Kyosho VoneR Thread >
Kyosho VoneR Thread
Like Tree1Likes
Kyosho VoneR Thread
Old 06-24-2003, 07:46 PM
  #7936
TBR
TBR's Avatar
There is nothing wrong with the Kyosho 3D clutch it is just people have found the Mugen one to work better for them.
TBR is offline
Old 06-24-2003, 09:48 PM
  #7937
So it's just only for some people,and it is not really proven.
Cilla is offline
Old 06-24-2003, 10:04 PM
  #7938
RClover's Avatar
This was once asked on this board, the Mugen clutch is much lighter than Kyosho, i guess!
RClover is offline
Old 06-24-2003, 10:25 PM
  #7939
vones's Avatar
The stock mugen centax flywheel is smaller than the stock 3-D centax flywheel........weight reduction
vones is offline
Old 06-24-2003, 10:28 PM
  #7940
Manticore's Avatar
the mugen clutch is more reliable then the 3D.
the white flyweights on the 3D clutch melts/deforms under excessive heat n high temp.
Manticore is offline
Old 06-24-2003, 11:22 PM
  #7941
Originally posted by Taylor-Racing
Thanks, Manti.
I sort of presumed that was the case.
Any opinion on the Kawahara clutch? It looks very neat and compact?
We've been using Venom pinions lately - they seem to wear a lot better than the Kyosho ones. As a related question . . do we know any sources for alternative pinions/spurs available in the new .8 pitch?
Kawahara clutch is a nice little unit, Takes the abuse of a good modified .12 .
I have 2 of them on 2 differnt engines, but the only down size, I can see hear in the states is where to get replacement parts for it.
Might have to bumm some off of Manti
HEYALIGNMENTGUY is offline
Old 06-24-2003, 11:56 PM
  #7942
Manticore's Avatar
NP !!
Old 06-25-2003, 01:29 AM
  #7943
esham's Avatar
Originally posted by finchy
Taylor Racing it's 19T at the end of 2 speed shaft and 25T at the counter shaft. ( I thinks that's it correct me if I'm wrong ).
Errrr... sorry guys..What exactly Overdrive can give you is you set it on your RR? How we should set it ?
esham is offline
Old 06-25-2003, 01:35 AM
  #7944
esham's Avatar
Originally posted by VoneRkid
esham that is right. It is just for V one R/S Rear Carbon Shock Stay.
Damo
Pheww!
esham is offline
Old 06-25-2003, 03:22 AM
  #7945
finchy's Avatar
finchy is offline
Old 06-25-2003, 03:49 AM
  #7946
esham's Avatar
Originally posted by esham
Pheww!
I almost want to place order of that item.. which i can't fixed it on my V1RR
esham is offline
Old 06-25-2003, 03:53 AM
  #7947
AMGRacer's Avatar
It will fit the V1RR, but you will need to remove the floating rear end.
AMGRacer is offline
Old 06-25-2003, 04:59 AM
  #7948
finchy's Avatar
Talking of floating rear ends, do you think there is any advantage of this rear end as apposed to the standard rear end. I've heard some people think that's it's not really effective and the standard one is better.
finchy is offline
Old 06-25-2003, 05:00 AM
  #7949
finchy's Avatar
How's Adelaide treating you AMG.
finchy is offline
Old 06-25-2003, 05:19 AM
  #7950
VoneRkid's Avatar
Using the standard rear end would be like driving the V one S but I think the floating rear end is much better to drive with....
Damo
VoneRkid is offline
