Old 06-09-2003, 07:57 PM   #7741
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Default M1RR drivers, help!!
hi to all M1RR drivers,
need your input here. i recently installed the m1rr setup in the rear of my v1rr, its a LOT of difference in handling. v1rr rear droop was 6mm on hudy guage, m1rr was set to 6mm also, upper link's shim was tested using 4mm and it makes the rear loose. reduce the shim to 1mm and its better but not as stable as v1rr setup. next change was to reduce rear droop to 5mm with 1 mm shim, getting better but still not as stable as v1rr setup. so any advice on how i should proceed from here? the track is layed on a tennis court with good traction and minor bumps. thanks in advance.
alan.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 06-09-2003, 08:04 PM   #7742
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: M1RR drivers, help!!
alan.
some of us end up using 3mm shims and it works pretty well.
start using 2mm front and 8 mm rear droop and adjust from there
Manticore is offline   Reply With Quote
Old 06-09-2003, 09:06 PM   #7743
DOMOisCOOL's Avatar
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Hey guys here is my V One R:
DOMOisCOOL is offline   Reply With Quote
Old 06-09-2003, 09:32 PM   #7744
alana07's Avatar
Default Re: Re: M1RR drivers, help!!
thanks for the fast reply manticore. my front droop was at 2mm also. since u recommended 8mm rear droop, and i started out at 6mm (loose rear), too much weight transfer for my case=loose rear? anyway thanks again, i will try out your recommended settings next time i hit the track. oh one more thing, i realised the rear track width with m1rr mod using mtx 3 pillow balls reach slightly over 200mm, and the screw threads are almost fully threaded into the arms already. do you need to shorten the pillow balls or what needs to be done to stay within 200mm?
没有最好,只有更好!!!
Old 06-09-2003, 09:36 PM   #7745
Manticore's Avatar
Default Re: Re: Re: M1RR drivers, help!!
yep, shorten the pillow balls as well as the camber link.
Old 06-09-2003, 11:21 PM   #7746
alana07's Avatar
Default Re: Re: Re: Re: M1RR drivers, help!!
ok then, i'll just saw off around 3mm of the threads. you are using the mtx 3 upper links and pivot balls or using stock v1rr upper links and pivot balls?
没有最好,只有更好!!!
Old 06-09-2003, 11:26 PM   #7747
Manticore's Avatar
Default Re: Re: Re: Re: Re: M1RR drivers, help!!
need to use the original V1R or V1RR upper link
Old 06-09-2003, 11:30 PM   #7748
Manticore's Avatar
check this out
Old 06-09-2003, 11:48 PM   #7749
RClover's Avatar
that's one dusty R
RClover is offline   Reply With Quote
Old 06-10-2003, 01:30 AM   #7750
alana07's Avatar
check this out
thanks alot, manti!!
没有最好,只有更好!!!
Old 06-10-2003, 01:38 AM   #7751
opel92's Avatar
Originally posted by finchy
Yeah it was good to meet AMGRacer and Opel 92 today. Holy shit that motor in that RR is quick, it blew me away. Can't wait till Sunday it will be a gas. Once again excellent to meet you both.
Like wise gentlemen.......i cannot really come in to this forum here cos i don't know whether my torch batteries will last the distance . I think that i was around the times that Amg set with his stock MKII Spider........ The TL01 was really flying with that 6 single in it and the mechanical speedy held up well
opel92 is offline   Reply With Quote
Old 06-10-2003, 01:46 AM   #7752
opel92's Avatar
By the way Finchy............. were can i get one of those Sundials........ yours is ultra accurate!!!!!
Old 06-10-2003, 02:04 AM   #7753
finchy's Avatar
Well Opel92 that sundial I was using was a special factory team item but I've just received a new version today and beleive it or not it has a state of the art abacus with it the manual is quiet technical so I think it will take me sometime to work out how to use it.
finchy is offline   Reply With Quote
Old 06-10-2003, 02:13 AM   #7754
finchy's Avatar
AMGRacer I sussed out what I think is a really good setup for the track conditions we had yesterday. I'll fill you in on Sunday, also I'm interested in one of those magic head for my motor once again I'll talk to on sunday about it if not before.
Old 06-10-2003, 07:51 AM   #7755
Taylor-Racing's Avatar
Default Re: Re: R to RR
Originally posted by AMGRacer
That will do the rear end parts and the overdrive. You need the VZ008B pulley set (harder pulleys) which comes with the 25T pulley. Change them all for these harder ones. Also get the front and rear SP belt, the drivetrain is MUCH freer. There are also another plastic tree (forget number) with a transponder mount and the front lola bumper on it. Lastly dont forget the centax clutch if you want to go fully RR.
You can get some 3 racing rear clamping hexes with a 2mm offset on them which will make fitting the 30mm rears a breeze with no trimming.
The RR body posts are further forwards than the stock holes. Need to ream some more.
Whether the rear makes a big difference or not is up for conjecture. I would say that it makes the car more stable at high speeds. Dont know if that will translate into faster times.
Thank's AMG, that's just waht I wanted to know.
I notice that both the VZ008B and the VZ008 Pulley Sets are listed as being for V ONE R - presumably the "B" denotes the hard pulleys, yeah?
Also, can I presume that only the front pulley (side belt) is changed to a smaller one to achieve the overdrive, given that the RR side belt is three teeth shorter?
Yes, on the SP belts. I've been waiting months for the belts to wear out, to give me an excuse to change to the SP's. The new engine relieved us of the front belt last Sunday.
The 3 Racing hexes sound like a good idea - presumably 0 offset for the front?. I actually quite like the light placcy ones, but with use, they do seem to deform somewhat in the middle.
We're using the Fantom Centax. I know it's a somewhat heavier than the newer ones, but it's proven bullit proof enough. Maybe a new 4D one from the EVO . . . . maybe a whole new EVO.
Any opinion on improved rear tyre wear with the O.D. pulleys, and what tyre split are we supposed to run to achieve a 1:1 ratio?
(We have a three hour Enduro to run on Sunday. )
Is this the plastic tree with the bumper - it was on my list also. It's just that I don't see the transponder mount, unless it's the strange thing down the bottom.
Taylor-Racing is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
