Old 05-21-2003, 10:50 PM   #7306
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Originally posted by Manticore
amazing. it does have some people think if they drive Masami's car, they could be world champion !!
Manticore
All I want is just to share my experience, I never said I could drive car like Masami and if you don't like please ignore my post, you don't have to being sarcastic
tl2111 is offline   Reply With Quote
Old 05-21-2003, 11:12 PM   #7307
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by tl2111
Manticore
I made a true statement and if you think I did any thing against you. sorry about that !
Manticore is offline   Reply With Quote
Old 05-21-2003, 11:32 PM   #7308
tl2111's Avatar
Originally posted by AMGRacer
Can you just explain in words what they did for now? Everybody is interested to know!!!
I think what simon did is, he epox some hard material under the 2nd mounting hole on the bulk head and then drill 2.6mm hole so that he screw the top arm in there, which make the link angle very much like M1RR with 3mm shims on it.
Old 05-22-2003, 12:22 AM   #7309
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Now Now... Tommy and Anthony, shake hands and make up
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 05-22-2003, 12:43 AM   #7310
AMGRacer's Avatar
I was wondering because I have also tried this and there is insufficient clearance to the diff outdrives and also insufficient material to drill a third lower hole. I was wondering how they achieved it!!
I HAVE actually tested the M1RR mod out at Brendale back to back with the V1RR rear end. On a non race day on the long track I was running 21.1 second average laps with the M1RR rear end and 21.7 second laps with the standard rear end. The M1RR squares up under throttle faster on a high bite surface.
AMGRacer is offline   Reply With Quote
Old 05-22-2003, 12:44 AM   #7311
AMGRacer's Avatar
BTW these are not indicative times for Brendale since the surface was dusty and had not been blown off.
Old 05-22-2003, 01:14 AM   #7312
tl2111's Avatar
I did compare both MTX3 and VoneRR, beside the low CG, their shock geometory are quite different, The MTX3 has alot more lay down then V1R front and rear.
If you notice the EVO, the front end bulk head has been narrow it bit so that it can lay down the shocks, it create more pack action from the shock. I think it make sense because traction roll generally cause by too much bite at the front.
Old 05-22-2003, 02:29 AM   #7313
finchy's Avatar
I would also like to know how simon did the mod, as I've being look at the bulk heads and there doesn't seem enough room to drill a third hole. So any info on this mod would be excellent.
Graeme
finchy is offline   Reply With Quote
Old 05-22-2003, 02:38 AM   #7314
Michael_T's Avatar
Is this the mod u guys are talking about, or am I just lost and need to speed more time away from the net...
Old 05-22-2003, 03:13 AM   #7315
finchy's Avatar
Novarossi the mod they're talking about is a mod done to the rear bulk heads. I think it's to lower the roll centre of the car, making the rear end similar to the MTX3 in the sense that the upper arm links are at a steeper angle, thus lowering the roll centre of the rear I think. The only real successful way to do this is to apply the M1RR conversion. This is what AMGRacer and Manticore have developed. I know AMGRacer said there is not really enough room to drill a third hole on the rear bulkhead, so you can place the upper inner link lower. This why they do the M1RR rear end. ( please AMGRacer and Manticore correct me if I'm wrong ). So if Simon Camaleri had a different mod for the rear end at the NSW titles, I think alot of drivers would like to see it and find out how's made it work successfully.
Cheers
Graeme
Old 05-22-2003, 03:46 AM   #7316
university_dave's Avatar
Does anyone know the spring rates in lbs for the black, silver and gold springs?
university_dave is offline   Reply With Quote
Old 05-22-2003, 03:49 AM   #7317
Manticore's Avatar
Cheers
Graeme
new holes on the bulk head have not been considered as it involves accurate mod to make symmetic camber angle. the MTX3 rear hub is a direct fit so why not?
Old 05-22-2003, 05:06 AM   #7318
finchy's Avatar
that's a good point Manticore thanks for the reply.
Graeme
Old 05-22-2003, 05:24 PM   #7319
AMGRacer's Avatar
I have been thinking about this stiffer rear swaybar idea. It seems to be a good alternative to the M1RR rear conversion.
It seems to me that it will give very similar results to a lower rear roll centre, but the camber change during cornering will not be as great as with the M1RR mod.
Old 05-22-2003, 05:26 PM   #7320
Originally posted by alana07
hi kingwillie,
ever wonder why those folks at protoform give you 3 or 4 holes to let you choose where to mount your wings?
i usually use the foremost and rearmost holes. if your car is pretty well balanced but just suffering from a little bit of turn in understeer, moving the wing forward will free up the rear end nicely.
Thanks very much for the reply, I have just never had this happen before, it is the first time I've run the 2.1. As to why I didn't consider the mounting position critical, I've never driven such an effective wing before.
KingWillie is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
