would love a test report on the NS3, please.
Although, Andrew Abbott raced at Lilydale on Sunday and was running the new Picco XP-12RE. He reckoned he was keeping the pace and even catching the big boys with JPs etc. Mind you he had to pit quite often cos he had a leak in his fuel tank .
I asked him and he reckoned it's better than his previous RS12 S3.
#9343
<SNIP>
<SNIP>
What type of track, AMG?
At our last meet, we seemed to encounter rather more suspension "bounce" than I thought acceptable. I put it down to the kit shock oil (what . . . about 40wt) and the warmer weather. I changed the front to 60wt and it seemed pretty good. Next weekend we'll try 70/60 and see how it "looks".
#9344
Re: Re: Re: Re: Re: Re: Re: Slowest Evo Build up!??!!
Originally posted by V-One S Racer
I'm currently drooling over the RB V12 Rody Turbo !
If price is anything to go by, it should.
#9345
Re: Re: Re: Re: Re: Re: Re: Re: Slowest Evo Build up!??!!
I wonder if the V12 Rody puts out much more power than the X12 Rody.
