Kyosho VoneR Thread >
Kyosho VoneR Thread
Like Tree1Likes
Kyosho VoneR Thread
Old 03-15-2003, 06:39 PM
  #6421
Manticore's Avatar
Originally posted by mitch179
i was wondering if the kyosho gears will fit on the mugen centax clutch bell ? ? the kyosho gears are easier for me to get than the mugen gears....
yes they do !
Manticore is offline
Old 03-15-2003, 06:47 PM
  #6422
AMGRacer's Avatar
harmony model is the place....
AMG where abouts do u race ? .... i want to see your rody tuned 5 port in action!
I usually race at Wynnum track lately which is a rubber tire track. Consequently i cannot use the 5 port My pictures a few pages back are the rubber setup.
I will likely be going to Meakin in a few weeks and the 5 port will be coming along as well
AMGRacer is offline
Old 03-16-2003, 09:28 AM
  #6423
NitroNut's Avatar
how many tims does it take for a new hump pack to fully charge? i've cycled them 3 times and no full power they're rated 1000 but only get 633 max out of it.
NitroNut is offline
Old 03-17-2003, 03:20 PM
  #6424
Bounty Hunter's Avatar
Default Hmmm....
Sounds like you have a bum hump pack. I usually cycle it once and it gets over 1100 Mah. I am using the Excel packs that are available at Nitro House.
Bounty Hunter is offline
Old 03-17-2003, 03:21 PM
  #6425
Default Re: Hmmm....
Just one question though what rate are you charging at?
Old 03-17-2003, 08:11 PM
  #6426
NitroNut's Avatar
I am charging at 125ma
NitroNut is offline
Old 03-17-2003, 10:05 PM
  #6427
NitroNut's Avatar
y so quiet these days
NitroNut is offline
Old 03-17-2003, 11:05 PM
  #6428
RClover's Avatar
i had similar problem with my hump pack rx batt as well and i thought it was my new charger at fault, but its not! These new batt required to be charge/discharge and put into use for a few times before you can fully charge them in one single cycle.
Sometimes i got the false peak at 6xx mah/ 7xx mah after 20 min of charging, but all i did was to unplug the rx and plug it in again and let it charge. If charging stop after 300mah, then you may repeat the step (plug it in) and leave it until the next cut-off. Sometimes i have to repeat this process 3 times, but after the 3 charging cycle, i sum up the total charging that was fed into the rx, it's around 1100 mah or a little more!!!
All others rechargeable batts like the AAA and AA Rx are much worse! Because these small batts does not like charging at anything more than 1amp.
RClover is offline
Old 03-18-2003, 04:30 AM
  #6429
VenomWorldOrder's Avatar
kyosho is dead unfortunatly
VenomWorldOrder is offline
Old 03-18-2003, 05:50 AM
  #6430
tl2111's Avatar
Trader Rating: 21 (100%+)
Not quit yet Thomas. M1RR has hit the moorebank track and very promising.
tl2111 is offline
Old 03-18-2003, 05:54 AM
  #6431
anything you end up driving tommy looks good!
for the sake of kyosho, i've left the flock. i made it look bad....REAL BAD! (and i don't mean that in a good way either).
Old 03-18-2003, 06:56 AM
  #6432
dameetz's Avatar
Default New V1RR owner
Hi guys!! I just bought a V one RR last 2 wk and this is my first R/C touring car after almost 6 years quitting the hobby. I bought at my LHS with a package deal including OS .12 TR(P)T and Kyosho Tuned pipe.During my absence in this hobby I m not that update about the engine technology.Not that the OS is not fast but I need an engine for my stock should anything happen to my OS.The thing is my LHS recommend me the Nova Rossi based engine JP Racing tuned RS12 T5S1 as an upgrade engine, is this a good engine? What is the engine power rating? Also how do I set up my car is it worth to buy the setting up board?
dameetz is offline
Old 03-18-2003, 07:05 AM
  #6433
NitroNut's Avatar
Kyosho DEAD!!!!!!! NEVER!!!! i will never believe as long as i got my v1r and lhs supplies me the parts i will come
NitroNut is offline
Old 03-18-2003, 07:19 AM
  #6434
coastaltony's Avatar
Nitro Nut
Do you run your voner on a prepared track?
Also, what springs & shock oil # do you use?
coastaltony is offline
Old 03-18-2003, 02:50 PM
  #6435
NitroNut's Avatar
hehehe funny u ask that coastal because i haven't even broken in my car yet, the track i am on is prepared and that's all of know so far tehehhe. sry
NitroNut is offline
