Old 05-05-2003, 04:22 AM   #7006
finchy's Avatar
AMGracer that turret looks a bit more like the goods have you tried this one out? I think I might just get one in case of emergency, and might as well try it out see if it makes any difference. Thanks for your help once again
Graeme
finchy is offline   Reply With Quote
Old 05-05-2003, 04:23 AM   #7007
AMGRacer's Avatar
Default Re: Gearing for good speed 0-1/2 throttle
Originally posted by esham
AMGRacer,
Sorry man could not locate your previous post on gearing. Need your advice what it the best gearing combo for my V1RR for good pick up and good speed Gearing for good speed 0-1/2 throttle.
My Engine Novarossi 5 Port TS1 .12, Other spur is stock
OK tuning guide for the V1R.
1. First up get the engine tuned. I wont go into this much here, but if the engine tune is wrong then nothing else will help.
2. Get a centax clutch. Adjust it like this. Set the endfloat to be 0.3mm (after much experiment I find this to be the best) and then adjust the clutch to engage as high as you possibly can in the RPM range without the rear tires breaking loose. This is a very misunderstood setting. For a higher grip track you really want the clutch set ultra high for maximum punch.
3. Start with the stock gearing if you are not sure. Run it on the track. Ultimately you want the top end of 2nd gear to top out right at the end of the straight. If you have RPM left go down on the 2nd gear pinion. Make it so that you top out right at the end of the longest straight. When you have that pinion right go 3-4 teeth down on 1st gear.
4. Set the 2 speed shift point. Tighten it up so that it does not shift into 2nd. Then slowly unwind it so it just shifts. You want the shift to be just as the car starts to slow down at the top end of 2nd gear.
If you do all the above your car will be an absolute rocket in a straight line.
AMGRacer is offline   Reply With Quote
Old 05-05-2003, 04:25 AM   #7008
AMGRacer's Avatar
Originally posted by finchy
AMGracer that's harmony isn't it?
Graeme
Yes Harmony. Man these guys have saved me hundreds if not thousands of dollars.
I have probably enough spares to make a brand new car. In the last 6 months I have only used a few spur gears from rock damage and some pulleys. This car is tough.
Old 05-05-2003, 02:07 PM   #7009
VoneRkid's Avatar
Cool
Originally posted by AMGRacer
Sorry man I choked:
www.rc-square.com
That is the turret we need it look good. The part no.Skr 33
This is not bad Part no.Skr 4
Damo
VoneRkid is offline   Reply With Quote
Old 05-05-2003, 04:05 PM   #7010
rrgt_kid's Avatar
hi finchy that rear turret looks nice and simple and could be alot stronger and hell of alot lighter see if you can find out more about the pricing! im still interested in those parts , but i like the carbon one as well as the gpm.
jeremy.
rrgt_kid is offline   Reply With Quote
Old 05-05-2003, 04:28 PM   #7011
drfritz's Avatar
[On another note. been looking at tire truers and they all seem to be for pan cars? does some any make one for sedans rims?
drfritz is offline   Reply With Quote
Old 05-05-2003, 04:56 PM   #7012
kevink2's Avatar
You just need the proper arbor for sedan wheel hexs.
kevink2 is offline   Reply With Quote
Old 05-05-2003, 05:07 PM   #7013
patelladragger's Avatar
Send a message via AIM to patelladragger
Yes it is. I miss my K car. I've already used more spares on the mtx3 than I did all of last year on the K car. I snapped 2 wheel axles in half in 2 consecutive runs (running solid rear) yesterday. No touchy board, just snapped on power. I like to run my lola against the 235's and I KNOW now I want my K car back. The mugen is so light the 235's boyz get rough with me and I go airborne everytime!
patelladragger is offline   Reply With Quote
Old 05-05-2003, 05:25 PM   #7014
drfritz's Avatar
thats the problem i have been running into. trying to find the right arbor, been looking at the C&M/TEAM Cobra one and all they list is 1/12 and 1/10 pan arbors, got any part numbers you can give me?
Old 05-05-2003, 06:48 PM   #7015
kevink2's Avatar
https://www.ssl-stormerhobbies.com/c....pl?pn=COB8027
part number is last digits in link address above.
Old 05-05-2003, 07:40 PM   #7016
TBR
TBR's Avatar
Default Siro Motor?
I know this is a V one R thread but I thought that I might as well ask the most intellegant people on this site. But has any one run a Siro motor with there V one R?? or RR I was just looking at some alternate engines to either Novarossi or RB I see they have a Siro V one RR combo deal in Japan so I know Kyosho wouldnt see it as a package deal if they thought the motor wasnt any good.
Any thoughts?
TBR is offline   Reply With Quote
Old 05-05-2003, 08:26 PM   #7017
vones's Avatar
Default Re: Siro Motor?
Any thoughts?
I wuld perfer to opt for ABC piston rather than AAC piston......and it seems the conrod for the engine wears out quite fast.......but on the whole its a pretty decent engine after running in.......I blew my conrod after running in.....no problems after replacing it....
vones is offline   Reply With Quote
Old 05-05-2003, 09:36 PM   #7018
drfritz's Avatar
THANKS
Old 05-05-2003, 09:46 PM   #7019
vones's Avatar
Anybody knows the difference when I changed from one-way to differential gear for the front without replacing the front side pulley(original 25 T) for RR........V1-R is 27 T for differential gear.
Old 05-06-2003, 01:04 AM   #7020
VoneRkid's Avatar
Here are some more V one RR parts.
Damo
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
