Old 05-29-2003, 02:07 AM   #7471
finchy's Avatar
You've dug your own grave now you'll have to lie in it.
I didn't start anything at all. That was nothing to do with you at all but you chose to come in on the issue. So this is where it ends.
Graeme
finchy is offline   Reply With Quote
Old 05-29-2003, 02:09 AM   #7472
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by xray vision
I used to run a vone r when they first came out but nevermind!
Tonight's topic...Placing isolalator's between between the engine and mount's. Will it overheat or keep the heat more constant?
Read it in a magazine can't remember the result's...Theories Please..
I've never done it... but the theory behind putting insulation between the engine and the mounts is to remove the chassis as a cooling source, and have the engine head be the primary cooling source.
The problem with using the chassis as a cooling source, is that it draws heat through the crank-case, which is the coolest part of the engine.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-29-2003, 02:09 AM   #7473
AMGRacer's Avatar
Originally posted by TSR6
...you guys done yet?
I am done, cant speak for the other guys.
AMGRacer is offline   Reply With Quote
Old 05-29-2003, 02:09 AM   #7474
finchy's Avatar
Xray vision when you mean isolators, do you ,mean the little blocks on the top of the engine mounts you get in the box with OS motors or is this something else.?
Old 05-29-2003, 02:10 AM   #7475
RCTech Member #2
TSR6's Avatar
isolator = insulator = cardboard, rubber, anything that doesnt transfer heat.
Troy
RCTech Member #2
Old 05-29-2003, 02:13 AM   #7476
VoneRkid's Avatar
I am done no more said
Damo
VoneRkid is offline   Reply With Quote
Old 05-29-2003, 02:13 AM   #7477
If oil and unspent fuel is used for cooling the how much cooling does the chassis provide?
I've modded an os cv-x thinking about tring the plates yes or no?
xray vision is offline   Reply With Quote
Old 05-29-2003, 02:13 AM   #7478
finchy's Avatar
I've never heard of the theory before but would a ceramic block be a good choice. I've heard ceramic is a good insulator. Also I've read and experienced this myself in the NTC3 it seems with a rear exhaust engine that the crank overheats. I know that the chassis's on these car are used a heat sink.
Old 05-29-2003, 02:15 AM   #7479
yes that is what i mean as an isolator..!
Old 05-29-2003, 02:17 AM   #7480
I think they isolate motors in nitro boats...?
Old 05-29-2003, 02:17 AM   #7481
VoneRkid's Avatar
Are you coming to the track on sunday if it is not raining
Damo
Old 05-29-2003, 02:23 AM   #7482
finchy's Avatar
I would say in theory that the isolators shold keep the chassis a bit cooler, this all so depends where the chassis has extra cooling slots. There are many variable to take into consideration. But isolation of the heat from the engine mounts should help the car overall stay cooler ( maybe a few degrees cooler ). It hard to say without doing some clinical testing. Anybody got a temp gun?
Old 05-29-2003, 02:25 AM   #7483
AMGRacer's Avatar
My thoughts on isolation.
1. It will raise the CG of the motor a little. Yeah yeah i know but every little bit matters. If you are going to do it cut the engine mounts down the same amount.
2. My chassis is plenty heat soaked after a 10+ minute race/heat. I am not sure that i want the heatsink head to be trying to do all the cooling if you can spread the load.
Old 05-29-2003, 02:25 AM   #7484
rrgt_kid's Avatar
yes i am all done
jeremy.
rrgt_kid is offline   Reply With Quote
Old 05-29-2003, 02:31 AM   #7485
finchy's Avatar
Legal motor combination for the state titles.
Well everyone will say JPs3 with the new inline pipe. But I'll go with Mario Collari modified Siro.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
