Old 06-06-2003, 01:31 AM   #7681
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by esham
Guys... this weekend i'm going to join a race in form tires. So it will be my first form tires race... any advice on what to look for once I used rubber tires to form tires setting -tuning ?
Is the toe and camber should be ok for both ?
time is tight for you !! there is no absolute setting or one universal setting because different skill level, driving style, engine power and tire used !
you might want to go back several posts back and take the setting sheet as starting point.
Manticore is offline   Reply With Quote
Old 06-06-2003, 01:33 AM   #7682
esham's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Help locating negative diff
Originally posted by Manticore
hell no !! i used to be snaker !
Manticore...
I just bought LSD for my M1RR . What exactly this LSD will give us? And how should I handle the driving sytle and change ?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 06-06-2003, 02:22 AM   #7683
Manticore's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Help locating negative diff
Manticore...
it gives extra rear traction especially off power steering. the car has become more stable on the back straight and you may keep a more agile line.
Old 06-06-2003, 07:45 AM   #7684
baggiolee's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Help locating negative diff
Kyosho 1 or the kawahara 1 better??
baggiolee is offline   Reply With Quote
Old 06-06-2003, 07:53 AM   #7685
Manticore's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Help locating negative diff
TCD !!!
Old 06-06-2003, 01:02 PM   #7686
Que
Default What does TCD stand for
And where can i get one? It is more for low bite conditions right
Que is offline   Reply With Quote
Old 06-06-2003, 01:18 PM   #7687
TCD stands for Traction Control Differential and LSD stands for Limited Slip Differential.
Hello guys! I decided to register to this forum. I'm from Finland and have a hopped up V-one R.
Finnitro is offline   Reply With Quote
Old 06-06-2003, 01:36 PM   #7688
Que
What's the difference between the two? Pros and Cons
Old 06-06-2003, 01:52 PM   #7689
For my knowledge there is no difference. Both names are used for the same kyosho diff.
I have one too.
Old 06-06-2003, 09:17 PM   #7690
asd
Send a message via ICQ to asd
hey guys! im back from my long winter/srping Rc break=)
i fixed up my v-one-rr today after school and boi is she pertty
anyhow, i hope u all had a great winter and spring, later for now
asd is offline   Reply With Quote
Old 06-06-2003, 09:22 PM   #7691
Manticore's Avatar
Kyosho use the term TCD for their "TCD"
Welcome aboard !
Old 06-06-2003, 10:04 PM   #7692
Default Re: Shaft driven VOne RR..... ????
Looks like its a super10 chassis
---cut----
The day when finally the veil is dispersed did. Evolution edition of super ten, FW-0C5r!
No.31581
GP shaft drive 4WD touring car
FW-05 R chassis kit
The July last third Sale schedule
KYOSHO CUP " R " class official recognition. The shaft drive 4WD of preponderantly light drive type, 2 speed, in the 3d clutch, the long suspension arm and the ultralow center of gravity design et cetera which it is thorough, it actualizes the running which shows high aggressive power. Participating you are not wrong even with other 1/10GP touring car race/lace!
----cut---
Originally posted by CS Lo
Shaft drive V1R.
Is this the new shaft drive version of VoneRR ??
Ppl having talking abt it over here for sometime, but nobody can confirm....
Is it on sale now ? How much is the price ?
au_Nightmare is offline   Reply With Quote
Old 06-07-2003, 07:58 AM   #7693
baggiolee's Avatar
Welcome aboard !
any piece for the TCD??
Old 06-07-2003, 02:47 PM   #7694
VoneRkid's Avatar
Lightbulb The Adjustable Differential
Here is some info The Adjustable Differential
As stated on the main section page, the term adjustable differential is somewhat of a misnomer as the majority of differentials have some degree of adjustability.
The adjustable differential we refer to in this article is a relatively simple derivative of the open differential. Although there are different designs and implementations they work by the same principle as the example used here.
Adjustable differential that uses Belleville Washers to apply pressure to the sun gears.
This increases the resistance between the gears and stiffens the action of the differential.
As it is adjustable, the 'diffing out' associated with the open differential can be reduced or completely eradicated.
The adjustment is provided by a modified grub screw which allows quick and easy access for track side adjustments.
As far as the internal parts are concerned, they are the same ones that are fitted inside a normal open differential.
If not present on the non-adjustable type, steel thrust washers are fitted behind the the sun gears to stop the forces generated by the belleville washers wearing the casings.
Damo
VoneRkid is offline   Reply With Quote
Old 06-07-2003, 03:02 PM   #7695
VoneRkid's Avatar
Default Re: Re: Re: Re: Re: Re: rear droop
Emmm... that photo is cystal clear on the front droop setting.. thanks.
Here some more info on Suspension Droop
Suspension droop is defined as the amount of downward suspension movement there is in the wheels of a model car. The base measuring point for this droop can either be the chassis or the ride height of the car.
It is responsible for keeping the wheels in contact (or not!) when the front/rear of the car rises or falls - like going into a corner, braking/accelerating or going over bumps.
More droop obviously allows for more wheel travel to keep the tyres in contact with the track surface, but this is at the cost of agility - the car will not change direction as quickly.
The general rule of thumb with droop would be to have just enough to cope with the track you are racing at and no more.
You must also consider the affect that the damping and springing on the car has with increased droop as they have to be able to react quickly enough to move the wheel in and out of any holes, etc..
Damo
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
