Old 07-27-2003, 08:22 PM   #8221
InitialD's Avatar
Default Re: PUTTING CLAY IN DIFFERENTIAL
Originally posted by thefuzzclub
Someone told me a technique instead of hard oil, you can put modelling clay in the front differential to tighten it. Is this effective and advisable? Need your thoughts please. tks.
It can be done. What we use to do is to put Serpent cleaning gum /putty into the gear diffs.
The plus part is that you get a hard diff close to solid but less hassle of fluid leakings through the diff. If you're looking something close to a solid (very hard setting), then this would be it.
Old 07-27-2003, 10:22 PM   #8222
thefuzzclub's Avatar
Default Re: Re: PUTTING CLAY IN DIFFERENTIAL
DO YOU NEED TO MIX? OIL AND CLAY? OR JUST PLAIN CLAY ITSELF.
thefuzzclub is offline   Reply With Quote
Old 07-28-2003, 12:46 AM   #8223
Default shock oil (front and rear)
What oil do you guys use in your shocks? The rear of my car bumps a lot on bumpy tracks. I see other racers run their car smoothly even on bumps. They say to change my oil to a harder one but did not mention the weight. I use the black stock springs for both front and rear. I hop you can help me.
Old 07-28-2003, 01:59 AM   #8224
esham's Avatar
Default Re: evo conversion
Originally posted by Fully Hopped
where can I buy this?
You can get it from http://shopping.rcmodel.com.hk but the stock will availabe on 1 August.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 07-28-2003, 02:04 AM   #8225
esham's Avatar
Default Re: shock oil (front and rear)
I used 40 wt Trinity shock oil - front and 30wt Trinity shock oil - Rear.
This can be very subjective depend on the track condition. I suggest ask the local racer that manage to get their car smooth. Otherwise have to use experiment If the 40/30 wt still bummpy than use 40/10 !? Others? What do you say man..
Spring tension can fool us sometime even you used correct wt shock oil. So have to get good combination. Try to reduce the rear tension first and try that.
Old 07-28-2003, 02:10 AM   #8226
http://catalog.rcmodel.com.hk/
Kyosho - V-One RR Evolution Conversion Kit US$140.00
Products Model: KY-39300
Manufacturer: Kyosho
Products Weight: 750.00 g
7075 Hard Main Chassis (Optional Parts for V-One-RR Evo Kit)
Carbon Upper Deck (Optional Parts for V-One-RR Evo Kit)
Separated Front Bulkhead
Servo Saver Set
Soft Tower Bar
1st Spur Gear (0.8M)
2nd Spur Gear (0.8M)
Front One-way shaft
Front Swing Shaft
Middle Shaft
Front Suspension Plate
1st Pinion Gear
2nd Pinion Gear
6x10x3mm Ball Bearing
2nd Clutch Shoe
2nd Clutch Weight
2nd Clutch Spring
This product will be in stock on Friday 01 August, 2003.Conversion kit
Cilla is offline   Reply With Quote
Old 07-28-2003, 02:18 AM   #8227
Default Re: Re: shock oil (front and rear)
thanks for the suggestion. the thing is sometimes fast racers here tend to secret their recipe. probably selfish and afraid to get beaten someday. I'll try to ask the others too. thanks again bro.
Old 07-28-2003, 02:25 AM   #8228
AMGRacer's Avatar
Shock oil is too subjective. Cannot guess your track with any accuracy. Very rough guess is:
Smooth and large track - 60-70wt front and rear
Smooth and medium/small track - 50wt front and rear
Bumpy and large track - 40-50wt f/r
Bumpy and small - 30wt f/r
Try from there. Look how your car reacts over bumps. If it is getting airborne you need to use softer springs and oil together. Hard spring and soft oil does not work in some cases and does in others.
Play some and observe the car then ask back here and we can help more.
AMGRacer is offline   Reply With Quote
Old 07-28-2003, 03:09 AM   #8229
tazman34685's Avatar
Lightbulb Tire cutting????
The question : You have a New set of JAco Nitro Shoe, 40s for the Fr. and the same in the Rr of your V1R, Do you 1) Put them up on the Tire tuner. (Cutting them down for True CG)?? 2)Just put traction compound on them or 3) do both?? The Track will it a big boy The racing starts Saturday the 2nd. Check out the TRack:
tazman34685 is offline   Reply With Quote
Old 07-28-2003, 03:19 AM   #8230
Post Putting cray in the Diff...
I use 100,000 Wt Diff oil.. The key is to warm up the oil right after you put it in the car(run the car DON'T LET IT SIT Wait for something to dry, Just clean up the over spill, an go....
But the only problem is now that the rear end is planted can you drive the breast with one ways in the front. Do you run with only the Front Sway Bay or Both FR/RR... Check out the Sway Bars:
Tip : Try using the Inner lower setting in the rear It said to offer bester Rear traction.....
Old 07-28-2003, 03:19 AM   #8231
Sp Racer's Avatar
I've been using Nitro Shoes, I 've found that they work really well around the 60mm dia mark, so yeah, I guess that I would be truing them down to at least 62 mm to start with, they are like 66mm (huge) from new!
Sp Racer is offline   Reply With Quote
Old 07-28-2003, 03:27 AM   #8232
AMGRacer's Avatar
Default Re: Tire cutting????
Depends on what effect you want. Less foam makes for better traction in high grip circumstances. On very high grip tracks start at 58-57mm for optimal performance. You don't need to do this, but the car does handle better.
Old 07-28-2003, 03:57 AM   #8233
Disney's Avatar
Default Re: Re: Tire cutting????
Disney is offline   Reply With Quote
Old 07-28-2003, 06:35 AM   #8234
ziggy12345's Avatar
AAAAAGGGHHHHH!!!
My rear shock mount just broke. Anybody know where i can get one ASAP? Nobody in the UK has any as they dont stock the car.
ziggy12345 is offline   Reply With Quote
Old 07-28-2003, 06:42 AM   #8235
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by ziggy12345
AAAAAGGGHHHHH!!!
Broken shock tower solution.........don't use one!!
dtm is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
