Old 07-28-2003, 06:50 AM   #8236
dtm
dtm's Avatar
Send a message via ICQ to dtm
Here's another view......
dtm is offline   Reply With Quote
Old 07-28-2003, 10:39 AM   #8237
Fully Hopped's Avatar
Default Re: Re: evo conversion
Originally posted by Cilla
http://catalog.rcmodel.com.hk/
Kyosho - V-One RR Evolution Conversion Kit US$140.00
Products Model: KY-39300
Manufacturer: Kyosho
Products Weight: 750.00 g
7075 Hard Main Chassis (Optional Parts for V-One-RR Evo Kit)
Carbon Upper Deck (Optional Parts for V-One-RR Evo Kit)
Separated Front Bulkhead
Servo Saver Set
Soft Tower Bar
1st Spur Gear (0.8M)
2nd Spur Gear (0.8M)
Front One-way shaft
Front Swing Shaft
Middle Shaft
Front Suspension Plate
1st Pinion Gear
2nd Pinion Gear
6x10x3mm Ball Bearing
2nd Clutch Shoe
2nd Clutch Weight
2nd Clutch Spring
This product will be in stock on Friday 01 August, 2003.Conversion kit
Thanks Allot!! I appreciate it.
Fully Hopped is offline   Reply With Quote
Old 07-28-2003, 11:57 AM   #8238
delete
Old 07-28-2003, 12:32 PM   #8239
ziggy12345's Avatar
Originally posted by dtm
Broken shock tower solution.........don't use one!!
Nice one!! Wheres the anti roll bar??
Cheers
ziggy12345 is offline   Reply With Quote
Old 07-28-2003, 03:18 PM   #8240
ziggy12345's Avatar
I didnt have the carbon piece like you have but managed to bodge something to get me racing anyway
Thanks for the tip!!
Cheers
Old 07-28-2003, 07:59 PM   #8241
thefuzzclub's Avatar
Default Re: Putting cray in the Diff...
Originally posted by tazman34685
I use 100,000 Wt Diff oil.. The key is to warm up the oil right after you put it in the car(run the car DON'T LET IT SIT Wait for something to dry, Just clean up the over spill, an go....
But the only problem is now that the rear end is planted can you drive the breast with one ways in the front. Do you run with only the Front Sway Bay or Both FR/RR... Check out the Sway Bars:
Tip : Try using the Inner lower setting in the rear It said to offer bester Rear traction.....
NO SWAY BARS, JST PLAIN STOCK SET-UP. DO I NEED ONE?
thefuzzclub is offline   Reply With Quote
Old 07-28-2003, 08:02 PM   #8242
Default Re: Re: shock oil (front and rear)
Originally posted by esham
I used 40 wt Trinity shock oil - front and 30wt Trinity shock oil - Rear.
This can be very subjective depend on the track condition. I suggest ask the local racer that manage to get their car smooth. Otherwise have to use experiment If the 40/30 wt still bummpy than use 40/10 !? Others? What do you say man..
Spring tension can fool us sometime even you used correct wt shock oil. So have to get good combination. Try to reduce the rear tension first and try that.
THANKS FOR THE SUGESTION. I WILL YOUR RECOMENDATION.
Old 07-28-2003, 08:08 PM   #8243
Originally posted by AMGRacer
Shock oil is too subjective. Cannot guess your track with any accuracy. Very rough guess is:
Smooth and large track - 60-70wt front and rear
Smooth and medium/small track - 50wt front and rear
Bumpy and large track - 40-50wt f/r
Bumpy and small - 30wt f/r
Try from there. Look how your car reacts over bumps. If it is getting airborne you need to use softer springs and oil together. Hard spring and soft oil does not work in some cases and does in others.
Play some and observe the car then ask back here and we can help more.
ONE TRACTION TEST I GOT IS TO LIFT THE REAR END OF YOUR CAR THEN DROP IT. IF IT BOUNCES 1 OR 2 TIMES, THE CAR WILL ALSO BOUNCE ON ON BUMPY TRACKS. IF IT DOESNT, LIKE WHEN YOUR DROP IT THERE'S NO BOUNCE AT ALL(IMAGINE A CAT JUMPING FROM A TREE TO THE GROUND) THEN YOU CAN EXPECT THE CAR TO BE STEADY AND GET HIGH TRACTION. I DONT KNOW IF I MAKE SENSE HERE.
Old 07-29-2003, 05:18 PM   #8244
AMGRacer's Avatar
I just got word today that Mr Lam has V1RR Evolutions available from today!!
I have put in my order for one from Harmony Models in HK.
AMGRacer is offline   Reply With Quote
Old 07-29-2003, 08:33 PM   #8245
Vinyard's Avatar
Sweet! I want one!
Vinyard is offline   Reply With Quote
Old 07-29-2003, 08:44 PM   #8246
F&K
F&K's Avatar
Hi guys,
What are the advantages of using the aluminum pulley against those plastic one that come with the kit? Are they worth to replace?
F&K is offline   Reply With Quote
Old 07-29-2003, 08:57 PM   #8247
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by F&K
Hi guys,
the advantage is claimed to have less friction but the downside is heavier and it wears fast. I stick with plastic pulley.
Manticore is offline   Reply With Quote
Old 07-30-2003, 12:20 AM   #8248
F&K
F&K's Avatar
Hi Manticore
You mean the belt or the pulley that wear faster?
TKS
Old 07-30-2003, 12:21 AM   #8249
Manticore's Avatar
Hi Manticore
TKS
the pulley
Old 07-30-2003, 01:44 AM   #8250
esham's Avatar
Where I can get Kyosho option parts ( LSD, Aluminimum Diff housing etc ) online ? Anybody ?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
