Old 09-22-2003, 06:10 AM   #9241
One other thing I have noticed with the EVO is that with the stiffer plastic i have yet to loose a dogbone instead i have warped and broken rims and this never occured with the R the dogbone would simply pop out. Also for the first time yesterday the dogbone locked but that's no biggie, quickly solved by turning the wheel. If only i could get a motor that runs i'd be set .
Dexter is offline   Reply With Quote
Old 09-22-2003, 06:24 AM   #9242
Taylor-Racing's Avatar
Originally posted by Dexter
That bring the tally up to about 5 people told me in one day! Becuase Jason Chin also missed the final due to an engine bearing. Look $35 for a JP S3 seems a reasonable deal to me don't be too stingey now.
See, we need to apease the bearing god's.
Sacrifice your engine . . . $32.50.
Could you have a look for the bearing part numbers and more importantly the sizes/spec's. I'll see if I can russle up a few, locally.
Taylor-Racing is offline   Reply With Quote
Old 09-22-2003, 06:28 AM   #9243
Sp Racer's Avatar
If you get stuck with bearings let me know, I have found a good source,I just ordered 2 new ones for my Collari $35
Sp Racer is offline   Reply With Quote
Old 09-22-2003, 06:40 AM   #9244
Yes, please.
You have PM.
Old 09-22-2003, 06:45 AM   #9245
AMGRacer's Avatar
I likey.........................
AMGRacer is offline   Reply With Quote
Old 09-22-2003, 06:49 AM   #9246
Sp Racer's Avatar
I likey more......
Old 09-22-2003, 06:53 AM   #9247
AMGRacer's Avatar
I likey more......
Wrong on so many levels............................
Old 09-22-2003, 07:03 AM   #9248
Hey . . . what's that little grub behind the car? . . . . must be the grub that fell out of Lu's 2-speed.
Old 09-22-2003, 07:19 AM   #9249
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Originally posted by finchy
Sp Racer at the QLD titles I was running 18/22 pinions with the standard spur gear. In my own opion I think that was a little too high, another guy there was running 17/21 and this seemed just right. I'm trying to get some other 0.8 module gears at the moment but it seems that no one has any, you don't know anywhere that carry's the gears at resonable prices in OZ do you.
finchy, 18/22 is too high?? I heard it needs 24t conversion.
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 09-22-2003, 07:21 AM   #9250
tl2111's Avatar
Thats what I have done to mine and have the short roll bar as well.
*F1**4PX***TORO
*12th**4PX***TORO
Old 09-22-2003, 07:26 AM   #9251
AMGRacer's Avatar
Hahahahah yeah it might be
I reckon using this swaybar from the fantom might be the ticket to get a stiffer rear end, and also to avoid hitting the shocks!
Old 09-22-2003, 07:28 AM   #9252
AMGRacer's Avatar
Did you just cut a groove into the rear cover plate?
Old 09-22-2003, 07:35 AM   #9253
tl2111's Avatar
yeah, just make sure the wire sink in tight but smooth up and down in movement, btw I'm using floating rear mount as well.
AMG, what gearing and tyres size that U use at brendale???
*F1**4PX***TORO
*12th**4PX***TORO
Old 09-22-2003, 07:39 AM   #9254
OK, the things I don't like about rear blade bars:
They're invariably heavy, mounted too high and have too much "slop".
. . . but they are easy to adjust, so I'd like to be convinced.
Old 09-22-2003, 07:41 AM   #9255
AMGRacer's Avatar
In full competition most people use 57mm tires. I personally use 60mm but I suck.
You can get a lesser motor to carry the 57mm tires with the 18/22 gearing and any motor like the S3 and NS12 should be able to carry 17/21. The motor will be screaming with this gearing, but fast.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
