Old 02-13-2003, 10:37 AM   #6181
kevink2's Avatar
Yep, you just need to remove the rear body mount, or just cut the mount down if you're running a sedan body.
kevink2 is offline   Reply With Quote
Old 02-13-2003, 10:40 AM   #6182
DCR1TWO's Avatar
Originally posted by NitroNut
woohoo it's only 26.80 cant w8 to get it, does a mugen clutch fit on a r witout ne mods?
There's a blade style aluminum front sway bar on ebay right now for $15. Not sure which brand, probably 3Racing.
Sway Bar
DCR1TWO is offline   Reply With Quote
Old 02-13-2003, 01:59 PM   #6183
rskoncepts's Avatar
Trader Rating: 21 (100%+)
AMGRacer or Manticore...
I noticed the pictures that AMGRacer showed was using rubber tires with the MTX3 mod. Does that work well also? I assumed the mod would be more for a foam car.
rskoncepts is offline   Reply With Quote
Old 02-13-2003, 05:49 PM   #6184
Manticore's Avatar
R/C Tech Charter Subscriber
the mugen mod will let you take care of that by adjusting the shim on the hub.
Manticore is offline   Reply With Quote
Old 02-13-2003, 07:30 PM   #6185
RClover's Avatar
Default Part # for the Shim on the hub?
Is there a part # for the shim on the hub? what are the size of these shims? In multiple of 1mm/0.5mm?
RClover is offline   Reply With Quote
Old 02-13-2003, 08:23 PM   #6186
AMGRacer's Avatar
Originally posted by Taylor-Racing
Oh, I dunno . . We use the Fantom clutch for the same reasons - there was no RR around at the time. The Fantom clutch uses three conical pieces for the fly-weights and has never given us a problem. I would say it's a pretty robust unit, just not as light as the latest trick ones like the Kawahara.
Had a chance to try the Fantom Red springs last weekend. We started off using Gold all round and ended the day with Black fronts and the Red's on the rear. Tyres were Active 40/40. I was pretty pleased with how this all worked, actually, but I can't imagine how we would find enough steering if we had used Red's on the front also. I had imagined that Brendale has only a little more grip than Lilydale - never run at Brendale, so I'm guessing a bit, here.
I would think that Fantom Yellows would be really skatey at Lilydale.
We also tried some new gearing. 18/22 with 48/43 spurs.
I know it looks wrong on paper, but on the track it was great.
These Venom pinions wear very well, too.
Hehehehe trust me the Mugen clutch is much better and lighter
Some people like hyper steering, and in fact some tracks hook up the back end better than the front end. Brendale is fine with slightly harder front springs and 40/40sh tires. For me that is
AMGRacer is offline   Reply With Quote
Old 02-13-2003, 08:26 PM   #6187
AMGRacer's Avatar
Default Re: Pics...
Originally posted by RClover
AMG,
I love to see the Rody Tuned X12 5 Port plsss.....
It is always pictures with you guys!!!
Well it is not in the car but I can take some pics. What sort of pics you want?
Old 02-13-2003, 08:32 PM   #6188
AMGRacer's Avatar
You are right, but the MTX3 hubs with the upper inner Kyosho hole and no shims on the hub is around perfect for rubber tires on my track. It gives around .5 degrees camber change under compression.
Put it on the lower inner hole and around 3mm of shims for a fast foam tire setup.
Old 02-13-2003, 08:42 PM   #6189
JUN
Default Re: Re: Pics...
A pic of you putting it in a box and shipping it over to me would be nice.
JUN is offline   Reply With Quote
Old 02-13-2003, 09:37 PM   #6190
patelladragger's Avatar
Send a message via AIM to patelladragger
Default Re: Re: Re: Pics...
here, here! I'll even give him what he paid for it for such a picture seeing as how he's got the cool guy hook-up and can get another for prices we mortals can only dream about
patelladragger is offline   Reply With Quote
Old 02-13-2003, 10:01 PM   #6191
NitroNut's Avatar
i wish i lived in hk or something i would break millions of parts and just walk over to like harmony or something and buy 2 million of the parts i broke
NitroNut is offline   Reply With Quote
Old 02-13-2003, 10:03 PM   #6192
NitroNut's Avatar
<-----looking at silver arrowanas
Old 02-13-2003, 11:25 PM   #6193
RClover's Avatar
Default Part no. for Fantom Spring
Appreciate if any1 could kindly provide the part no. for Fantom Springs Yellow and Red (Front & Rear). Also the Fantom Piston part no.
Old 02-14-2003, 03:34 AM   #6194
Taylor-Racing's Avatar
Default Re: Part no. for Fantom Spring
KYOFM 36917 Fantom Red-rear 1.7
KYOFM 36817 Fantom Red-front 1.7
KYOFM 36918 Fantom Yellow-rear 1.8
KYOFM 36818 Fantom Yellow-front 1.8
Sorry, don't know the piston part no. . . . AMGRacer?
Taylor-Racing is offline   Reply With Quote
Old 02-14-2003, 04:03 AM   #6195
Manticore's Avatar
Default Re: Re: Part no. for Fantom Spring
FM424
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
