Old 02-19-2003, 01:18 AM   #6241
Bounty Hunter's Avatar
Default Hmmm.....
Originally posted by InitialD
Ummm, with no overdrive pulleys installed, I believe when the rear tires get smaller than the front, the front end will be pulling the car and you'll be in overdrive mode because of the tire diameter difference. In that instance, the car will not push at the corners.
The reason being is that the tire rollout for the front end will be more than the rear end as the tire rollout depends on the tire diameter i.e. larger diameter, bigger tire rollout.
The front and rear wheels will have the same rotational speed (physics and engineering background people will denote this withthe greek word omega). Just that the rollout of the tires will be different.
Now I thought that with no overdrive, there could be a situation where you begin to lose rear traction due to the fact that the rear tires are rotating faster? Or is that more traction as the rear tires get smaller? Hmmm....I think I may be confusing my current setup with my old one which was with the 100,000 diff oil.
Bounty Hunter is offline   Reply With Quote
Old 02-19-2003, 02:24 AM   #6242
InitialD's Avatar
Default Re: Hmmm.....
I think the reason why you may be experiencing loss of rear traction is probably due to the front seemingly having more steering as the front end is now pulling the car. When the front end pulls the car, the rear end tends to follow and will seem somewhat lazy.
Old 02-19-2003, 07:25 AM   #6243
modellor's Avatar
With no overdrive set up, when your rear tires wear down smaller than the fronts you will get underdrive (pushing from the rear).
modellor is offline   Reply With Quote
Old 02-19-2003, 07:49 AM   #6244
Wolf's Avatar
Send a message via ICQ to Wolf
Oh, if front tire diameter is larger than rear, it should be overdrive. (The front is pulling the rear)
Wolf is offline   Reply With Quote
Old 02-19-2003, 09:11 AM   #6245
kevink2's Avatar
No underdrive, smaller rears will make your car push like a pig.
kevink2 is offline   Reply With Quote
Old 02-19-2003, 09:14 AM   #6246
Wolf's Avatar
Then i didn't understand why 25T pully is used as a overdrive pully? The 25T pully will make the front pull the rear (front speed is higher than the rear) Maybe it should call underdrive pully ??
Old 02-19-2003, 09:18 AM   #6247
kevink2's Avatar
Because it does create an overdrive condition!
Old 02-19-2003, 09:20 AM   #6248
Wolf's Avatar
Old 02-19-2003, 09:34 AM   #6249
Manticore's Avatar
R/C Tech Charter Subscriber
how does it look like when a pig pushes !!
Manticore is offline   Reply With Quote
Old 02-19-2003, 09:49 AM   #6250
kevink2's Avatar
Drives right through fences! Oink! Oink! Ouch!
Old 02-19-2003, 11:08 AM   #6251
popsracer's Avatar
Default Drives right through fences! Oink! Oink! Ouch
Like going through the boards at the end of the straight at Revelation?
Bounty Hunter;
Are you going to Rev this Sunday? I'll be there with Gus (2 dirty old men) but not racing myself. Come up and introduce yourself, always nice to meet another racing buddy. (I'll be wearing a Hitec hat)
popsracer is offline   Reply With Quote
Old 02-19-2003, 05:28 PM   #6252
Default Re: Drives right through fences! Oink! Oink! Ouch
Bounty Hunter;
Hitec hat huh? Yeah I think I will be there. My V one RR is almost ready for wall again! Hehe! I will most likely be racing on Sunday. I am sure you can spot me. I believe I am the only 6'2" 245lb. asian there! If there is another one, let me know, maybe we can start a Sumo racing group!
Old 02-19-2003, 05:45 PM   #6253
kevink2's Avatar
I'll probably end up there too.
Got a chance to stop by Revelation last night. The suggested 4mm stagger between front and rears with the 25T OVERDRIVE pulley felt awesome. I dropped my STS in there and it now weighs less than my MTX-3! Oh yeah B.H., 30,000 wt. seems to work well there. Any thing softer and your car will push... like a pig (there I said it again, oink!) out of the corners.
Old 02-19-2003, 07:36 PM   #6254
NitroNut's Avatar
WHat kind of tires u guys recommend for paved and aspahlt treated tracks? assuming on foamies
NitroNut is offline   Reply With Quote
Old 02-19-2003, 09:02 PM   #6255
Manticore's Avatar
Dont say bad words such as "your car looks like a pig" when you see an unsteer car !
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
