Old 06-03-2003, 03:57 AM   #7591
AMGRacer's Avatar
Originally posted by drfritz
Thanks for the help, but after taking a closer look at the car, I am at max droop with the way the REAR pod is made.
If I want any more droop I will have to go to the standard shock tower in the rear.
I can see what you are saying, but I feel if you need this much droop you should look elsewhere for some solutions.
What is the handling problem you are trying to rectify?
AMGRacer is offline   Reply With Quote
Old 06-03-2003, 04:00 AM   #7592
AMGRacer's Avatar
Default Re: 'lil Help needed here....
Originally posted by KingWillie
...anyone here run in the states this weekend? I was at the Richmond, VA track and didn't quite burn up the pavement as you fella's seem to have done. Finished 4th in the A-Main, but had a difficult time of it...first race with my V1RR, I had been running the V1R GRP version until this weekend.
Broke a front belt while in 2nd and fell back to 4th, luckily there was only about a minute to go in the race when it broke. I'd like a little help with set-up suggestions, currently this is what I'm running:
Tires: 40F/35R it's still not too hot here and the track is not permanent
ride ht: 5.5F/6.0R
toe: +1 F/0 R
camber: 0/0
droop, I could use some help with, don't have any clue here
...go ahead and abuse me, but then a little help would be appreciated..thanks
Very difficult to help based on the info. What is the car doing that you do not like? Generally the camber at 0 is probably not good with foam tires. Also ride height seems a little high.
Old 06-03-2003, 04:03 AM   #7593
AMGRacer's Avatar
Default Re: Re: Re: 'lil Help needed here....
Black Springs F/R, shock oil F 80/R 60 (Team Losi silicone), shocks are mounted on the top (inside) and bottom (upper), upper arm position out (upper) in (upper), rear diff is kawahara neg diff.
Like to improve turn in, off power and turn exit on power....currently too much push
Shock oil is too stiff for those springs. I would go with no more than 50wt in general with the blacks. General rule only of course.
To get better turn in go stiffer front swaybar, one way front diff, or more caster for high speed turn in.
Generally the black springs in my opinion are too soft for foam tires except for lowish grip tracks. Try stiffening the car up evenly all around for more response.
Old 06-03-2003, 04:05 AM   #7594
AMGRacer's Avatar
Default Re: Re: Re: Re: Re: Re: Re: 'lil Help needed here....
35 rears, still pretty cool here 40 fronts
Using 40 front and 35 rear will induce push. Try 37 or 40s on rear.
Old 06-03-2003, 04:08 AM   #7595
AMGRacer's Avatar
Default Re: Re: rear droop
Originally posted by InitialD
Driving style and setup of car will dictate the type of rear droop which would benefit the car handling.
A car equipped with a front diff usually requires a lot of steering. Beginners will find it OK but experienced drivers will find it a little lacking. So more weight transfer to the front off power is nice to have. You achieve this by having a lot of rear droop.
With a one way, off power steering is generally more than normal drivers would require and generally, you want to take out off power oversteer in the car. You do it by limiting the rear droop to prevent weight transfer from the rear to the front. Of course too little droop will make the rear end lift up and cause your rear end to loose traction. Too much is always no good. Everything needs to be just enough.
This is generally good advice, but I would say on the V1RR you should look at tires and then springs first. Droop is more fine tuning.
Old 06-03-2003, 04:10 AM   #7596
AMGRacer's Avatar
Originally posted by Manticore
here you go
This is a darn good setup, but is pretty aggressive as well. Try slightly softer rear springs if it is too much.
Old 06-03-2003, 04:12 AM   #7597
finchy's Avatar
AMGRacer do you know if Tobee Craft have a web site, also what do you think about the quailty of the products.
finchy is offline   Reply With Quote
Old 06-03-2003, 04:28 AM   #7598
AMGRacer's Avatar
Dunno about a website. I used their shafts for around 9 months and they wore badly enough around the bearings to become useless. Very light however.
Old 06-03-2003, 04:34 AM   #7599
finchy's Avatar
I would like to get a light weight 2 speed shaft, what would you suggest maybe something by square perhaps.
Old 06-03-2003, 04:36 AM   #7600
rrgt_kid's Avatar
hi racers hear is a pic of my new gpm rear turret!
rrgt_kid is offline   Reply With Quote
Old 06-03-2003, 04:48 AM   #7601
rrgt_kid's Avatar
and another
Old 06-03-2003, 04:53 AM   #7602
Default Tobee Online
Tobee Craft Online, the sites a bit dodge but just like their products i guess.........
http://www3.kcn.ne.jp/~tobee/index.html
Dexter is offline   Reply With Quote
Old 06-03-2003, 04:55 AM   #7603
rrgt_kid's Avatar
my optional alloy brake holder on my rr
Old 06-03-2003, 05:06 AM   #7604
VoneRkid's Avatar
Here are some more pic of my RR
Damo
VoneRkid is offline   Reply With Quote
Old 06-03-2003, 05:10 AM   #7605
VoneRkid's Avatar
another pic
Damo
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
