Old 04-28-2003, 07:43 PM   #6871
rrgt_kid's Avatar
Originally posted by coastaltony
I put a set of 30mm Fast tyres on, and they rub on the inside of the rim.
If I put one of them HPI style spacers in, the nut does not tighten down all the way. Maybe this is why Jaco came out with the 2 offset rim.
Is there a wider (like Serpent) hex I should switch to?
Are you using the new fast or old style???
Jeremy
rrgt_kid is offline   Reply With Quote
Old 04-28-2003, 07:51 PM   #6872
coastaltony's Avatar
I am not sure, never used Fast before.
The box is blue on the left side, and fades to white on the right side.
coastaltony is offline   Reply With Quote
Old 04-28-2003, 07:58 PM   #6873
TBR
TBR's Avatar
Default Re: v one rr set up
Originally posted by Tag
Hi all, i am in the process of getting a v one rr with one way, i would like to know with front one way installed how do you guys suggest for the rear diff set up as far as the oil thickness ? thanks
Jeff
you would want quite a thick oil maybe 30 000 or 50 000 but it may depend on your track that you run on.
TBR is offline   Reply With Quote
Old 04-28-2003, 08:00 PM   #6874
TBR
TBR's Avatar
You have a V one R? if so you need to get the wide tyre axle and wide tyre dogbone to allow the 30mm tyres on your car. This allows the tyres to spin freely without rubbing against the hub carrier
Old 04-29-2003, 12:22 AM   #6875
rrgt_kid's Avatar
Default Re: Re: v one rr set up
with the vone rr tune your rear diff between 3,000 to 10,000
because your can get alot of oversteer, i run mine at 6,000 with a front one way.
Old 04-29-2003, 12:48 AM   #6876
sparksy's Avatar
Trader Rating: 14 (94%+)
I would like to say all this talk of gear ratios no one has mentioned the tyre size debate I think that has a lot to do on how you can get the motor to scream.
I personaly like to forget about tire size when talking gearing....
Does it affect it? yes
However, with the method I use to select gearing it doesnt matter.
I gues I should have mentioned that I prefer to set my car up handeling wise before I gear....
So if there is a need to run small tires, I have them on the car when I gear it. fronts always start 2mm smaller then the rear.
Also, if you read back, once I find the perfect top gear, I add one tooth..... this allows for wear of the tires throught the day.
For club races I also like to use the biggest tires possable for the given track conditions without having them "squirmy"... mainly because I am a tight arse.
sparksy is offline   Reply With Quote
Old 04-29-2003, 01:13 AM   #6877
VoneRkid's Avatar
Cool
This is a good method the only differerce is I run a 1mm split.
The V one RR run 1:1 drive ratio
Damo
VoneRkid is offline   Reply With Quote
Old 04-29-2003, 01:14 AM   #6878
VoneRkid's Avatar
That is a good method but I use a 1mm split the V one RR runs a 1:1 drive ratio
Damo
Old 04-29-2003, 01:16 AM   #6879
finchy's Avatar
boycey I won't be there this weekend I have to run my new motor in yet and unfortunately I haven't got a pipe and header yet. I might be able to run it in on saturday, just depends on the work situation. We're quite busy at the moment ( 5 to 5 five maybe six days a week, grow money tree grow ). But I'll pop down and hassle you don't worry about that. Good luck for sunday
Graeme
finchy is offline   Reply With Quote
Old 04-29-2003, 01:19 AM   #6880
VoneRkid's Avatar
The same here Graeme Work Work and more Work
Damo
Old 04-29-2003, 01:22 AM   #6881
finchy's Avatar
gotta pay the bills this car racing costs a small fortune. Any way got to fly. Still setting the car up. check back in later. See ya
Graeme
Old 04-29-2003, 01:29 AM   #6882
VoneRkid's Avatar
Post
Graeme do you have the tc3 bottom bumper
Damo
Old 04-29-2003, 02:26 AM   #6883
finchy's Avatar
yeah I got one the rpm and the stock ones why is that.
Old 04-29-2003, 03:33 AM   #6884
rrgt_kid's Avatar
we need a stock one for dads tc3
Old 04-29-2003, 03:35 AM   #6885
rrgt_kid's Avatar
hi greame you setting it up as per stock to see how it goes???
make sure you get those shocks bleeding properly and make sure the rebound nice and smooth.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
