Old 08-07-2003, 09:14 AM   #8356
Manticore's Avatar
R/C Tech Charter Subscriber
Manticore is offline   Reply With Quote
Old 08-07-2003, 09:23 AM   #8357
ernestf's Avatar
Send a message via ICQ to ernestf
manti, nice !
i will receive mine soon .... no more low CG tank from K-Factory
ernestf is offline   Reply With Quote
Old 08-07-2003, 09:26 AM   #8358
Manticore's Avatar
Originally posted by ernestf
manti, nice !
the k factory low CG fuel tank doesnt work very well indeed.
Old 08-07-2003, 03:55 PM   #8359
AMGRacer's Avatar
Some comments on the kit:
- Plastic is HARD. I had to grease the screws to get them in! It seems the material is similar to the associated "graphite" parts.
- Dry weight of the car BONE stock with everything minus fuel is 1806 grams. Legal IFMAR weight is 1725 so we are 81 grams over weight bone stock. Remember that that is using a AA 5 cell pack at 97grams. The AAA small packs are around 50 grams so there is 50 grams saving right there
- Some hand fitting required which I hate. The steering linkage was fiddly and you have to cut the underside of the floating mount since the top of the camber links hit under compression (this is wierd since I dont remember this happening with my RR)
- Rear arms are different. It seems that they have some material removed from the insides.
- The stickers which come with the car don't say EVO!! That sucks right there.
- Lola and sedan is accomodated.
- No body!!!!!!!!!!!!!!!!!!!!!! WTF?
- 35 shore tires front and rear are supplied. Who uses 35 shore?
- The kit setup has a ride height of 6mm front and 6.5mm rear. Seems too high to me!
- My drivetrain is tight from the get go due to the belts, needs some breakin.
- The steering rack runs on bushings not bearings!!
AMGRacer is offline   Reply With Quote
Old 08-07-2003, 04:26 PM   #8360
They look so nice... I can't wait to get mine (2 - 3 months away but still ) !
So AMG, I take it you get all the mounts and bumper etc. for using both a Sedan and Lola body?
V-One S Racer is offline   Reply With Quote
Old 08-07-2003, 04:36 PM   #8361
AMGRacer's Avatar
Yes you get a foam bumper style front and a lola style flat front.
Old 08-07-2003, 04:58 PM   #8362
AMGRacer's Avatar
Originally posted by Taylor-Racing
6 hours . . . sheesh . . . fast.
At that rate the throttle linkage should take you about .026573 seconds to finish - plenty of time to get in a couple of laps practice for the titles this weekend, yeah.
BTW, looks good.
Hope we have ours before the weekend - a slim hope.
Yeah I was surprised how fast it went together. I was not rushing it really, just worked steady. I spent 2 hours on the shocks and the top deck/wiring alone
The throttle linkage is annoying the throtle side of the servo needs to be 8-10mm long and the brake side 18-20mm long so you have to cut up a servo horn etc.
Old 08-07-2003, 06:13 PM   #8363
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
AMG
Do you mind to post the picture of the rear arms??
tl2111 is offline   Reply With Quote
Old 08-07-2003, 06:24 PM   #8364
AMGRacer's Avatar
Originally posted by tl2111
AMG
I can try but my camera sucks for close up work. I will describe it for now and try some pics tonight.
The arms are exactly the same in terms of their overall size and dimensions. The inner bracing has a relief cut out of it which looks to me to be designed so that it will clear the diff outdrive/dogbone on serious upwards compression. However when I play with the arms they miss these areas by miles. Wierd.
The new arms are VZ004B.
Old 08-07-2003, 06:27 PM   #8365
AMGRacer's Avatar
Hahaha I just realised how dumb my car looks sitting on my stove Tire warmers for foam tires!!!!!
It it an impressive looking thing in the flesh even bone stock as it is. Very low looking (even the tank) and with the body on only the handle and tank is visible thru the windows!!
Old 08-07-2003, 06:32 PM   #8366
AMGRacer's Avatar
Originally posted by EVOLUTION
Bloody kyosho,i help them with all that R&D and all they give me in return is my name in gold on there boxes!!!
AMG,how was the assembly and parts fit etc?
No,close up pics?
Assembly was very very quick for me, but I am a Kyosho "expert" now and I can build them in my sleep
Parts fit is good as is usual for Kyosho.
Negative things:
- Steering arm linkage is fiddly (need to cut two ball ends down by 3mm).
- The steering pivots on bushings. I mean come on.
- The top camber links now hit the floating mount under full suspension compression!! You have to cut some reliefs into the mounts according to the instructions. I dont remember this from the V1RR?????
- The plastic is now so damn hard I could not physically force some screws in without greasing them!!
Old 08-07-2003, 08:16 PM   #8367
Manticore's Avatar
kyosho has used new material not only front suspension part? the old rear end has the new material as well?
I use 35 shore, send them to me please !!
Old 08-07-2003, 08:17 PM   #8368
Manticore's Avatar
Negative things:
your next challenge is to "win" a race in your sleep !
Old 08-07-2003, 08:30 PM   #8369
Newbie here at this forum...and waiting for my Evo to come. Do you happen to know the size of that bushing? Many Thanks!
adlawoo is offline   Reply With Quote
Old 08-07-2003, 08:31 PM   #8370
AMGRacer's Avatar
Yep I could not get the screws into the rear bulkheads!! Had to use grease............
I will send you the 35........................
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
