Old 09-03-2003, 10:34 PM   #8851
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Originally posted by AMGRacer
I agree the eccentric knobs can often be off. My car with shocks equal length and precicely the same droop requires the knobs to be at quite different positions to remove the tweak.
I am sure this is a molding problem from left to right.
The problem that I have with the plastic holder is when I tighten the adjusting screw it bent the arm pin which make the suspension not working probably even without the blade installed.
tl2111 is offline   Reply With Quote
Old 09-03-2003, 10:43 PM   #8852
AMGRacer's Avatar
Really?? Hmmmm i better check mine out but I never noticed this before.
AMGRacer is offline   Reply With Quote
Old 09-03-2003, 11:04 PM   #8853
AMGRacer's Avatar
Some interesting results from Malaysia:
http://www.rctech.net/forum/showthre...threadid=23627
Looks like the EVO did pretty well there. EVO is there like MTX3 is here by the looks!
Old 09-03-2003, 11:17 PM   #8854
InitialD's Avatar
No doubt that the car is very able. You must also take into consideration that it just so happen that top drivers in the country are jumping on the bandwagon and that is why you see they occupy the top spots
Actually, not all top drivers were present in the race as that race was pretty close to the 1 or 2 other races on that long holiday weekend.
Generally, MTX-3 cars do dominate in races here.
Old 09-03-2003, 11:38 PM   #8855
Data's Avatar
so are you saying the driver accounts for the win, not the car ?
Data is offline   Reply With Quote
Old 09-03-2003, 11:40 PM   #8856
Vinyard's Avatar
i think that was a wrong posting.. unless i am wrong..
coz on this thread
http://www.rctech.net/forum/showthre...threadid=23299
which the race were held on the same day had a different results and some of the drivers appear both..
unless they have a time wrap device or something..
anyway i think the Evo is a sweet car..!
Vinyard is offline   Reply With Quote
Old 09-03-2003, 11:42 PM   #8857
Manticore's Avatar
R/C Tech Charter Subscriber
coz on this thread
oh damn, you said KY again!!! where is punk the fish?
Manticore is offline   Reply With Quote
Old 09-03-2003, 11:47 PM   #8858
Originally posted by Manticore
i think the belt for 27T is 384mm and belt for 25T is 375mm (pretty sure) 376 or 377 is tight and i think it is almost impossible to install with 27T pulley. why you dont try 25T pulley and use 375mm belt?
by the way, i am using mtx3 clutch and engine mount with 25T and 375mm belt and they do rub but not that critical. I might need to file away some material from the header to minimize rubbing. that will help to reduce weight too !
I am using V1-rr clutch and V1-rr blue engine mount with 25T and 375mm belt, they don't rub but the belt is very very loose. When I change to 27T with 375mm belt it is too tight can you advise what should I do?
zech is offline   Reply With Quote
Old 09-03-2003, 11:48 PM   #8859
InitialD's Avatar
coz on this thread
No... No time warp devices used
This race was actually held on September 1st if I'm not mistaken. August 31st was open practise day.
The other race that AMGRacer quoted was held on August 31st.
Old 09-03-2003, 11:50 PM   #8860
Manticore's Avatar
375 belt is for 25T pulley OD configuration.
you should use 384 belt instead for 27T pulley
the reason why your 375 belt with 25T doesnt rub the header is that your engine sits taller and the belt is kept away from the header.
Old 09-03-2003, 11:53 PM   #8861
Data's Avatar
the adjustment knob doesnt work very well to set left/right balance. besides flex, it could be the molding problem that allows more slop between the knob and the blade holder.
wonder if i could use the knobs from the MTX-3.
Old 09-03-2003, 11:55 PM   #8862
Manticore's Avatar
try and tell me if you can or cannot.
Old 09-03-2003, 11:56 PM   #8863
Data's Avatar
don't be lazy now, you are the one who has all the time (and money)
Old 09-03-2003, 11:57 PM   #8864
Thank you Manticore!
BTW I am running front diff, shouldn't I use 375 belt with 25T pulley? Or what should my configuration be?
Old 09-04-2003, 12:02 AM   #8865
Vinyard's Avatar
same place??
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
