Old 11-18-2001, 07:16 AM   #616
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Novarossi
Who u talkin bout Willis?
Nothing mention on his setup sheet he used here Moon
http://www.mugenseiki.com/setupsheetmrx3-e092201wc.pdf
it didnt mentioned about the diff and solid axle setup !!
kawahara sponsored the mugen team. what do you think?
Manticore is offline   Reply With Quote
Old 11-18-2001, 07:17 AM   #617
Manticore's Avatar
Originally posted by hurhur
out of curiosity, what if the clutch in the negative diff wears off one day? im sure it will right......are they any direct replacements? how abt the kyosho LSD? need to get a new set to replace worn ones?
replacement parts will be available as spare parts just like the kawahara clutch type 2speed for MTX2.
Old 11-18-2001, 07:20 AM   #618
hurhur's Avatar
serious? sources from your friend in Kawahara huh?
hurhur is offline   Reply With Quote
Old 11-18-2001, 07:22 AM   #619
Manticore's Avatar
yes !! hee hee
I am doing the k factory fuel tank mod as well as fantom steering servo mount on my V1R now !
Old 11-18-2001, 07:24 AM   #620
hurhur's Avatar
yes !! hee hee
dont neglect yer MTX2
Old 11-18-2001, 03:36 PM   #621
AMGRacer's Avatar
yes !! hee hee
Hey Manticore what is the advantage of the fantom steering servo mount??
AMGRacer is offline   Reply With Quote
Old 11-18-2001, 05:43 PM   #622
Manticore's Avatar
it holds on the servo body, not the "ears"
Old 11-18-2001, 10:21 PM   #623
AMGRacer's Avatar
I have been thinking about the rear grip issue a bit more. The guy with the good rear grip has a V One S which I think comes with dry diffs. So as Novarossi and Manticore have suggested it probably is because the rear diff is too stiff. I went with the kit suggestions and put 50% 50000 and 50% 500 in the diff and filled it totally up. It feels pretty much the same as my old HPI used to feel when it had 30000 in it so I guess it is somewhere in that range.
So the suggestion on a unprepared parking lot style track is 5000-10000 wt? Or how about even empty + some lube?
I am also wondering whether the Kyosho LSD would be too severe for low grip surfaces? Perhaps using the active diff in the rear and setting it very open would be better? That way it could be tightened back up to 30000wt when I go back to the high grip track. The standard Kyosho setup worked very nicely for me on that high grip track.
Old 11-18-2001, 10:42 PM   #624
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Go 5000wt rear and 10,000wt front.
Michael_T is offline   Reply With Quote
Old 11-18-2001, 10:59 PM   #625
Michael_T's Avatar
BTW,
I found this quote from another forum :
Ok here it is-
A brand called General Silicon or GS are making a "version" of the V-one-R. GS make the V-one-R's for kyosho and they will be making one for Neo or DSI whoever it is. It will be much cheaper than the V-one-R. It will be realesed early 2002. When i have more info i'll post it.
Now we have the Trinity, Kyosho and another ????????
Old 11-18-2001, 11:45 PM   #626
AMGRacer's Avatar
OK pulled open the rear diff and..... empty
I did not do the 3mm screw mod so I lost all the fluid Would having a dry rear diff lose you rear traction (it was not totally dry....)
I have noticed that the car has gone from understeer to neutral through the slower corners (due to my diff oil ejecting ) I am guessing that having a high weight in the front (50000) and being zero in the rear may be inducing off power oversteer and on power oversteer. Any thoughts??
Old 11-19-2001, 02:33 AM   #627
Regional Moderator
BTW,
What the ?????? GS makes V1R for kyosho???? It's not April fool yet. How about Associated makes XXX-S for Losi?
White cat is offline   Reply With Quote
Old 11-19-2001, 02:35 AM   #628
Regional Moderator
GS is going to release a new nitro sedan, but it doesn't look like V1R.
Old 11-19-2001, 04:54 AM   #629
Mauler's Avatar
Send a message via ICQ to Mauler
Any site for reference?
Mauler is offline   Reply With Quote
Old 11-19-2001, 05:46 AM   #630
Trader Rating: 15 (100%+)
ive seen spy shots, and have spoken to the guy who imports them here in OZ and it looks more towards a v-one s and neo put together. gs dont make cars for kyosho, its the other way around, Kyosho are building the cars for GS, but dont get excited and expect cheap parts as most of the car parts will be ISO std so hardly any parts will fit v-one r or other.
amgracer, i use 30k in front and 10k in rear. its perfect for all-round use.
Kyosho Superten FW-04, O.S. 4 stroke conversion, fully optioned, shelf queen... my baby!
nitro dave is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
