Old 06-16-2003, 05:13 AM   #7861
finchy's Avatar
Yeah lock him in the canteen with Cashie.. Then they can trade top secret mugen setups. (j/k)
finchy is offline   Reply With Quote
Old 06-16-2003, 05:17 AM   #7862
Taylor-Racing's Avatar
Gentlemen,
My apologies for interrupting the cullinary persuits, but what is the pulley arrangement to achieve the RR overdrive. I have some RR pulley's coming.
Thanks in advance.
Taylor-Racing is offline   Reply With Quote
Old 06-16-2003, 05:21 AM   #7863
finchy's Avatar
Taylor Racing it's 19T at the end of 2 speed shaft and 25T at the counter shaft. ( I thinks that's it correct me if I'm wrong ).
Old 06-16-2003, 05:31 AM   #7864
TBR
TBR's Avatar
Any one want any cleaning tips while I'm here? I'm here to help any one?
TBR is offline   Reply With Quote
Old 06-16-2003, 05:40 AM   #7865
Thanks finchy.
I should have asked . . . I presume the tyre split for the O.D. pulleys is 3mm, yeah?
Old 06-16-2003, 05:44 AM   #7866
sparksy's Avatar
Trader Rating: 14 (94%+)
You know when you hit the back straight sweeper at full throttle for the first time and you kind of shit your dacks.... how do I gow about removing the stains....?
sparksy is online now   Reply With Quote
Old 06-16-2003, 06:08 AM   #7867
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Originally posted by Taylor-Racing
Thanks finchy.
to be exact, it will depends on what size rear is you are using. If u want exactly 1:1 split then at 54mm rear your front should be at 50mm.
the bigger the rear tyres, the large the split is but only in fraction though
hope this help
tl2111 is offline   Reply With Quote
Old 06-16-2003, 06:23 AM   #7868
hope this help
Ah, yes . . . it'll be proportional, of course.
Dammit, I'll have to do a spreadsheet, now.
Old 06-16-2003, 06:25 AM   #7869
Here's a pic of my driver's new shell.
Not a great pic, but I thought the transponder hole was amusing.
Old 06-16-2003, 06:38 AM   #7870
tl2111's Avatar
Don't worry too much, 4mm split is ok. You won't notice the different in 1% change. you'll only start to feel it when its over 4% in ODR, which in my example the front will be only 2mm smaller then the rear.
Old 06-16-2003, 06:40 AM   #7871
sparksy's Avatar
looks very cool
Old 06-16-2003, 06:53 AM   #7872
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by Manticore
those are displayed at the toy show in japan and pre-ordering has been started here. no one has this conversion kit as yet so I cannot tell you much about it !
I put my order in.....but I don't even know what I'm getting yet!!! Where did I put that RR of mine now??!!
dtm is offline   Reply With Quote
Old 06-16-2003, 07:46 AM   #7873
Thanks, sparksy.
Thanks tl2111.
On the EVO upgrade kit . . . .
I've been speculating over the list of parts contemplating how it all hangs together - most of them seem pretty obvious, BUT . . . . .
"Adjustable roll centre Front Bulkhead"
Is this supposed to accomodate the change in front end geometry introduced by the RR's Overdrive arrangements?
Months ago, I recall someone saying the Reflex had different front end geometry to the VoneR - a bit strange since it doesn't use an O.D. pulley system, I believe.
"Front Swing Shaft "
Why do you reckon we need new swing shafts?
I originally presumed it was to accommodate the new one way, but I expect the one way and the new mid shaft are needed to relocate the belt away from the new servo position.
What about the changes to the 2-speed clutch. I haven't heard of anyone having trouble with the original.
Old 06-16-2003, 07:56 AM   #7874
Manticore's Avatar
R/C Tech Charter Subscriber
Thanks, sparksy.
Thanks tl2111.
the front roll center has become adjustable with remove/add of the spacer that is attached to the front upper a-arm.
as for swing shaft, it is noticed that the front a-arms have become longer and that's why it comes with a whole new front oneway and swing shaft.
the 3D clutch (not the 2speed clutch) is not as good as mugen clutch i.e. kyosho has to improve it !
Manticore is offline   Reply With Quote
Old 06-16-2003, 02:07 PM   #7875
Originally posted by sparksy
Ive had 2 kfactory chassis.... both the 3mm and 4mm and on both I found the holes to be slightly out of wack.... either in the wrong position for the mid mount, or off center with the chassis....
Causing the sidebelt to be too tight, and the flywheel and clutch bell to have clearence issues.
I have had other k factory products for the v-one... and can make the claim that they have quality issues.
If yours is working fine, then all is good
Sparksy, my experience comes from my son's Reflex and the chassis I ordered specifically for my RR. I never heard this before about the placement of the holes. Thanks for letting me know though. I'll have to compare it to my original V1RR chasis. We have replaced the K-Factory pulleys and belts on my sons car as the pulleys just would not stop separatnig and well the belts just plain suck.
Have any other forum members had issues with K-Factory parts? Just curious, not trying to cause an up roar. Thanks
KingWillie is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
