Kyosho VoneR Thread
#6811
Originally posted by NitroNut
On page 15 of the v1r manual step #19 it says to put in washer 3x8mm when i put that in my spur gears wont move is that suppose to happen? When i dont have the washer in there the gears move freely. Thx
#6812
Grameme did you get your clutch done.
#6813
yeah it's all fitted ready to rock and roll, just have to get an exhaust.
#6814
#6815
gear selection
Could someone please suggest what's a good gear selection for the Brendale track (QLD Aust.). Are stock gears alright or is there a better combination.
#6816
No manti the eh.. clutch bell and the gears dont sping when i tighten the screw on to them. it's just hard and everything to spin.
#6817
#6818
Ya i had to put in 4 lil shims so the bell didnt touch the flywheel whenever i spin the clutch bell backwards and spin it forward it gets loose but then it'll stop later on, when i dont sping it backwards it'll just be hard to spin. Imma check on it again later today i got stupid work bah!
#6819
Re: gear selection
I am runnig 16/22 pinion and 47/43 spur gears I find that is a good combination Brendale. The stock gears alright there as well you will need to get your self some pinions
Damo
#6820
Any California racers in here!
I need help setting up my V ONE RR
I have the V one rr
O.S. 12 TR Turbo P
THS Racing tuned pipe
JR XS3 radio
all the kyosho V One RR springs and 50 40 35 30 shock oil Wt's
Using rubber because i mainly run on unprerared surfaces
have 3 racing brake bar and vented brake disk and brake stopper have the kawa Negative diff on the way what else do i need to set up my car! help please
I have the V one rr
O.S. 12 TR Turbo P
JR XS3 radio
#6821
Re: Any California racers in here!
I have the V one rr
O.S. 12 TR Turbo P
JR XS3 radio
I have the V one rr
O.S. 12 TR Turbo P
JR XS3 radio
#6822
New V 1 RR
i saw the new v 1 rr on rcmodel... the 'kyosho cup japan edition' too bad there is only a pic of the box! is there anything much new in this edition to the v 1 rr series ?
#6823
Re: New V 1 RR
Damo
#6824
From what I know the world cup edition come with the following options;
1) Shimo 3mm Chassis
2) 2mm Caron top deck
3) Steel Roll cage
4) Alum Chassis stiffer with belt tensioner
5) Alum low CG engine mount
6) World Cup Edition Decal Sheet
Not too sure they have anything else.
Regards
Joe
3) Steel Roll cage
Regards
Joe
#6825
There was apost some time back that help with the problem with running out of steam on very long straightaways, that had different pulleys, does any body have that part number?
