Old 06-02-2003, 01:58 PM   #7576
Default Re: Re: Re: Re: Re: Re: 'lil Help needed here....
Originally posted by Manticore
what shore rate of tire you used? I find you will have coned tire from outside if you have softer tire and coned inside if you have harder tire.
35 rears, still pretty cool here 40 fronts
KingWillie is offline   Reply With Quote
Old 06-02-2003, 02:01 PM   #7577
Originally posted by Matlock
Straight from the XXX Main setup book:
Scenario A: Car pushes while entering a corner(Off power); Not enough weight is being transferred to the front tires relative to the rear tires;
Increase rear droop.
Thanks, I have the XXX book also. Could be things like Front Springs too soft, not enough toe out in the front, rear springs too hard, not enough rear droop.............
looking for some live advice from V1RR users this time, need a reference point to start with.
Old 06-02-2003, 02:06 PM   #7578
VoneRkid's Avatar
This is not a bad web site
Xtreme RC CARS
Damo
VoneRkid is offline   Reply With Quote
Old 06-02-2003, 05:07 PM   #7579
drfritz's Avatar
Talking about droop. I have ran into a small problem of not able to get enough rear droop with the floating rear end. The rear guide is bottoming out on the turtle. this is not a problem when I run on most tracks, but the local short track has some nasty bumps and the car gets really loose when I find them.
drfritz is offline   Reply With Quote
Old 06-02-2003, 05:57 PM   #7580
TBR
TBR's Avatar
Default Re: Re: Re: 'lil Help needed here....
Originally posted by KingWillie
Black Springs F/R, shock oil F 80/R 60 (Team Losi silicone), shocks are mounted on the top (inside) and bottom (upper), upper arm position out (upper) in (upper), rear diff is kawahara neg diff.
Like to improve turn in, off power and turn exit on power....currently too much push
Where do you have your front and rear shocks mounted dont quite understand what you are saying above?
TBR is offline   Reply With Quote
Old 06-02-2003, 09:00 PM   #7581
Default Re: Re: Re: Re: 'lil Help needed here....
Rear Shocks: top of shock mounting closest to center of car (inner) and bottom in upper mounting hole
Front Shocks are standard
Old 06-02-2003, 09:01 PM   #7582
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Re: Re: 'lil Help needed here....
i am looking for a setup sheet for parking lot on foams.
will let you know
Manticore is offline   Reply With Quote
Old 06-02-2003, 09:04 PM   #7583
Manticore's Avatar
here you go
Old 06-02-2003, 09:24 PM   #7584
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Originally posted by Taylor-Racing
Hi tl2111,
Hmmm, interesting . . . I always thought the MTX-3's looked slightly better coming out of corners.
Are you running a Lola body or Sedan? - same body each time?
Stratus 2.1 on both time, don't forget I run on sprayed track that has twisting the setup a bit, such as a lot of droop F/R.
tl2111 is offline   Reply With Quote
Old 06-02-2003, 09:26 PM   #7585
InitialD's Avatar
How is the car bottoming out possible with the rear floating mount? Should not be the case. The rear floating mount prevents the shocks from being compressed when the downforce acts on the body.
Probably on bumpy tracks, you need to increase the ride height a little. I think that sounds more like the solution to your problem.
Old 06-02-2003, 09:27 PM   #7586
InitialD's Avatar
if you want faster steering response for initial turn in, stiffen front sway bar or reduce front caster, or you can reduce rear droop but this is a bit too risky to do that.
You actually increase rear droop (say for example +7 to +5) to increase weight transfer to the front... Hence you get more off power steering.
Reducing rear droop makes the off power steering less but you increase rear stability when you apply brakes.
Old 06-02-2003, 11:56 PM   #7587
Manticore's Avatar
Default rear droop
Try this
1/. limit rear droop to "without droop" in the rear and try it.
2/. set more droop to the rear and run it again on the track, compare the result.
the results on each of the above could be varies due to different driving style, different setupof the car (front diff or front oneway)
weight transfer to front also means you have less traction to the rear. It will be forgiving if you have some droop in the rear but if you have less droop, one of your rear wheels could have been lift (in extreme case) and this cause loose rear end.
In general, the fast moment of weight transfer (front Vs rear) is due to softer suspension setup
Old 06-03-2003, 12:00 AM   #7588
drfritz's Avatar
Thanks for the help, but after taking a closer look at the car, I am at max droop with the way the REAR pod is made.
If I want any more droop I will have to go to the standard shock tower in the rear.
Old 06-03-2003, 12:12 AM   #7589
InitialD's Avatar
Default Re: rear droop
Try this
Driving style and setup of car will dictate the type of rear droop which would benefit the car handling.
A car equipped with a front diff usually requires a lot of steering. Beginners will find it OK but experienced drivers will find it a little lacking. So more weight transfer to the front off power is nice to have. You achieve this by having a lot of rear droop.
With a one way, off power steering is generally more than normal drivers would require and generally, you want to take out off power oversteer in the car. You do it by limiting the rear droop to prevent weight transfer from the rear to the front. Of course too little droop will make the rear end lift up and cause your rear end to loose traction. Too much is always no good. Everything needs to be just enough.
Old 06-03-2003, 02:54 AM   #7590
finchy's Avatar
Drfritz how much rear droop are you running it must be alot if you've run out of room for anymore.
finchy is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
