Old 08-08-2003, 11:00 PM   #8401
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Belts 'n' Stuff
Originally posted by V-One S Racer
Is the Evo overdriven at the front like the RR was? If so then what is required to convert it back to 1:1 drive ie. Part number for belt/pulley etc?
Are all the other belts the same as the RR?
I want to convert it back to 1:1 until I get myself a tyre truer so that I don't have to run the diameter split.
Thanks.
pulley and belts are the same on RR or R
Manticore is offline   Reply With Quote
Old 08-08-2003, 11:09 PM   #8402
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Originally posted by Diva
Anybody is going to build the M1RR EVO here?
I am
HEYALIGNMENTGUY is offline   Reply With Quote
Old 08-08-2003, 11:36 PM   #8403
Default Re: Re: Belts 'n' Stuff
.... alright.... now i'm confused. I've read that the RR was overdriven at the front and to change the front drive ratio back to 1:1 you had to change to a different pulley and belt.
I assume the Evo is still overdriven?
V-One S Racer is offline   Reply With Quote
Old 08-09-2003, 12:24 AM   #8404
Taylor-Racing's Avatar
Default Re: Re: Re: Belts 'n' Stuff
Use the 27T front pulley to eliminate the O/D.
You'll also need the longer belt - VZ070 Drive Belt 378.
I expect the Evo and the RR both use the same O/D - with luck I can tell you on Monday.
Taylor-Racing is offline   Reply With Quote
Old 08-09-2003, 12:30 AM   #8405
AMGRacer's Avatar
Originally posted by Taylor-Racing
Geeez . . . what bad luck. I'd be crying.
I know I shouldn't ask this but are you really, really sure.
That's a hell of a coincidence.
(Hope they don't read this in that throttle servo thread.)
Yeah they are dead for sure.
Hooked up my charger to charge the battery (thru the two way switch) and heard a electrical frying noise. 2 dead servo and the RX unit is fine. Very wierd. Both servos were attached with rubber grommets and working fine 30 minutes before. I think the switch must have shorted the wrong way or something.
Anyway I have gone to my backup crappy servos, so the car will venture to the track tomorrow
AMGRacer is offline   Reply With Quote
Old 08-09-2003, 12:31 AM   #8406
AMGRacer's Avatar
Default Re: Re: Re: Re: Belts 'n' Stuff
EVO and RR both have the 25T pulley supplied and a 25T pulley sized belt. To convert you need the parts that Taylor-Racing mentioned above.
Old 08-09-2003, 12:33 AM   #8407
AMGRacer's Avatar
Thank you Mr Lam Wei Man
Old 08-09-2003, 12:33 AM   #8408
AMGRacer's Avatar
Ahhhhhhhhhhh
Old 08-09-2003, 12:34 AM   #8409
AMGRacer's Avatar
Contents of the conversion kit.
Old 08-09-2003, 12:35 AM   #8410
AMGRacer's Avatar
Team "Manticone" racing colours.
Old 08-09-2003, 12:37 AM   #8411
AMGRacer's Avatar
Naked. Dead stock EVO and conveted Jalopy.
Old 08-09-2003, 12:38 AM   #8412
AMGRacer's Avatar
Another. Guys I tried some detailed pics but my camera just sucks the big one on anything close up. We have to wait for "Manticone" to get his conversion done
Old 08-09-2003, 12:40 AM   #8413
AMGRacer's Avatar
Conversion kit rundown:
Nice graphite deck, better looking than the stock unit and more stiff.
The chassis is a damn work of art. Recess for lowering the throttle servo right down. Screws are countersunk at least 1mm into the chassis. Beautiful.
BEARING for the steering shaft. They are 6x10x4 jobbies.
All the required hardware included, took me about 3 hours to get where I am at right now.
Old 08-09-2003, 12:46 AM   #8414
You just did that to piss me off didn't you.
. . . waiting . . . . waiting . . . . waiting . . . . c'mon Monday
On a serious note, can the servo's be repaired?
Old 08-09-2003, 12:53 AM   #8415
AMG,
Is the top deck the same height above the chassis? - i.e. will a RR left side brace/tensioner fit?
I mean, like a 3Racing one or something.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
