Old 03-19-2003, 07:28 AM   #6466
NitroNut's Avatar
How great do you think a mugen clutch or any 3d clutch compared to a standard 2 speed?
NitroNut is offline   Reply With Quote
Old 03-19-2003, 07:57 AM   #6467
Taylor-Racing's Avatar
Originally posted by AMGRacer
Hehehe the MTX3 sure is a good car out the box. Nice and light!
Are you trying to tell us something, AMG?
Maybe Little Bo Peep has had a word in your shell like?
Taylor-Racing is offline   Reply With Quote
Old 03-20-2003, 03:29 PM   #6468
AMGRacer's Avatar
Hahahaha not really. I just think that the Mugen is a very good design. But I will be sticking with my Kyosho for a little while longer yet
AMGRacer is offline   Reply With Quote
Old 03-20-2003, 08:54 PM   #6469
TBR
TBR's Avatar
This apparent new V one R thats comming out is it going to be upgradable from the current V one R/RR or do you think we will have to bin our current cars?
TBR is offline   Reply With Quote
Old 03-21-2003, 07:03 AM   #6470
dameetz's Avatar
Default wheel revolution
I checked my V one RR today and found that when I rotate the rear wheel one complete revolution the front is turning less than the rear, is this normal? I just changed the front small pulley and the side rear to the aluminium one but it is still the same teeth(front small pulley 18T and side small pulley 19T). Is this normal because before I change to aluminium pulley I never check the wheel front rear revolution before. Also wouldn't this create a braking effect because the front is not rotate the same as rear?
dameetz is offline   Reply With Quote
Old 03-21-2003, 02:43 PM   #6471
squizzytaylor's Avatar
Does anybody have any evidence of a new car coming out? Ive heard rumours of shaft drive etc but nothing solid, come on spill the beans!
gt
squizzytaylor is offline   Reply With Quote
Old 03-21-2003, 02:48 PM   #6472
Smile V-One RR Setup
Anyone have a good setup for unprepare asphalt parking lots:
01. For front stock diff/rear TCD (LSD) diff and foam tires?
02. For front one way/rear solid axle and foam tires?
Thanks.
Atlas is offline   Reply With Quote
Old 03-21-2003, 09:11 PM   #6473
AMGRacer's Avatar
Default Re: wheel revolution
The V1RR has a 25T side pulley. So if this is installed the front does rotate less. With a front oneway this is fine, but if you install a diff then it is very bad for handling. Use 27T side pulley with a front gear diff.
Old 03-22-2003, 09:05 PM   #6474
RC
25t mid driven pulley makes front tires spin faster, not slower (8%). 27t makes fr/rr equal. Yes, 25t creates a breaking effect with both diff and one way because the fronts are pulling the rears so a tire dia split is needed to bring that percentage down (2-3%), just enough front pull to balance a solid rear/agressive set-up. Why when you spin your rear tire the front spins less is odd. Re-check that you have the pulleys installed in the correct locations (mid-driver 19t, mid-driven 25t, fr-driver 18t).
RC is offline   Reply With Quote
Old 03-23-2003, 07:05 AM   #6475
dameetz's Avatar
wheel revolution
I checked mine again today.when i spin the rear wheel one complete revolution the front only spin just pass half turn, I also checked my pulley everyhing is where it should be. Wouldn't this mean the front has less rotation than the rear? Anyhow what is the advantage of having front wheel run faster than the rear, also can I change to 27T front side pulley but still using front one way?
Old 03-23-2003, 11:18 AM   #6476
NitroNut's Avatar
For your v1r/r how did u find a place to put all of wires and stuff? i am deciding where to put it either on the upper deck somewhere or between battery and fuel tank or soemthing like that
Old 03-23-2003, 02:43 PM   #6477
AMGRacer's Avatar
Something is definately wrong there. Cannot tell what tho. The car will be undrivable with this much difference between front and rear.
Old 03-23-2003, 08:58 PM   #6478
NitroNut's Avatar
I tried starting my v1r wit a os tr today and the engine wont start i dont know why the flywheel will keep spinning but nothing, i checked the air filter and the engine was mad flooded then poured it out and redid everything and nothing help plz
Old 03-23-2003, 09:06 PM   #6479
AMGRacer's Avatar
Engines are very simple things so there can only be a few things wrong.
1. Is the glowplug working?
2. Is your ignitor charged?
3. Is fuel getting to the carb?
4. Are the needles set for an easy start?
If all this is yes then it will start.
Old 03-24-2003, 12:18 AM   #6480
Data's Avatar
if you are using diff. in the rear, make sure when you spin the rear wheels, both rear wheels spin in the same direction at the same rate. i am guessing the rear diff. is causing the big differences in rotation between the front and the rear wheels.
if you are uisng solid axial, then i have no idea.
Data is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
