Old 07-14-2003, 05:21 AM   #8101
Taylor-Racing's Avatar
Originally posted by finchy
Taylor Racing how did you go on the weekend. 5th in the final is all I could acheive this meet. Driving has gone to CRAP.
Hey, fifth is alright. If we got fifth, consistantly, I'd be happy - we would have been 7th or 8th today. And if it's any consolation, my driver has just been through a long doldrums period. He seems to have come out of it as misteriously as he went in.
Our day . . . not good.
Spent Saturday evening replacing pulleys/belts and rebuilding the rear diff.
Well, I should have checked the diff output cups, shouldn't I.
At the track, the rear end was bouncing around all over the shop due to the notched output cups. My temporary remedy was to but some fuel tube into the cups to keep the doggies out of the notch's. It sorta worked but the diff pulley parted company from the diff at the 17 minute mark of a 30 minute final. - I had the larger screws in too.
The printer was playing up so I have no idea of times etc. - not that ours would have been impressive.
Now the UP side.
Those SP belts really are smooth. The car has noticeably better free roll, and it was pretty good before. It might get even better with a few more runs - I like 'em.
Main experiment for the day was the overdrive stuff. We were running faily soft tyres 37/37 and while tyre wear was a bit high, the relative front to rear wear was pretty good. After 3 x 5 minute heats and all the practice & warm-ups etc., the 4mm split was down to a 3mm split - not bad, I thought.
For a 30 minute final we should have gone to 40/40 but since I figured we could control the wear, we decided to put up with the extra grip and just changed the rears for some correct sized 37's.
Diff's eh . . . bugger.
This improved tyre wear has me thinking about that solid rear again, though.
Taylor-Racing is offline   Reply With Quote
Old 07-14-2003, 05:27 AM   #8102
Originally posted by AMGRacer
Yeah that does not show up well on my 12 inch green screen
(Seriously I did my first 2 years of my IT degree on green and black screens!! We dont know how good we have it now!!)
Gawd . . you didn't have an ergonomic, eye-safe amber one, then?
Gee the crap they used to spin over amber screens was close to criminal.
Then again, 640K was also supposed to be enough for anyone, acording to Bill.
Old 07-14-2003, 05:28 AM   #8103
Sp Racer's Avatar
I knew there had to be a reason behind that , I noticed it on your car last weekend...I thought it was soft, big diameter tyres...
One way front diff is back in my RR...I will also be trying TCD diff in the front and rear...should be interesting..
LS
Sp Racer is offline   Reply With Quote
Old 07-14-2003, 05:30 AM   #8104
Kyle Hazell's Avatar
Trader Rating: 17 (100%+)
Default 3D and 4D Clutches
Hi Guys,
The 3D clutch is pretty good as long as you use the hard spring wound in to somewhere between 2.2 to 2.3 mm. Most of the times i use the std shoe however in high traction the red shoe seems to be the go.
The new 4D clutch is pretty much the same as the Mugen one. One main difference with the new clutch is the spring is longer than the one used in the 3D unit so make sure you dont mix them up as time goes by. Everything else is the same but turf the clutch shoe that comes with it and get the grey and red option ones.
Regards
Kyle
Kyle Hazell is offline   Reply With Quote
Old 07-14-2003, 05:40 AM   #8105
Default 3D or 4D (Not a bra size)
Now about this 4D clutch question . . .
The Kyosho Japan site talks about the EVO having a 3D clutch.
I'm sure I read somewhere about it coming with the 4D clutch, didn't I?
What gives?
http://www.kyosho.co.jp/main-e.html
Old 07-14-2003, 05:52 AM   #8106
LS
Your right, I should have twigged to that bouncing earlier - you and I even talked about it. It got a lot worse last Sunday
You mean you were running the RR with a front diff.
I've only heard good things about the TCD, but will try the Negative out first, since we have the bits - need the special Kawahara diff shafts.
Who does Kawahara spares in Australia?
OZDC was talking about a solid front axle - he says "unbelieveable under brakes"
Old 07-14-2003, 05:57 AM   #8107
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Default Re: 3D or 4D (Not a bra size)
What gives?
Gavin U mean 33D or 44D bra size
FYI in Kyosho website did mention car kit come with 3D clutch.
and 4D only goes with the New Fantom.
tl2111 is offline   Reply With Quote
Old 07-14-2003, 06:21 AM   #8108
Default EVO comes with 3D clutch
They do include the hard spring not sure about the clutch shoe. Hope to have mine built before the week is over. Will post pics and thoughts then.
Nemesis is offline   Reply With Quote
Old 07-14-2003, 06:22 AM   #8109
Default Re: Re: 3D or 4D (Not a bra size)
Ahhh . . but I don't measure from right around the back, there.
That'd be right . . the 4D clutch will be held in reserve by the Kyosho bean counters forward profit estimates comittee, to be released in six months time as the "Team" 4D clutch, represented by another teat on the V-one cash cow. . . . . just keeping the bra theme going.
Old 07-14-2003, 06:25 AM   #8110
Default Re: EVO comes with 3D clutch
Thanks Nemesis, but . . .
Looking forward to your thoughts on the new car.
Old 07-17-2003, 04:04 AM   #8111
finchy's Avatar
Gents the thread slipped into page 2, that's not good.
finchy is offline   Reply With Quote
Old 07-17-2003, 04:17 AM   #8112
It's dead in the ozzie one too . Hopefully me and gav will be ordering our evo's but i think that the FW05R might be a decent car aswell. I'm also still not sure what adds all this extra weight to the evo to pump it up to 1900g's.
Dexter is offline   Reply With Quote
Old 07-17-2003, 04:28 AM   #8113
Pardon my ignorance - what's a FW05R?
Old 07-17-2003, 04:47 AM   #8114
ziggy12345's Avatar
The new Kyosho shaft drive. Its on the Kyosho japanese web site, sorry dont have a link
ziggy12345 is offline   Reply With Quote
Old 07-17-2003, 05:22 AM   #8115
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Here's the link.
eddiethefish is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
