Kyosho VoneR Thread >
Kyosho VoneR Thread
Like Tree1Likes
Kyosho VoneR Thread
Old 09-07-2003, 06:25 PM
  #9016
esham's Avatar
Is it V1Evo is designed to used reverse steering operation?
esham is offline
Old 09-07-2003, 07:52 PM
  #9017
Manticore's Avatar
yes, reverse as in compare with V1R/RR
Manticore is offline
Old 09-07-2003, 07:54 PM
  #9018
Manticore's Avatar
Originally posted by EVOLUTION
Stop stirring things you snaker.
nope, he is not snaker but wanna be!!
  #9019
Manticore's Avatar
Originally posted by Vinyard
Actually the punk fish would sugguest KY but he preferred roughness.. but he's like lost in the pacific oceans
You can try WD40 too..
right, where is fish? i miss him much !!
Old 09-07-2003, 08:07 PM
  #9020
RClover's Avatar
eloped with his mermaid..
RClover is offline
Old 09-07-2003, 08:20 PM
  #9021
esham's Avatar
I tested my evo yesterday. Everything goes well except cornering angle still not that sharp off power ! ( I expecting more or as my MTX3 ! ) I believe my setup not that "sweet" yet. So I need help.
Current Setup
Front
Tire : Form
Caster : Only 1 pc of thin block slot in front
Camber :1
Toe Out : 1.5
Spring : Hard
Diff Oil : 10,000
Ride Height: 5mm
Droop: +3
Front Sway Bar : 90 ( Hard)
Rear
Tire - Form 40 shoe
Camber :2
Toe In : 2
Spring : Soft
Diff Oil : 7,000 LSD
Ride Height: 6mm
Droop: +4
Rear Sway bar : Gold Shaft - (Hard)
This week I want t o work on the rear/front sway bar and the caster. Hope I will get it..
esham is offline
Old 09-07-2003, 08:43 PM
  #9022
Vinyard's Avatar
mama fish will make sushi out of him first if that's the case..
Vinyard is offline
Old 09-07-2003, 09:33 PM
  #9023
AMGRacer's Avatar
Well some more results from this weekends outing.........
Plenty of rear grip to be had by reducing rear camber. Mine was at the kit setting of around 3.5 degrees. I am down to 2 on the rear and the tires are wearing nice and flat. Appears the EVO requires much less overall camber. A nice side benefit is that acceleration is improved.
Using +4 degrees of droop in the rear seems to work very nicely. Locked the rear end of the car in very nicely.
I no longer need to use the 300m to get plenty of steering. Sticking with a Stratus 2.1 and even front/rear shore tires is giving me plenty of turn in for my driving style.
The weight reduction on my car has made it feel even more like my XRAY!! This thing changes direction in a heartbeat!! I can recommend these parts:
1. Square TI pivotballs - unsprung weight reduction
2. AAA battery pack - overall mass reduction
3. Graphite top deck and Shimo chassis plate - Stiffer + mass reduction
I am not using a left hand brace and it feels well stiff enough for me right now. My track is only medium grip however.
On another related note, I found that using a 6mm ride height is excellent on lower grip/bumpy surfaces. I have always had it in my head to run 4mm, but getting it up higher makes the car corner much more smoothly. My current theory is that the chassis must have been striking/dragging.
AMGRacer is offline
Old 09-07-2003, 09:37 PM
  #9024
AMGRacer's Avatar
Current Setup
Front
Tire : Form
Camber :1
Toe Out : 1.5
Spring : Hard
Diff Oil : 10,000
Ride Height: 5mm
Droop: +3
Rear
Tire - Form 40 shoe
Camber :2
Toe In : 2
Spring : Soft
Ride Height: 6mm
Droop: +4
Two things which will reduce steering:
1. Hard front/soft rear. Make them medium equally (eg. black and black)
2. Hard front bar make initial turn in sharp but understeer mid corner. The front bar is much much harder than even the gold rear bar so with hard on both ends the car will understeer.
Also tires!!!
AMGRacer is offline
Old 09-07-2003, 09:58 PM
  #9025
esham's Avatar
Also tires!!!
OOOOooo I didn't know that ( About the gold bar.. ) Appreciate that. Need check it and test again. Thanks.
esham is offline
Old 09-07-2003, 11:04 PM
  #9026
apmk's Avatar
Default Setup
Hey AMG, care to post your setup?
apmk is offline
Old 09-08-2003, 02:18 AM
  #9027
Taylor-Racing's Avatar
Originally posted by Data
three places huh...... ok that would be 2.600 mm then.
Thanks Data.
Three places will just have to do, for me . . . . . I kinda miss your unerring accuracy, though.
Taylor-Racing is offline
Old 09-08-2003, 03:56 AM
  #9028
esham's Avatar
Where should I get the collar / spacer that hold the diff case of Evo to the dogbones/uni. I tried use bearing which alittle bit bigger ( That the only bearing ... that I have now! ) It not really well...
How you guys fixed this... The collar ..where it from? Please
esham is offline
Old 09-08-2003, 04:06 AM
  #9029
Manticore's Avatar
you should use bearing 10x15 (2pcs) for the rear diff and 12x18 for front diff or front oneway
Old 09-08-2003, 04:28 AM
  #9030
AMGRacer's Avatar
Well we have some new Kawahara items...............
AMGRacer is offline
