Old 06-27-2003, 01:05 AM   #7981
esham's Avatar
Hello, If i change the standard stock front pulley from 27 to 25 is it will make the front wheel abit faster tahn the rear? (Front Overdrive) And what will be the advantage?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 06-27-2003, 02:30 AM   #7982
AMGRacer's Avatar
Yes front wheels are faster than rear.
You need to true front tires 4.5mm smaller than rear tires to retain 1:1 drive. The advantage is that the smaller front tires make the car handle well while the rear wheels remain large to retain a decent drive ratio.
AMGRacer is offline   Reply With Quote
Old 06-27-2003, 12:57 PM   #7983
Default EVO Part numbers and pics
The V-one RR EVO parts and partnumbers are at the japanese side of the kyosho web site!!
And here is the conversion kit:
http://www.kyosho.co.jp/rc_model/tou...version-j.html
Finnitro is offline   Reply With Quote
Old 06-27-2003, 11:05 PM   #7984
Manticore's Avatar
R/C Tech Charter Subscriber
the conversion kit will be a limited offer
Manticore is offline   Reply With Quote
Old 06-27-2003, 11:19 PM   #7985
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Then you might want to get 2 of them
HEYALIGNMENTGUY is offline   Reply With Quote
Old 06-27-2003, 11:22 PM   #7986
vones's Avatar
That means other than the conversion on the V1-RR...other things/functions remain the same right...?
vones is offline   Reply With Quote
Old 06-27-2003, 11:51 PM   #7987
Manticore's Avatar
no, i will get n of them where n is ever increasing !
Old 06-28-2003, 01:39 AM   #7988
VoneRkid's Avatar
Lightbulb V-One RR evolution conversion kit
The conversion kit which " evolution " specification modifies the stock " V-One RR " machine in appears. The new part " of V-One RR evolution " business standard is equipped in this kit, furthermore is not included in the chassis kit " 7075 hard main chassis (the Noc.tsw13)" with " the carbon upper plate (the Noc.vzw051)" to it belongs. These all sets. Forcefully from single item purchase profit special edition.
*It is the limited commodity. The case of absence of stock please pardon.
1) You show light maneuverability with the chassis design which also centralization of mass carries out simultaneously.
2) To 4mm long with the front suspension arm which is converted and the bulkhead which is made to convert narrowly, it optimizes the camber change at the time in stroke.
3) With the upper arm pivot section of another body structure, change in camber angle setting possibility.
4) The front section substantial second look e.g., horizontal ranging it does steering wheel servo. It achieves battle power improvement.
5) You install one-way unit on the front. Loss at time of effective use and no load of traction thoroughness removal.
6) Shoe type 2 speed A/T, 3d clutch standard equipment. Furthermore with 0.8 module gears, it actualizes the running of the high efficiency which does not remove the power band.
Attachment part summary
< VZ100 > Front bulk < VZ109 > Servo saber nut
< VZ101 > Front suspension arm set < VZ110 > Servo saber spring
< VZ102 > Servo saber & holder < VZ111 > Middle shaft
< VZ103 > Small article part < VZ113-61 > 1st gear spur gear (0.8m/61t)
< VZ105 > One-way shaft < VZ114-56 > 2nd gear spur gears (0.8m/56t)
< VZ106 > Front swing shaft < VZ115-21 > 1st gear gear (0.8m/21t)
< VZ107 > Servo saber shaft < VZ116-26 > 2nd gear gears (0.8m/26t)
< VZ108 > Servo saber pipe < VZ117 > Front suspension plate
Damo
VoneRkid is offline   Reply With Quote
Old 06-28-2003, 10:28 AM   #7989
kevink2's Avatar
So, no new rear roll center adjustments on the EVO?
kevink2 is offline   Reply With Quote
Old 06-28-2003, 01:05 PM   #7990
DOMOisCOOL's Avatar
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Nice! Does it come with the 3D clutch itself? I have a regular one because I use a threaded crank engine. Hmm...
DOMOisCOOL is offline   Reply With Quote
Old 06-29-2003, 04:17 PM   #7991
AMGRacer's Avatar
I am not totally sure it will be needed. The Kyosho has always had better rear geometry than the MTX2 and with a lowered CG the rear roll centre will more closely match the overall car CG resulting in less roll anyway. I would have prefered the more adjustable approach but I think it may pan out ok.
I actually am usually chasing steering with my V1R and I often use lower shore front than rear tires. If these front mods aid the steering whilst retaining the rear stability (they should) then I will be happy
Old 06-29-2003, 04:23 PM   #7992
AMGRacer's Avatar
The conversion is missing a few parts from the EVO. Namely the improved clutch and the lowered engine mounts.
Old 06-30-2003, 01:10 AM   #7993
finchy's Avatar
Default need a measurements
Can anyone help me with some measurements. I would like to machine down my flywheel to suit some lowered engine mounts.
The fly wheel O/D is 35.7mm
New engine mounts are 14.5mm high.
I am using stock chassis as well, Will I have to flute the flywheel hole in the chassis to have enough clearance.
Any help would be greatly appriciated.
finchy is offline   Reply With Quote
Old 06-30-2003, 01:12 AM   #7994
finchy's Avatar
Good to see you AMGRacer and xray vision yesterday down the track. You should come more often.
Old 06-30-2003, 01:41 AM   #7995
AMGRacer's Avatar
Yeah man whenever I finish my renovations and get some time will ome to brendale!! I cant get the go ahead from the boss at the moment to go racing for a whole day
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
