Old 11-18-2001, 05:47 AM   #601
Mauler's Avatar
Send a message via ICQ to Mauler
Originally posted by AMGRacer
How much difference dows the Lola body make? Would it make an oversteering car into a neutral car just with the body?
The LOLA gives the best downward forces and thus giving better handling characteristics such as better steering control and better rear end traction whilst negotiating a high speed sweeper. It does give and oversteer but some amount of experimentation on the rear wings should solve the problem...but too much of downward force in the rear might cause an understeer...
The Serpent factory drivers were complaining of too much steering, but modifications to the rear wing solved the problem...
Mauler is offline   Reply With Quote
Old 11-18-2001, 05:49 AM   #602
Mauler's Avatar
Originally posted by Manticore
the Lola is a very neutral body but it gives you much much better overall downforce
Yes it does... but I wonder if anyone tried the 1/8th configuration like a front one way and a solid rear axila on a 1/8th? How does it compare other than the speed?
Old 11-18-2001, 05:49 AM   #603
Manticore's Avatar
R/C Tech Charter Subscriber
node node !
Manticore is offline   Reply With Quote
Old 11-18-2001, 05:51 AM   #604
Mauler's Avatar
Hey Manticore! U trying out this configuration soon?
Old 11-18-2001, 05:56 AM   #605
Manticore's Avatar
i bought a bunch of foam tires but i still havent used them due to busy at work.
I would never try the rear solid axle as 1/10 touring car chassis is very different from IC car. the 1/8 rear tire is a few times wider then the front tire so It wont do any adverse effect to the performance while running a solid axle in the rear end.
Old 11-18-2001, 05:59 AM   #606
Mauler's Avatar
I thought manufacturers are coming out with conversion kits that allow 1/10th cars to run wider rear tires? This would not help?
Old 11-18-2001, 06:02 AM   #607
Manticore's Avatar
I have heard that the world champion in australia use the kawahara rear negative diff in the world's.
Old 11-18-2001, 06:05 AM   #608
hurhur's Avatar
u mean Kenji Osaka uses a Kawahara Negative Diff on his MRX3?
hurhur is offline   Reply With Quote
Old 11-18-2001, 06:06 AM   #609
Manticore's Avatar
YES !
Old 11-18-2001, 06:07 AM   #610
Mauler's Avatar
The LOLA bodies that we run on are based on the 1970's Porche LOLA design...
This is the the new body in the 2001 LeManns... Solves most problem of understeer!
Old 11-18-2001, 06:08 AM   #611
hurhur's Avatar
YES !
wah! manti where did u read that from? u got his setup sheet or something like that?
Old 11-18-2001, 06:16 AM   #612
Mauler's Avatar
No wonder the top 3 Japanese lap the others by such a large distance!
Old 11-18-2001, 06:21 AM   #613
hurhur's Avatar
out of curiosity, what if the clutch in the negative diff wears off one day? im sure it will right......are they any direct replacements? how abt the kyosho LSD? need to get a new set to replace worn ones?
Old 11-18-2001, 06:27 AM   #614
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Who u talkin bout Willis?
Nothing mention on his setup sheet he used here Moon
http://www.mugenseiki.com/setupsheetmrx3-e092201wc.pdf
Michael_T is offline   Reply With Quote
Old 11-18-2001, 07:13 AM   #615
Manticore's Avatar
got this information from a friend of kawahara. !!
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
