Kyosho VoneR Thread
#7171
Re: m1rr conversions
Originally posted by finchy
Hey guys, I know this question has been ask many times before and I'm sorry to ask again this list below could Manti or Amgracer confirm this all I need for the conversion.
Mugen T0229 F/R axle shaft 1
Mugen T0230 F/r drive shaft 1
Mugen T0139 Rear up right 1
Mugen D0105R king pin 1
Mugen J0110 adjust nut 1
3 Racing mtx3-008 wheel adaptor 1
10 x 15 ball bearing 2
6 x 13 ball bearing 2
Could one of you guys tell me what parts I have to buy 2 off ( ie does this list do both sides left and right ). And does it fit on the box standard chassis. I assume it uses the v1rr bulkhead at the rear. I know these might seem like stupid questions but I would really like to try this conversion out and I don't want to botch it up. Also do I have to use fast tyres with the mtx3 specific offset, as I don't know anywhere to get the 3 racing wheel adaptors except Hong Kong, can it be done without the adaptors using the mtx3 off set wheels.
Thanking You in advance.
Graeme
Graeme
I believe the followings are come in pair and you need two pair each instead of one pack
#7172
Need two of these items like Manti says.
#7173
YOu only need two alloy hex.
#7174
Re: Re: m1rr conversions
Originally posted by Manticore
some parts comes in 2 pcs in a pack so you need two pack if the required quantity is 4 pcs.
#7175
thanks for the quick reply guys it's much appreicated.
Cheers
Graeme
Cheers
Graeme
#7176
Re: Re: Re: m1rr conversions
Originally posted by rrgt_kid
i think the 3 racing wheel adaptor is the same as the mtx3 so greame go and se jeffery and youll probably get the parts dirt cheap!.
#7177
this is not a shimo chassis. this is from square i think
Damo
#7178
I have found the shimo chassis from the KYOSHO web site
Damo
Damo
#7179
Graeme is some kyosho low height engine mount part no. VZW029 the chassis part no.TSW1
Damo
Damo
#7180
Have a look at this cooling fan. High wind output from small size fan. Displays strong cooling effect at times of high temperatures. Designed to also cool the carburettor so heat from fuel injection is reduced. Part no. VZWO11
Damo
Damo
#7181
He is good tool Hudy Chassis balancing tool Simple tool designed for XRAY T1 to optimize chassis balance. Place the balancing tool pieces on a flat, level surface. Place the T1 chassis onto the points of the balancing tool, on the two holes drilled along the centerline of the chassis. Use precision balancing weights to balance the chassis so it stays level. Can be used for any other race car as well. He is pic of the balancing tool. Part no.107880
Damo
Damo
#7182
Damo
Damo
VoneRkid,where abouts did you find that pic and is shimo an amtermarket brand or is that an original kyosho chassis?
#7183
the shimo chassis is a genuine hop up!
jeremy.
jeremy.
#7184
jeremy.
jeremy.
Is there anywhere i can get some info on it and what is the difference between it and the stock,thanks?
#7185
Originally posted by Pulsar
Don't mean to be slow but do you mean a kyosho part?
This chassis would be made of a better quality Alumium probably 7075. It would be stiffer than the standard chassis.
