Old 05-27-2003, 03:51 AM   #7351
Taylor-Racing's Avatar
Originally posted by finchy
Are you running the rody with the restrictor in or out of the carb. What sort of refuel window are you acheiving.
Graeme
Yeah, I forgot about that, didn't I. The restrictor is in.
We ran five minute heats and it might have made it to five and a half or so.
Taylor-Racing is offline   Reply With Quote
Old 05-27-2003, 03:55 AM   #7352
finchy's Avatar
I can't comment on the difference between our two tracks but Brendale has the same surface that was used for the 2001 Worlds in Sydney, Let's say it's fairly smooth.
About bodies I've just recently changed to the new Stratus 2.1 from the 300m, and I've found the new stratus is great it's may have a little more steering than the 300m. But I think ( not quite sure ) it could be due to the new position I'm now mounting the rear wing. Also I've noticed that a lot of the guys running these bodies don't run their side veins for the wing either. Can anybody clarify why?
Graeme
finchy is offline   Reply With Quote
Old 05-27-2003, 04:02 AM   #7353
Originally posted by rrgt_kid
if its flaming out to easy at race temp when you come into the pits for a fuel stop its either the bottom end to rich or you may want to bring up the idle by adjusting the throttle stop screw!
because with the 12 size motors when they get at temp their idle gets a bit low, but by doing a bit of adjustment it should be good as gold!..
hope this helps
jeremy!
Yeah, I realise this. I'll need to attend to it.
Remember, it's first firing up was on Sunday morning. At that time the idle was very high and considering it was only 8C and it might have been 30 C when it was last run, I made some quick adjustments to get the idle within reason. Now, of course, it flames out as I described.
I'll get it right this Sunday . . . I'd better, 'cos we run six minute heats, there.
So, what happens with the restrictor out? . . . another half a horsepower?
Old 05-27-2003, 04:09 AM   #7354
rrgt_kid's Avatar
well first of all your motor will suck alot more air throught the carby! and you may gain a little more power not ovally alot!
jeremy.
rrgt_kid is offline   Reply With Quote
Old 05-27-2003, 04:22 AM   #7355
sparksy's Avatar
Trader Rating: 14 (94%+)
I doubt it...
If your still legal with the restrictor out, you may notice a slight drop in performance.... the restrictor is a nice venturi shape, with it out, the carbies bell is too sharp and may cause excessive cavitation above the spraybar.
sparksy is offline   Reply With Quote
Old 05-27-2003, 04:24 AM   #7356
finchy's Avatar
Unfortunatly Sparksy it is illegal with the restictor out the venturi dia. is to large for the IFMAR Rules. The motors got plenty of poke with the restictor in the carby.
Graeme
Old 05-27-2003, 04:25 AM   #7357
Graeme
On the bodies:
I know we had too much wing angle on the old Stratus 1, and I dare say that accounts for some of the differences I mentioned.
By "side veins" I presume you mean the verticle ends that are on the standard wing? Some people go one step further and put full end plates on the standard wing - that is, end plates that extend below the horizontal section.
Theoretically, the end plates will stop air spilling off the sides of the wing and increase it's effectiveness. The full end plates will increase it again.
It's quite feasible to alter the characteristics of the downforce by adding or subtracting these items, depending on what you want.
It's my thinking that wing differences likely make up a large proportion of the differences between bodies. . . . that'll get 'em goin' again.
So, our new S60 has a smaller wing than the old Stratus 1, but with full end plates. I "think" we have less downforce, a little more steering and better balance. Overall, I "believe" it's rather better with no reduction in stability. On a practical note, there seems to be more room under the front guards than with the Stratus, too. The Stratus 2.1 seems to have addressed the front guards issue though.
Old 05-27-2003, 05:21 AM   #7358
Originally posted by sparksy
I doubt it...
I haven't taken the restrictor out to have a look . . . Is it the same as the JP?
If so, I have always thought that sort of bowl shape couldn't be good for air flow, but, hey, JP should know a lot more than me.
Old 05-27-2003, 05:24 AM   #7359
Graeme
Hmmm . . . interesting.
Loose inserts in the tank are illegal, but a screwed in venturi is OK.
Old 05-27-2003, 05:33 AM   #7360
finchy's Avatar
The shape of the bowl is similar to the JP but it the actual hole at the bottom of the carby that comes under scrutiny. Anyway I'll be doing some track testing with the restrictor when it get closer to the date. Don't want to wear the motor out before I have to.
Graeme
Old 05-27-2003, 05:40 AM   #7361
sparksy's Avatar
The bowl shape is ok.... but the rody carb I saw the other week, the bottom of the bowl isnt a nice smooth curve. It has a sharpish corner that seals on the insert. So with the insert out, the air isnt nicley funeled. But that said, the larger venturi opening would allow more flow.... maybe not nice smooth flow without the restrictor, but more flow.
Old 05-27-2003, 06:53 AM   #7362
Yep. I always figured that the correct venturi profile should be shaped like a trumpet, not a bowl.
In full size car terms, I understand that the "sharpish corner" is usually considered to be only a small issue as the flow establishes it's own "air ramp" over small indentations without much negative impact. Someone will know more than me on this.
So, I guess the answer is to take it out and see what happens.
Old 05-27-2003, 01:08 PM   #7363
Que
Default Reflex Springs Work?
Do the Reflex springs work for the V ONE RR? If so where do you get a complete set from online?
Que is offline   Reply With Quote
Old 05-27-2003, 01:09 PM   #7364
Que
Default My Pixy
Has a nice venturi effect built into the carb
Old 05-27-2003, 01:16 PM   #7365
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: My Pixy
Any pics?
eddiethefish is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
