Old 09-01-2003, 11:24 PM   #8821
AMGRacer's Avatar
Originally posted by zech
If I am not wrong the EVO is using the V1s's roll bar holder.
Yes you are wrong
The V1S standard front roll bar mount is actually on the top deck and the front roll bar is a wire type. This was also used on the V1R foam tire edition, both the gold and silver versions.
The EVO front bar mount is a completely new moulding and the bar retension setscrews are now bottom loading and thread far more deeply into the material so they are less prone to stripping the mount unlike the old holders.
AMGRacer is offline   Reply With Quote
Old 09-02-2003, 06:40 AM   #8822
AMGRacer's Avatar
Did anybody notice the new EVO has new shock diaphragms? W6006.
Old 09-02-2003, 07:29 PM   #8823
esham's Avatar
Evo assembly almost done... but now facing problem in installing the sterring servo horn. Is anybody have a effective idea how to install that. What the proper sequence is? I tried to acces the screw for the servo horn from side ( which the updeck already screwed ) but the front pulley blocked me..
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 09-02-2003, 09:04 PM   #8824
B4
B4's Avatar
Lightbulb
Attach the servo horn before putting on the top deck. You attach the steering linkage after the top deck is on. It is important to use the correct spacer to go between the steering servo and it holder. Otherwise the servo horn will not be in the correct position and you will be unable to get to the linkage.
B4 is offline   Reply With Quote
Old 09-02-2003, 09:44 PM   #8825
That steering linkage is an ABSOLUTE NIGHTMARE to get on ... I nearly spat the dummy .
V-One S Racer is offline   Reply With Quote
Old 09-02-2003, 09:55 PM   #8826
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Its Chrismas in Sept.
I got my little package today
Thanks Santacore or is it Manticlause
HEYALIGNMENTGUY is offline   Reply With Quote
Old 09-02-2003, 10:21 PM   #8827
Me too.....
zech is offline   Reply With Quote
Old 09-02-2003, 11:47 PM   #8828
StepPins's Avatar
AMGRacer,
even though the new EVO front stabilizar bar holder is of a new mold, do you think/know if the v-one-rr stab bar holder will fit the new lower arms of the EVO conversion?
I'm still in the mist -- since a sales rep from Precision R/C says that the 3Racing (KV006) aluminum front stab bar holders for the v-one-rr will work.
I would rather ask you since you (IMO) have alot of knowledge about the v-one-rr and EVO conversion
StepPins is offline   Reply With Quote
Old 09-03-2003, 12:20 AM   #8829
esham's Avatar
Old stuff question - The 5th body post from Kfactory. Is it give any good?
Old 09-03-2003, 12:51 AM   #8830
Diva's Avatar
Send a message via Yahoo to Diva
Harder or what?
Diva is offline   Reply With Quote
Old 09-03-2003, 09:46 AM   #8831
Taylor-Racing's Avatar
The instructions show that the servo horn should be installed before the top deck get's screwed down. If you need to adjust the horn after it's all together (like I did) , just take the screws out of the middle block, and there's enough room to get a driver in there.
Taylor-Racing is offline   Reply With Quote
Old 09-03-2003, 09:55 AM   #8832
You must have been a good boy all year - Merry Christmas, HAG.
Old 09-03-2003, 01:06 PM   #8833
ziggy12345's Avatar
Anybody have a decent setup for the V-ONE-RR on a bumpy track using rubber tyres?
ziggy12345 is offline   Reply With Quote
Old 09-03-2003, 02:53 PM   #8834
ziggy12345's Avatar
Damn! I just checked and the guide at the rear that stops the body moving sidways was upside down and restrictiond suspension movement.
It should work OK now!!
Old 09-03-2003, 04:50 PM   #8835
Manitcore,
Where did you get the left side brace on your Evo?? I have been searching all over and have yet to find someone that is selling it. Do you have a web address or telephone number??
Thanks in advance,
Jason
melonracer is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
