Old 08-05-2003, 07:28 AM   #8311
Taylor-Racing's Avatar
Default 0.8 Pinions
Originally posted by Manticore
i've just got "some" from harmony today ! dunno if he has reserved one for you yet !
Manti,
Do you know if Mr Lam has some 0.8 pinions in stock?
I'm looking for a 19T 1st. and a 25T 2nd.
Taylor-Racing is offline   Reply With Quote
Old 08-05-2003, 07:30 AM   #8312
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: 0.8 Pinions
Originally posted by Taylor-Racing
Manti,
yes he does but dunno if he has the spec you want !
Manticore is offline   Reply With Quote
Old 08-05-2003, 07:43 AM   #8313
Default Re: Re: 0.8 Pinions
Thanks - will give him a try.
Old 08-05-2003, 07:43 AM   #8314
dtm
dtm's Avatar
Send a message via ICQ to dtm
Manti,
Not yet in stock.....only 22T and 27T....will have to wait.
Spur gears 55T and 60T are available though...
dtm is offline   Reply With Quote
Old 08-05-2003, 08:24 AM   #8315
Thanks dtm,
Damn . . might have to use the old gears till the new ones turn up.
It's good to know the 55T and 60T spurs are available, though they make for a larger spread than I wanted for a smaller track.
Cheers.
Old 08-05-2003, 08:41 AM   #8316
dtm
dtm's Avatar
You may be out of luck. I just looked at the gear ratio chart and 1st gear pinion only goes down to 20T!
1st gear pinions 20, 21, 22T
1st gear spur 59, 60, 61T
2nd gear pinions 25, 26, 27T
2nd gear spur 55, 56T
You may have to wait for Kawahara to come out with something....
Old 08-05-2003, 08:46 AM   #8317
Manticore's Avatar
kyosho has less pinion choice then mugen.
Old 08-05-2003, 11:45 AM   #8318
Trader Rating: 49 (100%+)
Default VoneR to evo ?
Can you upgrade a box stock VoneR to the EVO? What are the main differences. Are there any extra parts needed?
thanks.
rodneybarrett is offline   Reply With Quote
Old 08-05-2003, 05:56 PM   #8319
Default EVO Pinions
I was just wondering if anyone knows if the .8 pitch mugen pinions will fit the evo?? Hopefully it will work and solve the problem seein as gav and my evo kits and conversion kits are on the boat as i post.
Dexter is offline   Reply With Quote
Old 08-05-2003, 06:51 PM   #8320
AMGRacer's Avatar
Default Re: EVO Pinions
Yes they will fit. The pinions and gears are actually known as .8 MODULE. I believe this refers to the size of the teeth on the pinion. (I think this is right or close) 1 module refers to a tooth size and spacing where 32 teeth fit on a gear 1 inch in diameter. .8 module means that 32 teeth fit on a .8 inch diameter gear.
Long and short is .8 module pinions and gears will always mesh together since the teeth are the same size. The only time you have a problem in RC is when the motor mounts do not have sufficient movement to fit since one manufacturer uses pinions of a radically different diameter to another. The Mugen and Kyosho diameters are very close in terms of the number of teeth. Worse case scenario is you have to file the chassis mount holes a little to make it fit.
AMGRacer is offline   Reply With Quote
Old 08-05-2003, 06:53 PM   #8321
AMGRacer's Avatar
Default Re: VoneR to evo ?
thanks.
Yes you can Kyosho kindly provide a conversion kit.
http://www.kyosho.co.jp/rc_model/tou...version-e.html
Here are the main parts:
Old 08-05-2003, 09:44 PM   #8322
esham's Avatar
Default Spare Parts for V1 Evo
Hello everybody, If I order conversion kit - Evo V1RR what are other parts that I should order ? Should I used Special belt for the 0.8 module Evo ?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 08-05-2003, 10:27 PM   #8323
vones's Avatar
Default Re: Spare Parts for V1 Evo
I think no need lah cos the 0.8 module only affects the spur n pinion only, unless the middle block position is also change to accomodate the longer frnt bulk head...
vones is offline   Reply With Quote
Old 08-05-2003, 10:45 PM   #8324
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Hello All Been a wile since I have been on this thread.
I see Manti is up to the same ol things Catch me on AIM sweet hart
Good to see all of you Down Under are still have good luck with the car, those god damn mugens are out of control up hear where I run.
But then again I have not ran my car in over 2 months
HEYALIGNMENTGUY is offline   Reply With Quote
Old 08-06-2003, 04:25 AM   #8325
Oooh, OK.
I guess it's no biggie since we can achieve the same thing with either spurs or pinions - but, yes, there isn't a lot of choice, is there.
So where can I get this "gear ratio chart"?
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
