Old 07-20-2003, 06:40 PM   #8131
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Originally posted by AMGRacer
Testing was at Meakin Park. I also went back to the standard V1R rear end (no floating mount) for testing and I could swear (again no firm data here) that it is better on the direction change.
Oh yeah all I can say is USE JOHN HAMMOND FUELS. This stuff is unbelievable.
AMG
I found the same standard rear end works better in changing directing. thats probably the reason why the JAPs has gone back to it when they run sedan body
did U have EVO car kit or the converion???
37F thats good news. no more traction roll.
tl2111 is offline   Reply With Quote
Old 07-20-2003, 07:27 PM   #8132
AMGRacer's Avatar
Still have not had word from HK about the EVO kit. Waiting very impatiently.
AMGRacer is offline   Reply With Quote
Old 07-20-2003, 08:20 PM   #8133
tl2111's Avatar
So the test U have done is on the old car??
Old 07-20-2003, 08:55 PM   #8134
InitialD's Avatar
The lack of rear downforce with the use of standard rear end makes the direction changes of the car better.
Old 07-20-2003, 08:56 PM   #8135
InitialD's Avatar
BTW What is an X50F??
According to Jaco, they are made from special compound which gives you better turn in and steering. Ideal for small and tight technical tracks. Only available for the front.
Old 07-20-2003, 10:56 PM   #8136
AMGRacer's Avatar
Yes V1RR GT.
Old 07-20-2003, 11:38 PM   #8137
tl2111's Avatar
Yes V1RR GT.
Just to share my recent setup in moorebank, which have my first 16 laps in qualify and finished 85laps in 1/2 hour final, car feels good except not enough punch with 24T conversion and the lap times is actually similar compare to without the conversion, but it's very smooth to drive the car, it can roll in and out the corner. have to run very small tyre to avoid traction roll.
more testing still to come before going to NATS.
Here is my setup if anyone interested
front
one way
droops -1
toe -1
castor 1mm in front
spring light blue
oils 50wt
swaybar 90 degree
tyres GRP 45sh 56mm size
ride height 4mm on above tyre size
rear
droops +5
toe +1.5
spring gold
oils 60wt
swaybar black (shortened)
LSD w 8000wt
tyres ATS 42sh 58.5mm
ride height 4.5mm on above tyre size
Old 07-21-2003, 03:41 AM   #8138
finchy's Avatar
AMGRacer I must also say that John Hammond Fuels are the best I used, prior to his fuel I used Jungle Jooze it was also of high quality but also of an extremely high price. So you think that the touring car rear end is better, that's interesting I have been told that buy Mr Silvers as well. I suppose I should try it out hey.
finchy is offline   Reply With Quote
Old 07-21-2003, 12:23 PM   #8139
front
one way
droops -1
toe -1
castor 1mm in front
spring light blue
oils 50wt
swaybar 90 degree
rear
droops +5
toe +1.5
spring gold
oils 60wt
LSD w 8000wt
What mounting holes for your shocks did you use front and back?
KingWillie is offline   Reply With Quote
Old 07-21-2003, 05:40 PM   #8140
tl2111's Avatar
front is in normal position
rear is in mid hole on the standard shock mount
btw rear top link is lower inside, upper on outside upright.
Old 07-21-2003, 11:15 PM   #8141
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Wow Tommy, 85 laps in 30mins is quick
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is online now   Reply With Quote
Old 07-22-2003, 12:44 AM   #8142
tl2111's Avatar
michael
Quick I don't think so, with the traction like now it should be at least 89 lap to give yourself a victory
Old 07-22-2003, 12:57 AM   #8143
Michael_T's Avatar
michael
I am way behind time
6 Months ago, this would be easy A main win!
Old 07-22-2003, 01:21 AM   #8144
tl2111's Avatar
with the pace you have at NSW title, you should easily doing 89-90laps no problem
Old 07-22-2003, 01:36 AM   #8145
Michael_T's Avatar
Ahh, those were the days
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
